+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: 2009 Sierra Ext Cab 18" Zcon Install (Tons of pics)
  1. #16
    darren700's Avatar
    darren700 is offline got bu/\/\p?
    Jun 2006
    Windsor, Ontario, Canada
    485
    Re: 2009 Sierra Ext Cab 18" Zcon Install (Tons of pics)
    thanks alot guys. didnt bypass the voltage regulator, so no need for it. My voltage barely drops below 14.4
    Yes amps are grounded to the frame, but keep in mind both batts are grounded together, and both are grounded in two spots to the frame, plus two grounds from the engine to the frame.
    2009 GMC Sierra SLE Ext Cab
    Hu: Premier P690UB
    Front: CDT ES-6MO, DRT-26a, Upstage Tweeter, 560 Xover
    Amps: Audioque AQ2200 and US Amps MD23
    Sub: SSA Zcon 18 D2 (6.6cu ft @ 28hz)
    Wiring: 2 run Knuconcepts 1/0 ga w/ Big 3
    Elect: Singer 350a Alt.
    Batts: Stock and HC2400
  2. #17
    darren700's Avatar
    Jun 2006
    485
    double post
    Hu: Premier P690UB
  3. #18
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,506
    24 Post(s)
    Nice build! Wiring is really clean. But, your doors/mids could use some work. Get those tweeters up to the A-pillars, and seal off the door. You'll notice much better sound in the front stage as a whole.
  4. #19
    darren700's Avatar
    Jun 2006
    485
    Actually, the doors are completely sealed, i just forgot to take a picture of them when i was finished. there are no holes in the door skin now.
    There are tweeters in the a pillars as well as in the doors (DRT25 Titanium in doors and CDT Upstage kit tweets in the a-pillars). images really well. i am very happy with the frontstage, the upstage tweeters really raise the image well.
    much better than in my monte carlo.
    Hu: Premier P690UB
  5. #20
    Iosias's Avatar
    Iosias is offline Senior VIP Member
    May 2012
    United States
    412
    5 Post(s)
    Hmm, my friends voltage goes from 11-14v, maybe his dash is metering wrong. We wanna run 2k plus in it but were worried about the alt. (2010 Silverado)
    Refs # Tallc, CleaRSkieS, Roth, Goindef154, Kangaroux, tv559
+ Reply to Thread
  1. 97 GMC Sierra ext cab., 2 18 inch Fi SSD's, RF p1000.1bd
    By sierrawitdaslap in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-09-2010, 10:35 AM
  2. 2000, ford f 150 regular cab install, tons of pics
    By twistedmind in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 01-06-2009, 12:41 PM
  3. Tweeter Installation *TONS OF PICS*
    By ThomasG in forum General Discussion
    Last Post: 12-07-2006, 09:08 PM
  4. box to fit 02 gm sierra ext cab
    By 02gmsierra in forum Enclosure Design & Construction Help
    Last Post: 09-29-2006, 11:12 PM
  5. Need to build a Box for Gmc Sierra Ext. Cab.
    By Rc 415 in forum Enclosure Design & Construction Help
    Last Post: 05-13-2006, 08:59 PM
