Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 91 to 104 of 104
Reload Thread: Joseph's SQ Build Log
  1. #91
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: Joseph's SQ Build Log
    i made my first spheres using a hole saw, which leaves the center piece. then i used a paddle bit to remove the middle. this usually resulted in some material left, so i used a dremel with a cutting disc. finally, i used a dremel with a sanding wheel to perfect the opening diameter. then i had to fill the hole in the rear of the sphere created by the pilot bit on the hole saw. i used a wood plug which was then sanded smooth.
    then i bought a forstner bit set. so yea, fvck the old way.
    i use double-sided foam tape in the vice to increase grip while allowing for less clamping force. i don't have issues with the vice squeezing the sphere this way.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  2. #92
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    or i can make the spheres for you. i do that. i have a price for just the spheres made per your dimensions, or you can mail me tweeters and i'll mount them for you.
    a vice is a requirement in my opinion. spheres are easy with proper tools. which is why i can fabricate and mount in about 3 hours total effort. i charge $20/hr. + materials + shipping. so price is really just based on time spent, not-to-exceed of course. i'm not a con.
  3. Likes splwj47 liked this post
  4. #93
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    Faster/easier to glass them then that method lol.
  5. #94
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    no. start to finish is still under 1 hour to make the cylindrical hole, another hour to get the mounting stems positioned secured, another hour for painting/sanding. yes, i had to use several tools over several steps, but the process was still fast. glassing will take you much, much longer than that and cost more. and the end finish is less, trying to glass a perfectly smooth surface requires skill and patience. plus, you don't get the same diffraction benefits with traditional glassed pods.
    these spheres are still the easiest tweeter mount i've done.
  6. #95
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    I don't find glass work to be that hard at all to be honest.
  7. #96
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    i agree glass is fairly easy, but very time consuming with having to wait for curing of the various layers.
    i have some paper mache eggs that i will use for the shell of pods for tweeters or small mid/full range drivers. those will be glassed.
    glassing a perfect sphere is not an easy task. i've seen several attempts. even people using balloons as the form.
  8. #97
    Joseph7195's Avatar
    Joseph7195 is offline Walkin Tall
    May 2011
    Saltillo, Mississippi, United States
    38
    1,467
    385 Post(s)
    I think fiberglass would be an option if I had knowledge of fiberglassing. It's one of those trades I haven't had the pleasure to learn yet. I am still trying to get "upholstery" figured out, though it's seems to be harder than I first thought.
    I found a set of forstner bits, and it includes a 1" bit, which is about what I need. I don't want to make the hole to big to begin with, so I am gonna make it a little smaller and then just use a small "Dremel" like tool and slowly sand it out to the correct size. I hate to say it, but it seems the only way to make these things (and be presentable) would be with a forstner bit. Though I think a hole saw could be an option, though I don't have one to try out.. I am gonna make some more attempts tomorrow, I am really set on learning on making these things, and hopefully this log will help others too!
    Quote Originally Posted by adulbrich View Post
    We don't have food stamps on the east side. Its called a link card. Man, the grocery is packed on the first of da month. I shit you not, a homie got stabbed over a can of soup.
  9. #98
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Besides the kit, you can buy individual bits. But in the larger sizes, two large bits is the price of the kit.
    And yes, they are the way to make these things.
  10. Thanks Joseph7195 thanked for this post
  11. #99
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,633
    1275 Post(s)
    fiberglassing a sphere ***** ***.
    I am protesting Skar by giving them added exposure in my signature.
  12. #100
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    Quote Originally Posted by Joseph7195 View Post
    I got a couple more pics! Enjoy!
    I loooove how you ran those wires. I can't believe I never thought of that. And I really wish I would have thought of it before I hacked up the wiring harness in my door.
    Also, the amps and the amp rack look incredible and gorgeous and terrific. Awesome job so far!
    Also, I might have to rent that bit off of you when I do my spheres.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  13. Likes Joseph7195 liked this post
  14. #101
    Joseph7195's Avatar
    May 2011
    38
    1,467
    385 Post(s)
    Well, I have been resurrecting my dash. I think all Dodge's like mine have a serious problem with the dash cracking, so I thought of a way to use up some left over denim material I used for my amp rack, and used it for my dash! I hope you like!
    This is how the dash started out. In a million pieces!
    I used a quick setting epoxy to bind all the pieces back together
    It's not pretty, hence I was going to have to cover it
  15. #102
    Joseph7195's Avatar
    May 2011
    38
    1,467
    385 Post(s)
    I am going to add the tweeter spheres to it before I put it back into the truck, I have a feeling once I get it back in, it won't come out without it breaking to a million pieces!
  16. #103
    Joseph7195's Avatar
    May 2011
    38
    1,467
    385 Post(s)
    Here are some pics of the tweeter spheres. I need some help too.
    I need help with finishing the front of the spheres
    I was gonna put a metal grill over the front, but I didn't like how it looked. I need some ideas of things I could use to encircle the outside of the tweeter that would also be inside the diameter of the sphere. Any ideas would be greatly appreciated!!!
  17. #104
    Joseph7195's Avatar
    May 2011
    38
    1,467
    385 Post(s)
    Bump, because I can.
  1. 2005 Scion tC SQ Hertz Audison Pioneer Build Log
    By keep_hope_alive in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 05-17-2013, 04:20 PM
  2. 1995 Dakar Yellow M3 Coupe SQ Install Build Log
    By MrFriskles in forum General Discussion
    Last Post: 05-02-2011, 09:13 PM
  3. FierceTimbo's SQ Build Log
    By Fiercetimbo17 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-08-2009, 03:18 PM
  4. New sq system build log!! Pics
    By asaner85 in forum General Discussion
    Last Post: 02-29-2008, 09:28 PM
  5. LS2's SQ Build Log *56k beware*
    By ls2poweredgoat in forum General Discussion
    Last Post: 01-07-2008, 06:56 PM
