Page 4 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 46 to 60 of 266
Reload Thread: Skar audio VVX15 8cft box buildness
  1. #46
    VisceralSound's Avatar
    VisceralSound is offline CarAudio.com Elite
    Oct 2011
    Rochester, MN
    1,604
    20 Post(s)
    Re: Skar audio VVX15 8cft box buildness
    I'll give the 300watts a shot once I get it squared away with a DMM etc etc.
    box is pretty cool though :{|
    References: BigSix,
    This industry is about innovation and setting your own path
  2. #47
    ddcmdb's Avatar
    ddcmdb is offline Member
    Jun 2011
    Edmond, Ok
    40
    Inside diameter measurements? And also after displacement??
  3. #48
    -01limited-'s Avatar
    -01limited- is offline Where are my 72 virgins?
    Oct 2010
    812 Indiana/409 Texas
    23
    3,973
    5 Post(s)
    Its not going to take much to get that sub moving at full excursion. Not much at all. Just dont want you to bottom it out horribly thinking you can throw 1600 watts to it and it just be ok.
    2001 Jeep Grand Cherokee Limited
    Mach 5 ixl 18.4
    7 cubes tuned to 34hz
    Hifonics Brutus 2k
    Knu Wires
    Quote Originally Posted by Bassin Buick View Post
    Why?? You still haven't learned to eat my balls in the WTEMB section.
  4. #49
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,823
    72 Post(s)
    Quote Originally Posted by vISUALHype View Post
    screw the DMM method thats kinda out the window with a box this big... Just set it by sight...
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  5. Likes g6ryder, IonRL205 liked this post
  6. #50
    chillin's Avatar
    chillin is offline CarAudio.com Elite
    Jan 2007
    Whistler, Canada
    1,802
    4 Post(s)
    Just looked over your measurements and assuming you used 3/4", you are just under 8 cubes before ports and sub dispacement, so that will help a little, but that box is still way too big.
    Children are the future… today belongs to me!
  7. #51
    May 2006
    Tennessee
    5,464
    37 Post(s)
    Quote Originally Posted by chillin View Post
    this^ after displacements its probably around 7cubes...which is still double of what you need.
    Refs- DiabolicBass, nismos14,IonSQL,massiveaudiocw,sxpimpin,sundownz,8 7gr, nissan,Louie68,Tips,Trell,integra88,Ellsworthz,bas ebalz13,lil98cabrio,woofercooker,pro-rabbit,Louisiana_CRX,MANTI5,eL_wEEnIe,bubbagumper6 ,jco1385,95saturn,ace_800,micah_jones,assassin1840 ,beat-down69,RAM_Designs,whitedragon551,KTMrida4life
  8. #52
    Dec 2010
    Grand Junction, CO
    16,823
    72 Post(s)
    Quote Originally Posted by Mitch86 View Post
    exactly so just add another and be done...
    Western Rep.
  9. #53
    Oct 2011
    Rochester, MN
    1,604
    20 Post(s)
    After calculating the wood+woofer displacement+port displacement, I'm still sitting at about 7.8-7.9cft.
    References: BigSix,
  10. #54
    May 2006
    Tennessee
    5,464
    37 Post(s)
    If these are external dimensions that you posted: 33" deep x 15" high x 34", it comes to 7.9 before sub or port displacement. What size ports are those and how long btw?
  11. #55
    Oct 2011
    Rochester, MN
    1,604
    20 Post(s)
    Its actually 18 high I forgot that the 15 was internal.
    8" diameter, and 25.25" long
    References: BigSix,
  12. #56
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    Proud to see someone actually building a proper sized box.
    Stupid Loud.
  13. Likes VisceralSound liked this post
    Dislikes madcad95, groundpound4200 disliked this post
  14. #57
    Oct 2011
    Rochester, MN
    1,604
    20 Post(s)
    Quote Originally Posted by wickedwitt View Post
    Atleast someone likes it :V
    References: BigSix,
  15. Thanks wickedwitt thanked for this post
  16. #58
    wickedwitt's Avatar
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    Yeah, don't listen to these guys. If you want it to slam like no one around, keep the size, keep it on RMS power, hit play and enjoy. If you end up getting enough power to run two, build another proper box and try to maintain that same size per sub. You'd be amazed at the results.
    Then again, just ask someone local like IonRL. I'm not loud, I wouldn't know what I'm talking about...
    Stupid Loud.
  17. Dislikes madcad95 disliked this post
  18. #59
    Oct 2011
    Rochester, MN
    1,604
    20 Post(s)
    Good man
    References: BigSix,
  19. #60
    Fi_'s Avatar
    Fi_
    Fi_ is offline King of Diamonds
    Nov 2011
    Fryeburg
    1,669
    6 Post(s)
    While I agree that the box seems rather large they perform rediculously if done right... Port area plays a BIG role on boxes this big. I'm thinking of doing 3.5-4ft^3 per 15" on my next build right now they're getting 3ft^3 each D:
    Also I wouldn't out more than 600w to that subwoofer in 8ft^3 I think people on the forums are assuming you'll do almost twice that as SKARS are known to take 1k+. Even with the smallest box possible for that subwoofer I wouldn't put more than 800w to it daily lol. I like SKAR's but they're no SA.
  1. Skar audio vvx-15 subwoofer box build
    By 321slapinbass in forum Enclosure Design & Construction Help
    Last Post: 02-08-2012, 07:12 PM
  2. (2) 12" SKAR Audio VVX-12D2 Box Build Help...
    By NissanKicker in forum Enclosure Design & Construction Help
    Last Post: 01-31-2012, 05:39 PM
  3. PV Audio's Carpeting/Box Build Technique Tutorial *56k on hiatus*
    By PV Audio in forum Enclosure Design & Construction Help
    Last Post: 12-16-2009, 09:20 PM
  4. 15" Beyond Audio Inhuman Box Build
    By PhatTonyDeMarco in forum Enclosure Design & Construction Help
    Last Post: 12-09-2005, 07:28 PM
  5. Box Building 2 15" Diamond Audio CM3s
    By colt325e in forum Enclosure Design & Construction Help
    Last Post: 02-26-2005, 02:03 AM
