+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 51
Reload Thread: Impala Build
  1. #31
    Below20hzonly's Avatar
    Below20hzonly is offline CarAudio.com Elite
    Feb 2012
    East Grand Forks, MN
    796
    19 Post(s)
    Re: Impala Build
    this
    Quote Originally Posted by dbeez View Post
    Umm get that tweeter out of the door and up to the a pillar.
  2. #32
    Feb 2012
    796
    19 Post(s)
    Re: Impala Build
    make sure your hpf is set around 120hz and keep the treble and bass flat until you experiment more later, what other adjustments are you having trouble with?
    Quote Originally Posted by Jsantoyo89 View Post
    the only issue i am having is setting up my amp settings and HU setting the amount of option on this unit is overwhelming to a newbie. Any tips on what i should be adjusting? also would it sound better or be easier to adjust settings if i go active?
  3. #33
    Jsantoyo89's Avatar
    Jsantoyo89 is offline Banned
    Jan 2012
    chicago
    278
    1 Post(s)
    Re: Impala Build
    Would i set the HPF on the amp or on the HU? what differ does it make having the tweet on the A pillar as oppose to where i have it?
  4. #34
    Feb 2012
    796
    19 Post(s)
    Re: Impala Build
    set the hpf on your HU for the speakers to around 120 and your LPF on your amp to around ~80-90hz, Whats the point of components if you have them right next to each other anyways... it will sound better and separate the high/mids alot more
  5. #35
    Jan 2007
    any wet spot i can find
    3,282
    50 Post(s)
    Re: Impala Build
    It shifts the focus from your knees to your face...it is called imaging. And are you using your active crossover network in the 80prs, or just the passives that came with the comp set?
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  6. #36
    Jsantoyo89's Avatar
    Jan 2012
    chicago
    278
    1 Post(s)
    Re: Impala Build
    Quote Originally Posted by quackhead View Post
    Passives that came with the comps.
    As far as relocating tweets on the A pillar would i face them towards the windows, cabin each other? How high would i want them?
  7. #37
    Jsantoyo89's Avatar
    Jan 2012
    chicago
    278
    1 Post(s)
    Re: Impala Build
    Quote Originally Posted by Below20hzonly View Post
    Would it make a differ if the HU unit is in Network mode?
  8. #38
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Re: Impala Build
    Face tweeters at center of window put them down pretty low about 6-8" up from the dash if I recall correctly from mg old impala
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
  9. #39
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Re: Impala Build
    Or try this get some double sided tape make some long wires pull tweeters out tape to pillar close doors and do some testing moving them around til you find the sweet spot for your ears you will thank me later.
    2002 suburban
  10. #40
    Feb 2012
    796
    19 Post(s)
    Re: Impala Build
    on axis more treble off axis more mellow highs
  11. #41
    Jsantoyo89's Avatar
    Jan 2012
    chicago
    278
    1 Post(s)
    Re: Impala Build
    working on that now!
    thanks for the help guys.
    as far as the HPF on the head unit the only thing i found was 125hz HPF is that good enough?
  12. #42
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Re: Impala Build
    OK how was the sound.
    2002 suburban
  13. #43
    Jsantoyo89's Avatar
    Jan 2012
    chicago
    278
    1 Post(s)
    Re: Impala Build
    sounded way better than what i had. tomorrow i might mess around with it going Active.
  14. #44
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Re: Impala Build
    Sweet your welcome. Glad we could help you move in the right direction.
    2002 suburban
  15. #45
    Jsantoyo89's Avatar
    Jan 2012
    chicago
    278
    1 Post(s)
    Re: Impala Build
    now to work on the substage. Also been messing around with it on Active and sounds much better and seems a little more easier to tune except for the tweets they are too **** bright!
    Regardless thanks for the help guys!
+ Reply to Thread
  1. Cyn's - - - 007 Impala Build Log...
    By cyn in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 12-30-2012, 11:12 PM
  2. The Impala-Warden Build Thread
    By power-fanatic07 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-16-2010, 07:45 PM
  3. 2001 Impala Build
    By MikeyF in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 01-20-2010, 12:41 PM
  4. 1970 Impala full build all audison
    By coogle in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 06-03-2009, 03:46 AM
  5. 1996 impala ss build log
    By hemi=22s in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 11-04-2008, 03:05 PM
