Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Reload Thread: 2 HDC3 15's with DUAL Vertical kerf port
    bigbud747's Avatar
    bigbud747 is offline CarAudio.com Elite
    Oct 2007
    Stillwater, OK
    608
    Just started this box tonight. Have about 3 hours into it. Just have to put the double baffle on, cut the holes, and it's done. Guy wanted it bare. Box is 7.3 cubes with 120 sq. in. of port tuned to 37 hz. Should make some boom in the back of his Trailblazer. On to the pictures.
    kowboy's Avatar
    kowboy is offline CarAudio.com Elite
    Nov 2003
    The "D"
    1,537
    1 Post(s)
    Re: 2 HDC3 15's with DUAL Vertical kerf port
    Tuned in...
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,661
    14 Post(s)
    are you filling the backside of the kerf with anything? And why so small on the enclosure as AQ's like large enclosures?
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    Backside is filled with wood glue and will be fiberglassed. And space constraints is the reason for only 7.3 cubes. I'll be interested to hear how it sounds off just one 2200. Any input in design? Never built a box like this before but have seen many like this put up good numbers.
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    Just finished the box up. Will be left bare for now. Did a double baffle for extra strength, and resined the kerfs, and all corners, so won't be leaking anytime soon. Also have bolts through the box for speaker terminals for maximum power transfer. The guy will probably be installing everything tomorrow and letting it rip. We'll see what she does then.
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,496
    149 Post(s)
    You should get good numbers but can't say how well it will sound on music.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - CT - ASE (local) - Batcap - C&D Tech - DC - eD - Excessive Amperage - Rainbow
    In Nashville? Me too! Pm me and come hangout!
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    With it being about 6" from the back hatch, there will be more compression than being a lot farther from the hatch. I'm thinking musically from 36 hz and up.
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    I think aeros might have worked well in this application.
  9. #9
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    Yeah. He wanted something that nobody else had, so i figured i would build him this. It won't be playing Decaf anytime soon, but it will soot his needs for hitting high numbers and still being musical. Most of the rap he'll listen to will be in the low to mid 40 hz range.
  10. #10
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,636
    17 Post(s)
    The enclosure specs look pretty spot on for the listening preferences. My personal experimentation found the Aq to like smaller chambers and larger ports tuned low to play flat and over power the spike in response. The enclosure looks nicely built. I had 2 12's ported at 37 in my s10 blazer and they would play to the low 30's pretty well.
    I have been wanting to grab another pair of aq's to play around with I would like to try them out in a tline or horn loaded enclosure.
    I am protesting Skar by giving them added exposure in my signature.
  11. #11
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    That's very good to know. The guy had limited space, but i figured that 7.3 cubes would be enough, especially with a HUGH port. Might not do a hair trick but it's going to be painful, even on just a 2200 for now.
  12. #12
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    Guy is coming over today. He has a DD-1, so we'll be tuning the amp and seeing what it can do. Just wish i had access to a TL.
  13. #13
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,096
    351 Post(s)
    Quote Originally Posted by bigbud747 View Post
    Move to OKC and you will lol
  14. #14
    bigbud747's Avatar
    Oct 2007
    Stillwater, OK
    608
    Well, I actually live in Stillwater. Haha. The closest person I know that has one is Anthony Aho at Aho Audio in Guthrie. I'd love to have a meet up with some people around the OKC/Stillwater area. The guy i made this box for lives in Moore... Message me your contact info and we can get this setup metered.
    Also, he says it's really loud, but like any other bass head wants louder. Therefore he's been talking to me about a wall. Obviously this opens up more air space, but what would be a good net volume and port area for a wall with these 2 HDC3 15's?
  15. #15
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,096
    351 Post(s)
    I will send over my info in a few...
    As for a wall...well i would do around 8.5-9.5ft3 with a large amount of port area.
    Is that your adds on craigslist I see from time to time lol
    BTW- I'm buying a CNC very very soon and picking up a new location(in OKC or Yukon not sure which yet) so if you need something custom done that is a pita with basic tools just hit me up.
  1. audioque hdc3 15" Inch sub dual 2 ohm aluminum voice coil
    By Jason19 in forum Subwoofer Classifieds
    Last Post: 05-28-2011, 02:58 PM
  2. Sir Pay's Duke Blue Devils dual 13w7 kerfed port box...Built by DONH
    By Sir Pay in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-06-2011, 03:14 AM
  3. AQ HDC3 15 in Ram Ext cab sub & port placement
    By HPDRLR in forum Enclosure Design & Construction Help
    Last Post: 01-01-2010, 09:56 PM
