Results 1 to 10 of 10
Reload Thread: '98 Cavalier Build
    sbelew's Avatar
    sbelew is offline Senior VIP Member
    Sep 2010
    New Port Richey, FL
    51
    213
    40 Post(s)
    '98 Cavalier Build
    Enclosure started out to be a slot port, but then a change of plans, (and subs) I went with a round ported box. My first attempt at building a ported enclosure, with assistance from Kushy_Dreams, Thank You. It is a little rough but I will pull it back out to sand and cover it. I wanted to listen to it first before I spent anymore money on carpeting.
    Specs are;
    2 Boston 10" G1's (Thank you Cerwin Vega Fan)
    2.3 Cu Ft Net
    32Hz
    25 sq in of port
    Massive Audio NX5 Wired to 2 ohms.
    Vehicle: '99 Ford F-150 Extended Cab / '98 Chevy Cavalier LS
    Head Unit: Kenwood KDC-X997 / Kenwood KIV-BT900 w/ HD Radio
    Sub: FI Audio x12 4ohm w/BP 1cu ft sealed / 2 GTO804's 1.4 cu ft @28Hz
    Sub Amp: Hifonics BRZ1700.1d /
    Front Door Speakers: Massive Audio CK6 / Massive Audio CK6x
    Rear Door Speakers: Boston Acoustics SL80 / Massive Audio VX69
    Amp: MBQuart DSC4125 / Massive Audio NX5
    Wiring: All Knukonceptz
    Sound Deadening: eDead 45 / AT60 / Murder mat BL
    References: Retroaudioinc, davidtemple, cd6551, double07, Ssteele18
  2. Likes Sleeklsc liked this post
  3. #2
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,520
    14 Post(s)
    2181 Post(s)
    Re: '98 Cavalier Build
    Only thing I would change is round off that hard edge on the inner lip of the pvc
  4. #3
    Fiendstolemyamp's Avatar
    Fiendstolemyamp is offline Call of the Wintermoon
    May 2011
    GA
    793
    58 Post(s)
    Seems like a lot of port for those drivers, I know BA recommends using 3" ports with these. Might be kind of peaky.
    I use gain as a volume control.
  5. #4
    Sep 2009
    5,520
    14 Post(s)
    2181 Post(s)
    Generally with round ports you can get away with less port area due to the increased efficiency over slots but in this case the ports aren't flared so its ok to go with a little bigger port area. But the hard edges do need to be eliminated.
  6. #5
    sbelew's Avatar
    Sep 2010
    New Port Richey, FL
    51
    213
    40 Post(s)
    I couldn't get the numbers to work out right with using 3" ports. Might be because of my of cu ft is smaller than what Boston recommends. I went with 4" and stayed within the 9" to 13" per cu ft rule. Ended up at 10.9" per cu ft. And I'm not sure what peaky means. I will also round off the edge of the port when I take it out to finish it.
  7. #6
    Sep 2009
    5,520
    14 Post(s)
    2181 Post(s)
    that rule doesnt apply to round ports and the rule isnt always something to stick to when using slot ports. its not a big deal. if you are able to (looks like not much side on the sides) make sure you have at a port's width of clearance to allow proper airflow from the exit of the port
  8. #7
    sbelew's Avatar
    Sep 2010
    New Port Richey, FL
    51
    213
    40 Post(s)
    Im real close on that side clearance of the ports. I know I need 4" of clearance. I didnt have a tape measure handy at the moment, but i will check that. Its a real tight fit, with trying to retain some usable trunk space. I'm going to check that, I may end up having to rebuild the box. It started out being for a single 12 and got modified for 2 10's. I actually may try slanting the back of the box to fit up tight against the back seat, narrow it down some and give it a little more depth, which should solve that port clearance problem, free up a bit more trunk space, and perhaps drop the tuning down a bit more. Its a learning process, but meanwhile the learning is taking a bite out of my pocket, and the subs are starting to collect here. Need to put them up for sale soon.
  9. #8
    sbelew's Avatar
    Sep 2010
    New Port Richey, FL
    51
    213
    40 Post(s)
    Here is the latest addition to my system. I decided to go back and try the JBL GTO804's again, ported this time. It is 1.4cuft enclosure tuned to 28 Hz. Very clean sounding, plays low and is not overpowering. Sounds great actually. I just finished it up over the weeknd. Now I need to pull out the amp mount and recover it in the same material and clean up the wiring. Here are some pictures.
  10. #9
    rdlyn13000's Avatar
    rdlyn13000 is offline Senior VIP Member
    Apr 2012
    White Bear Lake
    493
    184 Post(s)
    Looks good but I would slide the box closer to you trunk lid, about 6-8"s off
  11. #10
    sbelew's Avatar
    Sep 2010
    New Port Richey, FL
    51
    213
    40 Post(s)
    Why would you do that?
  1. 2001 Cavalier Build
    By tapout383 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 08-10-2008, 03:39 PM
  2. Need help replacing flasher fuse in an 98 Cavalier
    By 93 saturn sl2 in forum Car Performance and Repair
    Last Post: 07-15-2006, 01:09 AM
  3. 98 cavalier
    By magmaGT in forum Wiring, Electrical and Installation Help
    Last Post: 08-31-2003, 11:47 AM
  4. Help.... 98 Cavalier....
    By cbwhitie in forum Wiring, Electrical and Installation Help
    Last Post: 06-05-2002, 05:33 PM
  5. Help With 98 Cavalier
    By TwiztedRolla in forum Wiring, Electrical and Installation Help
    Last Post: 05-02-2002, 02:14 PM
