Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: tri-amp rack monday build *pics inside*
  1. #16
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,105
    25 Post(s)
    2100 Post(s)
    Re: tri-amp rack monday build *pics inside*
    Quote Originally Posted by Dirtrider4eva View Post
    Yessir was my great grand fathers. Iirc it's a 67. Cast iron and all that good ish, then painted up to like a construction machine. Had the engine replace with a bigger 11hp motor
    ..Id kinda like to take her around the block,Very nice man.Very nice..by by the way..nice work on the rack.Is that Zed amp a 2100??800??2150??
  2. #17
    Dirtrider4eva's Avatar
    Dirtrider4eva is offline √\_The CaUsE__
    Mar 2011
    Milwaukee, WI
    4,292
    841 Post(s)
    Quote Originally Posted by audiobaun View Post
    It's fun. Use it to plow snow even. The zed is a usx600f. And thanks again
    welcome to
    Where b-stock is the new a-stock
    TEAM WEST
  3. #18
    audiobaun's Avatar
    Jun 2011
    Tx
    9,105
    25 Post(s)
    2100 Post(s)
    Looks bigger in the pick..Ive got an 800 on the way from Spooney.You know if that amp will do 2ohms bridged??I have an Autotek BTS Bass Thrust 7150 that is 4ohms mono stable, is all I could find on the specs, but have been running @2ohms for over 5yrs
  4. Dislikes Turbopit disliked this post
  5. #19
    Mar 2011
    Milwaukee, WI
    4,292
    841 Post(s)
    I have no clue man.. I've Never heard someone doing it. I wouldn't, it gets a little warm at 3.3 a channel, so I wouldn't recommend
    welcome to
    TEAM WEST
  6. #20
    audiobaun's Avatar
    Jun 2011
    Tx
    9,105
    25 Post(s)
    2100 Post(s)
    Well,i guess i better not then..i have a pair of 8ohm 10in daytons or my kicker l5 i plan on putting it on in my next used ride
  7. #21
    focused313's Avatar
    focused313 is offline Learning With Every Post
    Mar 2004
    Michigan
    267
    12 Post(s)
    Quote Originally Posted by VWBobby View Post
    Not to sound like a jerk, just a little critique....
    Mount both amps facing the same direction and drill holes to run your cables through the mounting board. That way you can strap your amps, etc and still have them close together and facing the right direction. It'll also make a cleaner look. A pack of grommets can be bought at Harbor Freight/ebay for cheap if you wanna make it look really clean.
    exactly what i was going to suggest, well, just tidying up the wires. good advice on the drilling holes thing.
    Had JL 12w3's...replaced with Type R's...and couldn't be happier
    God Is Love.
    Don't , I'm Just Here To Learn.
  1. amp rack & mini rant.... **pics **
    By skeptikal in forum Enclosure Design & Construction Help
    Last Post: 05-24-2006, 05:55 PM
  2. My sub enclosure/amp rack trunk build (30+ pics)
    By lubetek in forum Enclosure Design & Construction Help
    Last Post: 02-10-2006, 08:52 PM
  3. Amp rack [almost] finished *pics*
    By takeabao in forum General Discussion
    Last Post: 01-16-2006, 01:02 PM
  4. New old school amp rack lots -o- pics
    By ax600 in forum Amplifiers
    Last Post: 08-29-2005, 08:48 PM
  5. RE SE 10 Box Building... Pics Inside
    By Slody4Futbol in forum Enclosure Design & Construction Help
    Last Post: 02-23-2005, 01:16 PM
