+ Reply to Thread
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 31 to 45 of 111
Reload Thread: SQL Scion tC
  1. #31
    DDtC's Avatar
    DDtC is offline Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by kushy_dreams View Post
    What are the specs on the box? Thats an odd design, how the port fires into a large chamber like a 6th order but the woofer isnt inside the box, who designed it? I have seen about the same cone area on half the power in a similar sized vehicle do 1db less from high 20s to mid 40s. I suspect that the box is holding you back from more output.
    Surreal designed it. I wanted a music box and thats what I got. Its 1 db flat from 26-60hz. It feels A LOT louder then it metered. Not peaky at all, the SQ is top notch. The "6th order" is designed with the back glass in mind. If I open the hatch and turn it up they bottom out. Its basically the loading surface. I could get more with a standard slot with it moved into the cabin more but I'm going to compete in SQ also so i dint want peaky till i can add a good processor/EQ to it to tone the peak down.
    I did find another peak after i got home using a phone app so i dont know if its anywhere close to ligit. It was 3db higher at 69hz. Running through the tones at a high enough volume to register the change.
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
  2. #32
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by hispls View Post
    What?
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  3. #33
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by DCtC View Post
    Ah ok, that makes sense, I thought you were just chasing after a high #, didn't you know were going after sq and flat response.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  4. #34
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    I wanted a bit of both. A flat 46 is pretty **** loud though. Numbers are just for fun, I want a real SQL daily setup. I think i got it.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  5. #35
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,347
    74 Post(s)
    Re: SQL Scion tC
    A flat 46 with the SQ you're aiming for would be epic goat sex
  6. #36
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by princ3cmo View Post
    It really does sound amazing man. So crisp all the way across the 8 octaves. I know when the doors get finished it will be even better.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  7. #37
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,705
    15
    85 Post(s)
    Re: SQL Scion tC
    What?
    146 with 5K on tap... I guess if you can do it at 25hz that's pretty cool.
  8. #38
    keep_hope_alive's Avatar
    keep_hope_alive is online now Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,014
    28
    124 Post(s)
    Re: SQL Scion tC
    Looks great, love how well the fiberglass pod molds with the door.
    I am disappointed they share airspace, that mostly defeats the benefit of having separate drivers. That 8" will manhandle the 6.5". WHen the 8" moves out it will pull the 6.5" in. The 6.5" would have been better in the kick. Maybe next time.
    Great work though. The box is cool as hell. I like the amp mounts.
    I am surprised at how much you fit on that battery. Well done.
    Maybe a CAI would give you more room for mounting fuse holders. .
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  9. #39
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    It was a 45. Something at 26 if that matters.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  10. #40
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    Quote Originally Posted by keep_hope_alive View Post
    Looks great, love how well the fiberglass pod molds with the door.o
    the 6.5s have baffles.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  11. #41
    May 2007
    Quad Cities, IL
    5,014
    28
    124 Post(s)
    Re: SQL Scion tC
    they share airspace or not? if the 6.5's have a separate fiberglass sealed enclosure then neglect my comment.
  12. #42
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    They are going to but until I can get some more funds they just have those cheap foam baffles.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  13. #43
    May 2007
    Quad Cities, IL
    5,014
    28
    124 Post(s)
    Re: SQL Scion tC
    ah, the XTC baffles. they don't count. they move. they are intended to be opened up in the bottom/rear.
    something is better than nothing. with a build this nice, it's hard to find room for improvement.
  14. Thanks DDtC thanked for this post
  15. #44
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,877
    43 Post(s)
    Re: SQL Scion tC
    Im having a ton of mid bass cancelization right know anyway cause I just have power going to them with the doors cut open. I cant start them over till the end of next month and I had to have sound till then. But man are they loud, the 8s are really starting to move so I cant imagine what its going to sound like sealed.
    I have come to the conculsion this car just cant get loud though. My friend has 4 DD 3512s on two M3s in his and he pulled a 52. I ended up getting a 47.2 today with charged batteries. I sealed up some of the holes in the hatch where I took the panels off also so I think that helped a little.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  16. #45
    May 2007
    Quad Cities, IL
    5,014
    28
    124 Post(s)
    Re: SQL Scion tC
    Did you see what I did to a scion tC for seals/deadening? The build log is in here also.
+ Reply to Thread
  1. Replies: 179
    Last Post: 09-01-2005, 08:13 AM
  2. Replies: 10
    Last Post: 06-06-2005, 05:23 PM
  3. 2005 scion tc fiberglassing w/ pics...in progress
    By 8inw7 in forum Enclosure Design & Construction Help
    Last Post: 05-12-2005, 12:43 AM
  4. Planning a system out for new car, Scion TC
    By Unreal in forum General Discussion
    Last Post: 07-05-2004, 06:01 PM
