Results 1 to 9 of 9
Reload Thread: looking for info 2010-2011 Silverado/Seirra
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,854
    104 Post(s)
    I am looking for info on how to's on the newer trucks..Panel removal,wiring routes,OEM integration
    etc....Cant find much on the new stuff but its that time of year again and I want to reload my new truck with some of my old gear
    Ignatowski's Avatar
    Mar 2005
    Dirty South
    6,854
    104 Post(s)
    Re: looking for info 2010-2011 Silverado/Seirra
    DAYUUM........no of you punks own new trucks?
    winkychevelle's Avatar
    winkychevelle is online now CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    most everything is pop together like all the older trucks. not much has changed except the doors or held on by pop zerts and not the slide-on panel like the older 99-07 trucks. just look for screws before you yank on stuff. and keep a 7mm and t15 drill bit handy as you will need it
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
    snyderd758's Avatar
    snyderd758 is offline Senior VIP Member
    Feb 2011
    emigrant gap, ca
    457
    1 Post(s)
    118 Post(s)
    Crew cab, ext cab or regular cab? i have an 09 crew cab. I have replaced stock door speakers ran power wire for my amps done the big 3 also installed aftermarket headunit.Im getting ready to lift the back seat and build a custom vented box for 2-10" fi ssd's as well as upgrade to 250a altenator. This is probably one of the easier vehicles i have installed an aftermarket stereo in. The most frustrating things are finding space for amps and subs. Let me know if i can help.
    Ignatowski's Avatar
    Mar 2005
    Dirty South
    6,854
    104 Post(s)
    Quote Originally Posted by snyderd758 View Post
    my last truck . a 2002 I did a seat lift w a ported 12........I loved it....Ill never do slims or shallows,they all plain **** so If you make some seat lifts bars holla at me ill take a set..Usually 2x2 steel works best ......Amps mount on the back wall
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    @Trancer ...
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
    Trancer's Avatar
    Trancer is offline CarAudio.com Veteran
    Aug 2002
    Allen, Texas
    32
    2,707
    16 Post(s)
    Quote Originally Posted by Bettr n' Revrse View Post
    @Trancer ...
    It is I Better is saying I know these trucks extremely well. I have done plenty to my 08 crew cab Sierra, subthump ultra deep dual sealed 12" box. Ran RE SeE12Msomps in the 12's till decided to go louder, so that sub set up is gone. I have ran 3 amps, now im down to two now. Big 3 upgrade, inatalled the kicker PDK01 0/1awg amp kit, Installed 6.5" woofer and 1 7/8 tweeter Focal component set. I had to run 3/4" MDF speaker ring adapters to clear the window. I believe it was fo the front, but you could be ok as I am running Focal Utopia comps in the front and Focal K2P. Comps in the rear. Now that I think about it, due to the rear foor being smaller than your front door and your front window and window track location. Depending on your midbass driver's mounting depth, you may have to make your own or buy a pair. I have an extra pair in my garage if you need them. I ran my front tweeters in the factory APiller location. For the rear comps, I flush mounted my tweeterd in my foor just above the mids.
    I kept my factory cd player on purpodr. An aftermarket deck would just look tacky in our trucks, so im running a Digital Sound zp
    Processor, the Rockford Fosgate 3Sixty.1. They made a .2 also, but both aren't made anymore so you'd have to buy one used. If you aare keeping your OEM cd player, then grt a Digital Sound Processor. Don't get s cheap LOC. Its cheap for a reason. This will be the source of your audio. I plan on upgrading my zozezm cd player to a full 7.1" Pioneer AVIC-Z130BT. Its their flagship GPS/DVD model and retails at $1499.99. This way here, still looks stock woth the optional overpriced Navigation screen, but the Z130BT will be 10 x's better than the OEM Navi @ hlf the price.
    I raised my rear seats 3 inches with T6 aluminum square tubing. Im currently building a ported box for 4 Sundown Audio SA-8 V2's which will ne here middle next week. Im getting roughly 3.7 cu ft gross just by building a full wood box. I, will be working on a fiberglass boc after this one is done. I get impatient so if I have bSs in my truck, I can really take my time and get creative and make it look really good.
    I swear up and down and I am a true believer in Audiopipe amps.
    Taking off the trim is easy. Start with the flat long door sills. Work your way around. There are 3 bolts, 7mm I think? In the rear door. Pop off the plate behind the pull handle, there are two of your 3 bolts in there. Right below that, behind the door handle, pop that off. There is your 3rd bolt. Pop off the
    window up and down switch block. Its about 8 inches long or so. Unplug it. Start from the bottom and once you get one good pull off, the rest of the rest oof the door comes off easy. I wrote all of this on my phone. I still have alot of advice to give but my $1700 laptop took a crap on me so its getting sent to Asus today maybe. Advice on tips and tricks, exhaus5, etc...
    Go in the build log section and search for my thread. I need to update it, but its harder to do withou my laptop.
    07 black Yamaha V-Star FI 1300. 08 GMC Sierra QC SLE2 Texas Edition
    Rockford Fosgate 3Sixty.1, Focal Utopia Components, Focal K2P Components with Digital Designs T1 Tweeters, Audiopipe AQX-360.4, Audiopipe 3001D
    References: 21: DesertHeat, Ravens9322, Netherland24, Insomniac119, killahbean, Charlieee, Dustin19, djman37, dirthog, JayRich, JimJ, RassyMX, Slayerx, smgreen20, lyttleviet, RAM_Designs, Gingerbreadman, DarkHart, cwill5, Imtjnotu, Bettr n' Revrse
    Quote Originally Posted by GeekSquad View Post
    Make the port as large and as round as possible. For example, a square port is more round than a rectangular one; an octogonal port is more round than a square port. Also, keep the number of ports down to one, if possible.
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    There you go I did my part in this thread
  9. Likes Trancer liked this post
  10. #9
    Trancer's Avatar
    Aug 2002
    Allen, Texas
    32
    2,707
    16 Post(s)
    Indeed you did! Im beginning to build up my threads of useful knowledge, experiences, and answers again. Its been a while. I need to get my laptop back so I csn update my build log and add another build log of a customers car I did a couple weekends ago on my birthday weekend. He drove 250 miles for me to install it. I had him help since he wanted to learn so I had to stop every 10 minutes to nelp him, show him how to do something, redo/correct his mistakes,etc... or I would have had it done in two days instead of 4 days. Didn't help the first 2 days we were running around all over north Dallas getting stuff like an amplifier wiring kit that he said he already had, but it was cheapo junk and 8 guage power and ground and among other things like s "2000 watt amp" that actually only put out 400wrms at 2 ohm + more.
  1. Looking for info, good 12" woofer, under $300.
    By chambiec1 in forum Subwoofers
    Last Post: 08-31-2007, 11:35 AM
  2. looking for info on company that makes eq's
    By hawaiian5 in forum Head Units
    Last Post: 06-04-2007, 03:11 AM
  3. looking for info on a alpine 7418 cd radio?
    By jackchan in forum General Discussion
    Last Post: 10-05-2005, 09:20 PM
  4. Looking for info on eclipse 3322 and 3640
    By justsayk in forum Amplifiers
    Last Post: 01-21-2005, 02:09 PM
  5. Looking for Info
    By Corwin in forum Subwoofers
    Last Post: 10-05-2002, 09:47 AM
