+ Reply to Thread
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 62
Reload Thread: Ford Excursion Build
  1. #46
    jteske88's Avatar
    jteske88 is offline CarAudio.com Elite
    Apr 2012
    collinsville il
    942
    6 Post(s)
    Re: Ford Excursion Build
    what you do with them boston mids and tweets that were in there? crossovers possibly?
  2. #47
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,694
    It is all old and pretty much junk, so will likely go in the trash.
    Anyway, metered that L5 12 today. Did a 138.8 on the dash with absolutely no testing/tuning/etc.
  3. #48
    jteske88's Avatar
    Apr 2012
    collinsville il
    942
    6 Post(s)
    hey i dont care about old stuff lol really just need set of mids and cross over, only reason i ask is i had a set in a car years ago and i loved em.
  4. #49
    Sep 2006
    Tampa, FL
    7,694
    Well I really doubt they would be worth shipping. They sound like crap anyway.
  5. #50
    jteske88's Avatar
    Apr 2012
    collinsville il
    942
    6 Post(s)
    alright thats cool just was asking
  6. #51
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,525
    1 Post(s)
    ummm never thought to use an old guitar amp speaker as a midbass in the door... that is sick as hell and i love the sound of peavey speakers i had an old vintage peavey tube amp for my guitar sounded amazing
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
  7. #52
    Sep 2006
    Tampa, FL
    7,694
    The little 6.5s and 8s just dont cut it. Just like a cheap, tiny, wimpy sub wont cut it for bass, to get the vocals that you can feel in the ground you need to step up to the big mids and use big power.
    The front will only have tweets, but the back will hopefully have some 2" compression drivers with some even bigger mids.
  8. #53
    F3fiddy's Avatar
    F3fiddy is offline Junior Member
    Aug 2012
    Apopka,FL
    18's ftw!
  9. #54
    Sep 2006
    Tampa, FL
    7,694
    Got my doors today. Just need to paint the top piece and then install the speakers. They look beautiful. Everyone says big doors like this always look tacky. I think these look great. Will really pop with the black trim pieces, speaker grills, and tweets in it.
    A guy I know in Tampa did them. He has a shop named Trafficking Customs. If you ever need glasswork done in the area, he is definitely the way to go. Cant wait to get my rear doors done.
  10. #55
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Doors look good! What are you using for amplification? Active or passive? And what do you have planned for your substage?
  11. #56
    Sep 2006
    Tampa, FL
    7,694
    Right now it is passive. Even though I have a brand new Pioneer 4200BT in my dash, I think Im going to break down and get another 80PRS to go full active. Then it will be seeing a Stetsom 5k on the front doors most likely.
    It is getting a wall for 8 12s for bass. Just a small build at the C-pillar to leave room for a big mid/horn setup out back.
  12. #57
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Yeah active is definitely the way to go here. But you can't run 3 way plus subs with the 80PRS. You plan on running the 18's in the door on the same sub channel as the 12's in the wall?
    You have a brand/model in mind for the subs?
  13. #58
    Sep 2006
    Tampa, FL
    7,694
    They are 15s and 12s in the doors, but they play roughly the same frequencies, so they will be on the same output. I think if I can bandpass them from 80-100hz to 4-5khz I'd be good to go.
    As for subs, likely the cheap American Bass subs. Probably run them on some sort of 3k or a pair of 1500s of some type.
  14. #59
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Quote Originally Posted by galacticmonkey View Post
    Oh gotcha, yeah those woofers should be decent in that range. You can always play around with crossover settings anyway.
    How much room you giving up for the sub box? Maybe go with 6 15's in a large box to compensate for lack of power? It would be more cone area, plus less number of subs to divide power to. Just a thought.
  15. #60
    VWGolfMKVI's Avatar
    VWGolfMKVI is offline StarrMountainSoundNutHugr
    Oct 2005
    Minot, North Dakota, United States
    972
    2 Post(s)
    Those panels are SICK
    StarrMountainSound Nuthugger Team Member #1
+ Reply to Thread
  1. 2000 Ford Excursion
    By bigmarv89 in forum Wiring, Electrical and Installation Help
    Last Post: 06-28-2007, 10:16 AM
  2. junkyard dog ford excursion
    By 60_cent in forum General Discussion
    Last Post: 03-31-2007, 09:57 PM
  3. 01 ford excursion dvd issues
    By KRD in forum Head Units
    Last Post: 10-17-2006, 05:29 PM
  4. '06 Ford 500 Build Log
    By Loud3 in forum Car Interior/Exterior Enhancements
    Last Post: 05-20-2006, 02:50 PM
  5. Ford Excursion sub placement
    By stiverp in forum Enclosure Design & Construction Help
    Last Post: 03-17-2005, 12:29 AM
