+ Reply to Thread
Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 46 to 60 of 111
Reload Thread: SQL Scion tC
  1. #46
    DDtC's Avatar
    DDtC is offline Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by keep_hope_alive View Post
    Did you see what I did to a scion tC for seals/deadening? The build log is in here also.
    Yes I have,, a few times. Im still not sure if I want to bump the 6.5s up to the Mille before I finish the pods. Im not sure how they will sound with the HE tweeters but im guessing good
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
  2. Dislikes KJThaDon disliked this post
  3. #47
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,031
    28
    124 Post(s)
    Re: SQL Scion tC
    No, I wasn't referring to the Mille, your speakers are just fine.
    I am referring to the work I did in the rear corner and rear quarter. Stupid lossy, that entire rear quarter. We put in a lot of work to eliminate that highly resonant part of the car. Any tC owner should do the same.
    That tC is so well sealed, if you try to shut both doors at once, one pops back. It's cool.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  4. Likes DDtC liked this post
  5. #48
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    I know that.. I put 2 layers of deadner on the rear quarters. Still flexes.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  6. Dislikes KJThaDon disliked this post
  7. #49
    May 2007
    Quad Cities, IL
    5,031
    28
    124 Post(s)
    Re: SQL Scion tC
    We did more than layers on the outside, we did several layers built up on opencell foam. The result is zero exterior flex. Since the interior layer is decoupled from the exterior.
    Someone wanting SPL would want something similar, but not foam that flexes. The interior layer should be rigid. I would opt for several layers of fiberglass on top of the foam backing if I wanted SPL.
  8. #50
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    I like the sound and range of this box but i know this set up has a 50 in it, or at least close to it. I dont think this car likes subs up so Buck is drawing something up with subs and port back with about 18sq inches of port per cube. It may not be as accurate but we will see.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  9. #51
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    No more electrical issues. Those XS fittings are garbage. SQL Scion tC-photo.jpg
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  10. #52
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    Screw it.. If I want to enter a SQ comp I'll just turn the subs off and let the 8s play down. Its time to get loud. 3.1 internal, 18 square inches of port. Let them eat! Thanks for the design Buck, I'll let you know how it turned out late next week.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  11. #53
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    I see what your talking about. I'm going to take your advice on this.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  12. #54
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Re: SQL Scion tC
    I would add more bracing to the box in the form of 2 dowels to connect the top piece to the bottom piece. You can never have too much bracing imo. If you want SPL you need rigidity, many people don't realize this.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  13. #55
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,671
    17 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by DCtC View Post
    Attachment 26532685
    if you do that you will lose, you still need subsonic reproduction in sq comps.
    I am protesting Skar by giving them added exposure in my signature.
  14. #56
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,436
    6 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by wenn_du_weinst View Post
    I think at this point he's more interested in getting loud.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
  15. Thanks DDtC thanked for this post
  16. #57
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by sacsking916 View Post
    Yep. I didn't go this far in the hole to not use this stuff for what it's meant for.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  17. #58
    Apr 2009
    6,436
    6 Post(s)
    Re: SQL Scion tC
    I heard that lol. Got any vids of it with the old box? Did u get a chance to meter it?
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
  18. #59
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,020
    44 Post(s)
    Re: SQL Scion tC
    No vids
    Metered lower then I was looking for. It was a music box and it did that well. I asked for that and I got it so I cant complain. It would really drop though. I had a feeling it would meter good according to the graph but that peak didnt happen in the car.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  19. #60
    Apr 2009
    6,436
    6 Post(s)
    Re: SQL Scion tC
    Whatd it meter at? The downfall with the graphs is that they change so much in the car. Wiah there was a way outside of keep testing, that a program knew the car frequencies, that way the graphs will be spot on. If only it was a perfext world lol
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
+ Reply to Thread
  1. Replies: 179
    Last Post: 09-01-2005, 08:13 AM
  2. Replies: 10
    Last Post: 06-06-2005, 05:23 PM
  3. 2005 scion tc fiberglassing w/ pics...in progress
    By 8inw7 in forum Enclosure Design & Construction Help
    Last Post: 05-12-2005, 12:43 AM
  4. Planning a system out for new car, Scion TC
    By Unreal in forum General Discussion
    Last Post: 07-05-2004, 06:01 PM
