+ Reply to Thread
Results 1 to 7 of 7
Reload Thread: 2009 Ford Fusion Build Log, slow and steady.
    st0n3r's Avatar
    st0n3r is offline Member
    Apr 2012
    147
    1 Post(s)
    So this is my 1st legit full build. The 1st time Ive did the Big 3, the 1st time Ive invested in batteries and such. Pictures will be uploaded slowly but surely as I am still in the process of completing the install.
    Special thanks goes out to @Buck ; for designing my box with the limited space in my trunk.
    My system is currently comprised of the following.
    1.) Clarion CX501 Headunit
    2.) Rockford Fosgate t1500bdcp Amp
    3.) Kicker 15" L7
    4.) Rockford Fosgate 2 Farad Hybrid Cap
    5.) SHURiKEN SK-BT45 (under the hood)
    6.) SHURiKEN SK-BT20 (in the trunk)
    7.) 0 AWG power / ground wires from audio technix
    Other altercations to car.
    1.) Pirelli P-Zero 225/45/18 tires
    2.) Incubus Paranormal 18" Rims
    3.) HID's for Low-Beams / Foglights
    Head Unit Installed
    Measuring the trunk for box design
    Some deadening going on
    More deadening
    And more deadening
    A litte more
    laying out the wiring
    wiring getting ready for runs
    power and ground wire from trunk through the front firewall
    st0n3r's Avatar
    Apr 2012
    147
    1 Post(s)
    Re: 2009 Ford Fusion Build Log, slow and steady.
    A few more pictures of the build process.
    another picture of the power / ground wires through the firewall
    trunk wiring with battery terminals
    new wheels tires installed
    Side view with the new tires / rims.... Why yes that is a 2013 Jeep Grand Cherokee SRT-8
    box in the trunk to ensure a smooth fit
    closer view of the box in the trunk
    putting the nail filler in to smooth out the edges
    another view of the box getting prep'd before working on carpet
    winkychevelle's Avatar
    winkychevelle is online now CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    21
    2,466
    6 Post(s)
    looks good so far. not really a fan of kicker squares but hey if your satisfied thats all that matters. and i would ditch the cap personally. the money spent for it would be better spent on another bt20
    2012 Nissan Versa Hatch
    Going back to stock
    st0n3r's Avatar
    Apr 2012
    147
    1 Post(s)
    the cap was free when i bought the amp, so might as well put it to use. with all the other electrical upgraded and the batteries it can only help an cant hurt anything.
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,525
    1 Post(s)
    nice job so far
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
    st0n3r's Avatar
    Apr 2012
    147
    1 Post(s)
    So Ive completed the build for now. My next step in the spring will be replacing all factory speakers and getting the windows tinted.
    Here are some final pictures as of now.
    HID's being installed.
    Overview of box / sub in the trunk.
    Behind the seat wiring and cap install. *will clean up wiring and mount the cap (not on the box of course)*
    Amp mounted on back of the drivers side rear seat
    2nd battery in the trunk. Will have a neat little corner shelf made and carpeted to flow nicely.
    st0n3r's Avatar
    Apr 2012
    147
    1 Post(s)
    I am going to have to slap several more layers of sound deadener in the trunk because its just too annoying when i turn it up. Inside the car sounds good, but the moment i step out you can hear the rattling big time. Also need to figure out how to fix my rear-view mirror, its causing a bad interior rattle also.
    On a side note, i need to find out how to get this system to hit harder. When i did the tuning on my amp i used my DMM. My amp is 1500w across the board, but the sub is 1k rms and 2k max. I tuned using the amp at 1k x 2ohm and square rooted that. Set my freq on between 60-80, think right about 44.7 was the voltage, so i went to 43.5 just under. I also tuned with the sub on volume 4 of 6 with my radio volume at 24/40. Anything above 24 and the factory speakers just sound like garbage. I also has the punch thing turned all the way down so the remote knob is kind of useless at the moment. I must admit though, the time and effort into the system, and of course the money, id really have thought this would have hit a lot harder. Ill try alternative songs another day though.
    Any advice on easily getting this to hit harder and really pound? Would adjusting my voltage up to 1500 instead of 1k make a big different? Would making any other changes like the freq. etc make it louder? How bout the punch settings?>
+ Reply to Thread
  1. 93 Ford Ranger Build Log
    By UCF_Knight24 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 10-13-2009, 09:19 PM
  2. 2002 Ford Explorer Build Log
    By kbkid in forum General Discussion
    Last Post: 08-31-2008, 01:11 PM
  3. 2000 Ford Ranger build log
    By TPABlazer in forum Enclosure Design & Construction Help
    Last Post: 11-26-2007, 08:25 PM
  4. Ford F150 Build Log(Work In Progress)
    By Trepkos in forum General Discussion
    Last Post: 09-02-2007, 02:41 AM
  5. '06 Ford 500 Build Log
    By Loud3 in forum Car Interior/Exterior Enhancements
    Last Post: 05-20-2006, 02:50 PM
