Make the hole a little bigger on your first piece and use it as a flush mount. Cover your hole you have now with that flush mount piece, and put the sub away from the port mouth inside the box.
traded-pickup1, power-fanatic07, fbi90909
sold to-superspank, dumple, JoeRa22, sub-FATHER, TrlcKed_OuT, rosrock, dcole18, RaiN, BassAddictJ, tommyk90, MANTI5, Micah_Jones, mrflamboynt, g6ryder, rebelfromva, n8skow
Well this is the way that was recommended to me for an extended cab pickup. Port firing to the passenger side and sub forward as far to the driver side as possible.
Here is the discussion thread on the box design. Tell me if I got this right please!!
Your son probably went to bed feeling as though he had the coolest pops, ever.....man, that's worth all the enclosures in the world!
Good job, Nebraska
Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
HU:Eclipse CD7200 MkII
Subs: Fack Skar Audio
Front comps: HAT Clarus C61-2 off Sony ES 7547
Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
Damping: 60mil FG panels over holes, full worx from SDS
ahhhhh i shouldhave went over a little bit more than i did.... you should be fine with that but it will unload pretty easily. thats the only issue with it. had i been thinking i wouldhave had you do a zig zag port near the pas. side.
No it is firing into the port wall, or at least about 2/3rds of it. I think the entire motor was in front of the port wall, if that makes sense. I was more worried about the fact there is only about 3" of clearance btw the sub and the port wall. Maybe I need to take a pic from a better angle.
Wh1teboy- did you use one of the computer program to design that box? the reas im asking is because i want to build something similar but i dont want to do the math to figure out the interior volume if the box.
Bookmarks
