+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 35
Reload Thread: Toyota Tacoma Rebuild (Sundown, Image Dynamics, Knu Konceptz)
  1. #16
    Sugary Monkey's Avatar
    Sugary Monkey is offline Member
    Nov 2008
    Owensboro KY
    84
    Re: Toyota Tacoma Rebuild (Sundown, Image Dynamics, Knu Konceptz)
    First primer coat wet sanded
    Second primer coat applied
  2. #17
    Nov 2008
    Owensboro KY
    84
    Well i tried spraying on the first color coat and for some reason on certain spots the paint would not stick to the primer at all it just ran all over the place So now it looks like im gonna be sanding everything back down and rolling on some herculiner bed liner instead the inner baffle where the subs will be mounted looked okay so i think I'm gonna go ahead and finish that part out green to give it a two tone look ive herd good things about the herculiner and have seen pictures of some pretty good results. Wish me luck.
  3. #18
    30Hertz's Avatar
    30Hertz is offline Member
    Jul 2011
    Central Cali
    117
    Quote Originally Posted by Sugary Monkey View Post
    I think i saw your build when i did a search for taco builds lol. Your's the plexi glass window with bed liner and vinyl that looks like white carbon fiber correct? I love that build.
    Yup, that was my build. I used Herculiner and 3M DiNoc for the carbon fiber look. Right now that enclosure is sitting in the garage since I like to try different stuff all the time lol
    Make sure you stir the **** out of the Herculiner. I used a foam roller for mine instead of the regular cloth type and worked good!
    Nice work on the enclosure! Can't wait for the finish
    Feedback:
    http://www.splbassx.com/forums/index.php?showtopic=9609
    Also available is ebay name upon request
    Purchased from:
    919motoring
  4. #19
    Nov 2008
    Owensboro KY
    84
    Got it all sanded back down and masked off the areas I didn't want to be coated in Herculiner. I got the first coat of Herculiner applied to the box waiting for it to dry a bit then I'm going to apply a second coat. I have to say that the Herculiner turned out better than i could have imagined. I should have just used this in the first place.
  5. #20
    30Hertz's Avatar
    Jul 2011
    Central Cali
    117
    looks great
    Feedback:
    Purchased from:
    919motoring
  6. #21
    kushy_dreams's Avatar
    kushy_dreams is offline low like a bau5
    Sep 2009
    University of Toledo
    26
    1,974
    3 Post(s)
    Looks good, I've always liked that textured look. Does Herculiner only come in black?
    Refs: http://www.caraudio.com/forums/buyer-seller-feedback/530100-kushy_dreams-feedback-thread.html
  7. #22
    redrider's Avatar
    redrider is offline Senior VIP Member
    Jan 2012
    jacksonville, fl
    161
    Quote Originally Posted by kushy_dreams View Post
    i believe so but if you like the texture could always just take it to a line-x or rhino liner dealer where they can spray it with color.... i believe rhino liner line can actually color match as in matching the exterior color of your car to the texture coating.
    noaffiliation.net
    subs : 2 s2w8-svc 2ohm by Cadence
    doors: Cadence zrs65ks comps
    amp: Cadence CSA5000.1
    wires: 0awg amp kit from SQ
    alt: 200amp H/O from powerbastards.com
    Big 3: 4 awg run soon to be 0 awg
    box: mdf/fiberglassed box ported tuned @ 35hz soon to be built by me
    CADENCE SPONSORED
  8. #23
    Nov 2008
    Owensboro KY
    84
    Thanks guys glad everyone is enjoying my build so far. I went ahead and added a second coat of herculiner to the box I'm gonna let it dry over night and hopefully have some pics tomorrow before I finish it up with a mirror gloss imperial jade mica on the baffle. The Herculiner turned out to be a great solution since my attempt at painting this enclosure turned out to be total failure. Herculiner FTW!
  9. #24
    Nov 2008
    Owensboro KY
    84
    Pic of the Herculiner second coat applied all dry and ready to go
    I also made these tweeter pods out of some 1 1/2 PVC end caps these will be mounted to the a pillars in the truck I painted them with the imperial jade mica that i had left over.
  10. #25
    2ndroundko's Avatar
    2ndroundko is offline Member
    May 2010
    Greenville NC
    46
    Nice box and great idea on the tweeter pods I want to do the spheres but I may go this route now.
  11. #26
    Nov 2008
    Owensboro KY
    84
    Quote Originally Posted by 2ndroundko View Post
    I actually got the idea for the tweeter pods from another forum I can pm you the link to the tutorial of u want
  12. #27
    redrider's Avatar
    Jan 2012
    jacksonville, fl
    161
    install pics yet?
    noaffiliation.net
    CADENCE SPONSORED
  13. #28
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    3,847
    another tacoma...nice
    box looks good, I've done a couple builds with 8's and they're probably my favorite to use
    Team Flex Issues
    2 15" Zcon's
    Crescendo 5500
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  14. #29
    Nov 2008
    Owensboro KY
    84
    Quote Originally Posted by redrider View Post
    install pics yet?
    Sorry no install pics yet things are on hold until Saturday because I had to go back to work this week. But hopefully by the end of the weekend I'll have everything wired up. I'll post up install pics as we go along throughout the day on Saturday.
  15. #30
    redrider's Avatar
    Jan 2012
    jacksonville, fl
    161
    work puts everything on hold. i know how you feel. im trying to get my install/box finished but once i get off work i have like 1 hour of daylight and cant get much done. hoping to get my paint ready this weekend.
    noaffiliation.net
    CADENCE SPONSORED
+ Reply to Thread
