+ Reply to Thread
Page 12 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 166 to 180 of 266
Reload Thread: Skar audio VVX15 8cft box buildness
  1. #166
    VisceralSound's Avatar
    VisceralSound is offline CarAudio.com Elite
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Re: Skar audio VVX15 8cft box buildness
    Quote Originally Posted by Chriszle View Post
    Do a few sine sweeps to find your peak with that setup. Once you get it narrowed down, burp individual frequencies.
    Should the sine sweeps be on full tilt?
    References: BigSix,
    This industry is about innovation and setting your own path
  2. #167
    Moble Enclosurs's Avatar
    Moble Enclosurs is offline Box Designer/Builder Moble Enclosurs is a Supporting Member of the forum!
    Moble Enclosurs is a Supporting Vendor of the forum!
    Jul 2011
    New London, Connecticut
    1,398
    34
    80 Post(s)
    Quote Originally Posted by plantinseeds View Post
    Got the chance to hear the box + sub in person... and I've got to say I am definitely impressed with how it sounds.
    Hits the lows perfectly and sounds very clean.
    Makes me want to upgrade to 2 VVX12's and a Skar1500 haha
    Hey, Im glad you got the chance to get a demo of it. I have been talking to Visualhype during the entire process and I am very glad he had the chance to finally get some info for you guys. Hopefully it will put some things into perspective for a few people on here.......
    As long as voltage is not exceeded, it will do just fine as it is.
    "You build for physics....you design for acoustics. Just because you can build a box, doesn't make you a designer....and vice versa."
  3. #168
    Jul 2011
    1,398
    34
    80 Post(s)
    Quote Originally Posted by vISUALHype View Post
    No, gradually work them up to the same voltage level as the limits of the design as it should be done. Sine sweeps and tones are usually a higher level recording than music records, so it may need to be lowered a bit on volume for those. Again, increase it gradually until peak voltage is hit. Anyone should be doing this, not just you. If you do sine signals on full tilt, you may end up distorting or damaging some things if it is not meant to handle it. Depends on the equipment and design all together.
  4. #169
    Jan 2012
    Rochester, MN
    519
    31 Post(s)
    Quote Originally Posted by Moble Enclosurs View Post
    BTW, the box for my two 12 inch Type R's you designed for me turned out great I messed up on a couple aspects of the build such as the port supports and the second layer of MDF on the top (because I didn't have enough room in my trunk for two layers) but I am super satisfied with how it turned out and how much better the lows sound vs. using the prefabricated box I had before. Unfortunately my amp fried so I will have to wait a bit longer to pick up a new one :/ Anyways thanks alot Jason for the design! I will definitely recommend you to everyone I know that is in need of a box/design.
  5. Thanks Moble Enclosurs thanked for this post
  6. #170
    Jul 2011
    1,398
    34
    80 Post(s)
    Thanks Jack! Glad you like it and thank you for your great communication during the process as well! Let me know if you ever have any questions in the future! Anthony, get a better video up here too! lol. j/k man. Thanks for the updates and everything you have done for me also!
  7. #171
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    No problem dood, im working on finding a legit recording device and the best song to demo every aspect of my box!
    References: BigSix,
  8. #172
    Jul 2011
    1,398
    34
    80 Post(s)
    Word lol
  9. #173
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Would truck bed liner help like "stiffen" up the box like a form of bracing (not fully using it as a brace) but if I sprayed it on the box would it make it more solid?
    References: BigSix,
  10. #174
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Not really...
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  11. #175
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Quote Originally Posted by Bettr n' Revrse View Post
    Not really...
    I was just wondering for the fact of when I have it on full tilt looking into the trunk I get an odd wood sound, but theres no air leaking, maybe I need to screw it in some more with more screws. Once I get the second if etc etc ill pole brace it between the woofers.
    References: BigSix,
  12. #176
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Just to kind of update, im going to be looking into getting some expanding foam or related to seal my trunk from cabin, any recommendations would be cool too.
    References: BigSix,
  13. #177
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    So I've sealed most of the cracks with expanding foam so far so good (minus filling the rear deck yet and the side with my power wires running through) The spare tire well I forgot to put the tire and top back on when building the box in my trunk, would not covering this with wood/plastic/foam etc hurt any output?
    References: BigSix,
  14. #178
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Just kind of showing the foam idea, the boxes face is really ugly (right now) once it all cures etc I'll shave it off and paint the box all black again.
    References: BigSix,
  15. #179
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    so u jus thave ur port firing into the cabin?.....dude wtf are u doing
  16. Thanks kushy_dreams thanked for this post
  17. #180
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Quote Originally Posted by Imtjnotu View Post
    Thats whats been discussed somewhere near the start of the thread :V
    whutrudoin
    References: BigSix,
+ Reply to Thread
  1. Skar audio vvx-15 subwoofer box build
    By 321slapinbass in forum Enclosure Design & Construction Help
    Last Post: 02-08-2012, 07:12 PM
  2. (2) 12" SKAR Audio VVX-12D2 Box Build Help...
    By NissanKicker in forum Enclosure Design & Construction Help
    Last Post: 01-31-2012, 05:39 PM
  3. PV Audio's Carpeting/Box Build Technique Tutorial *56k on hiatus*
    By PV Audio in forum Enclosure Design & Construction Help
    Last Post: 12-16-2009, 09:20 PM
  4. 15" Beyond Audio Inhuman Box Build
    By PhatTonyDeMarco in forum Enclosure Design & Construction Help
    Last Post: 12-09-2005, 07:28 PM
  5. Box Building 2 15" Diamond Audio CM3s
    By colt325e in forum Enclosure Design & Construction Help
    Last Post: 02-26-2005, 02:03 AM
