Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: This is my '89 Volvo Wagon, I'm installing an aftermarket stereo
  1. #16
    Joe89's Avatar
    Joe89 is offline Senior VIP Member
    Dec 2007
    Northern California
    267
    Re: This is my '89 Volvo Wagon, I'm installing an aftermarket stereo
    Didn't get as much done this weekend as I had hoped... Couldn't work on Easter and removing the headliner took much longer than anticipated. I ended up removing the front carpet, some more trim, the headliner, and then scraping away at the stock deadening adhesive for an hour or so. Then, my friend's angle grinder could not fit into the space to cut away the 3 roof braces, so I had to use the Dremel.
    Image Above: Roof ready for MDF treatment, I will attach 3/4" MDF with Loctite PL Premium
    This is where I cut away the roof braces. They will all be mig welded back into place once the MDF is affixed to the roof.
    Finished the weekend's work with the application of some Alphadamp to some rear sections of the vehicle, including the rear passenger side quarter panel. I will do a comparison video of the dampening ability of 100% coverage of Dynamat extreme to the ~40% coverage of the Alphadamp next weekend.
  2. #17
    MECHMAN's Avatar
    MECHMAN is offline Supporting Vendor MECHMAN is a Supporting Member of the forum!
    MECHMAN is a Supporting Vendor of the forum!
    Jul 2008
    Knoxville, TN
    364
    16 Post(s)
    Nice progress.
    Builder of alternators.
    www.mechman.com
    865-522-6166
    1-800-MECHMAN
  3. #18
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    33
    2,825
    11 Post(s)
    um as your cutting out parts of your cars bracing and gluing mdf overhead keep in mind that in a small wreck your f*cked as that car is going to crumble around you. I would think more about bracing and securing before deadening to the point that your daily maybe your coffin.
  4. #19
    Joe89's Avatar
    Dec 2007
    Northern California
    267
    Quote Originally Posted by goingdef View Post
    Quote Originally Posted by Joe89
    They will be welded back into place, don't worry. There was a gap between where the braces were and the roof. The funny thing is there was adhesive on the bars, and marks telling me they had at one point touched the roof, but there was about a 3/4" gap between the braces and the roof when I took off the headliner. If you look closely there are 3 areas going horizontally across the roof that have residue from the bonding agent Volvo used, but they were separated at some point in the past 23 years. The car will likely be safer once those are pressed against the now thicker roof if that was the original design. It is a Volvo... these cars are very safe.
