+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 47
Reload Thread: Honda Civic SQ Build
  1. #16
    itsblown's Avatar
    itsblown is offline why is there smoke?
    Sep 2011
    Toledo OH
    1,114
    15 Post(s)
    Re: Honda Civic SQ Build
    Quote Originally Posted by vISUALHype View Post
    It would be nice to own an R8, but they get an estimated like 12mpg.
    Because that matters after you purchase a super impractical $100,000 car
    Good luck on the doors and speakers not hitting Im having issues with it in my ride
  2. #17
    etm34's Avatar
    etm34 is offline CarAudio.com Elite
    Jan 2011
    Kentucky
    501
    Day 5: Not working on anything today, but got my free alpha damp today, cant wait to install this stuff but i can't decide if i want to cover both doors fully or cover the outside sheet metal on the doors and cover the trunk lid/package tray/trunk itself.... hmm wait until the sub is installed and see what starts rattle-ling.....????
    System: Front Stage: Diamond Audio Hex s600s Active on Treo 75.4
    Sub Stage: 2 10in Dayton Ho's on BA GT-2300
    Head Unit: Pioneer deh 80-prs
  3. #18
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    Day 5 continued:
    ok i decided to pull the back of the car out and to start prepping to run my wires tomorrow or saturday, found some more blaupunkt speakers in the back.
    The floor has zero sound deadening on it, i dont know if i should stick some on it or try to find some cheap mass loaded vinyl or something to try to keep out some road noise, its bad in the back, give me some suggestions if you have any please!
    These spots have some huge holes in them that im thinking need to be filled with some expanding foam or something along that line, because it is next to the wheel well and there is lots of noise through these areas, any ideas on how to stop the noise coming through the big hole in the sheet metal???
  4. #19
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    day 6/7:
    removed almost everthing from the car, running wires the next couple of days, i'll probably run 4 speaker wires to the front for if i go active in the future heres what ive done so far
    got this in yesterday, i was pretty happy to see it but then sad when i realized it had two 4ga inputs instead of one 1/0 ga, so now i guess ill have to order a new distribution block and more freaking wire, the expenses keep getting to be more and more.
  5. #20
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    Day 8/9/10:
    welp i finally started to get a little overwhelmed with what i was doing the past few days, there is just so much stuff i still have to do!!
    I tried to make a custom plexiglass insert for my bottom insert tray, that didnt work, plexiglass is just too difficult to cut straight, and it cracked so i got pissed and threw it on the ground!
    routed the rca cables today and worked on some speaker adapters, going to run just midbass in the back
    did this to find the centers
  6. #21
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    Its been awhile since ive updated this due to a lack of interest and comments on it, i thought i would just keep updating it to have as a log for myself and to show others what could be done with the same car.
    While i was away i got some ID oems for midbass ran those for awhile and then just took them out and decided to run active instead. Im now running active on diamond audio hex s600's on a treo 75.4. And i got a pioneer deh 80prs
    Old wheel well cover that will not hold a box up
    New one that i will cover with carpet and use as my base made of 1/2in birch
    Doors were deadened and i am about to create a sheet metal cover for the holes
    Tweeters im still pondering on how to mount them because they are so big
    Back of car is completely deadened
    Now i am going to cover up the holes as soon as i can find some butyl around here
  7. #22
    Flex68's Avatar
    Flex68 is offline dilligaf
    Jan 2012
    The Backroads
    1,613
    21 Post(s)
    Nice build log. Thanks for sharing.
    You are planning to use some CCF as a 'decoupler' on the sheet metal, and attach with more than just butyl, yes?
    Quote Originally Posted by Spider Monkey View Post
    Romney will [fornicate] me less than Obama already has and WAY less than what Obama has planned.
    Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
    HU:Eclipse CD7200 MkII
    Subs: Fack Skar Audio
    Front comps: HAT Clarus C61-2 off Sony ES 7547
    Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
    Damping: 60mil FG panels over holes, full worx from SDS
  8. #23
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    Quote Originally Posted by Flex68 View Post
    I can't decide honestly. I don't know if the butyl will work as a decoupler or not. Will be deadening them with mlv and cld. I will be using sheet metal screws for attaching them and the butyl layer between the sheet metal.
  9. #24
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,095
    351 Post(s)
    Quote Originally Posted by etm34 View Post
    Day 4: Got the other door done, my order from PE came, took one day for my order to get here!!!
    And while working today at my tennis club these roll up, our club goes hard!!! Yeah thats my civic next to an R8
    Makes me miss my NSX
  10. #25
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    I would miss it too....
    So I'm more productive at night so I covered my wheel well cover today
    Looks pretty good in the car. Doesn't match exactly but after my box is done if I have other material I may make it match. I'm going to create some solution to the 4 spots that don't have carpet so that they will be covered.
    There were some holes in the trunk for some tabs for the old cover so I utilized these and tapped them and they are now to hold it in place and is an added security feature if someone decided to take my stuff since everything will be mounted to this board. 4 hex bolts hold it in place and I made them so that they sink into the board so they don't catch on anything.
  11. #26
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,823
    72 Post(s)
    Im getting ready to start the build in my honda with S600s as well...
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  12. #27
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    Quote Originally Posted by Bettr n' Revrse View Post
    Let me know how you are going to mount the tweeters. I kinda want to make swivel mounts but I don't have enough time before college. The actual mounts, well the right one, are on axis.
  13. #28
    Dec 2010
    Grand Junction, CO
    16,823
    72 Post(s)
    I'm trying to find some sort of swivel myself that I can use with PVC caps for cups...
    Western Rep.
  14. #29
    etm34's Avatar
    Jan 2011
    Kentucky
    501
    Are you just mounting the tweeter in the pvc? Or are you using the mounting hardware and the pvc? also how do you think you will get the tweeter to stay in place? i thought of using caulk on mine, but im scared the ammonia released will hurt the tweeter.
  15. #30
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,118
    28
    127 Post(s)
    i have two NPT swivel air tool fittings to use as tweeter mounts, but they aren't tight enough to support the weight...
    other members added o-rings or other materials to increase friction and allow for fucntional use, explained here: Tweeter Spheres - pics and examples
    for the CDT tweeters I used a continuous ring of foam weatherstripping on the inside of the PVC cap to friction fit the tweeter. it holds it well and you don't see any mounting hardware.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
+ Reply to Thread
  1. jaeguerra909's 97 honda civic new build for 2012
    By jaeguerra909 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-24-2012, 06:11 PM
  2. Honda civic trunk build
    By jcadams in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-03-2009, 12:03 PM
  3. UNDERGROUND_BUMS 06 Honda Civic Sedan build Log ( vid)
    By UNDERGROUND_BUM in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-09-2009, 07:52 AM
  4. Honda Civic Trunk Build
    By R/T Pimp in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 12-21-2008, 01:49 PM
  5. 06 Honda Civic Build (Lots of Pics)
    By Mike465 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 09-15-2008, 05:23 PM
