+ Reply to Thread
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 75
Reload Thread: Buck Box Designs /// 6th order AQ hdc3.0 single 10"
  1. #16
    duanebro's Avatar
    duanebro is offline CarAudio.com Elite
    Oct 2011
    Grand Blanc, MI
    561
    74 Post(s)
    Re: Buck Box Designs /// 6th order AQ hdc3.0 single 10"
    I would like to know how firing the rear port into the front chamber works? Does it act like a normal 6th order because the front port has unloaded?
    looks like a nice box. Have fun with it!
    HU - Pioneer
    Front Stage - Old school MB Quartz run off a JL e2150
    Rear Stage - Stock - well one works, LOL
    Sub - Tang Band 740C in between the front seats
    Sub Amp - A tiny Kenwood. - because it fits under the seat.
    Total Spent on everything $50.
  2. #17
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,671
    29 Post(s)
    1130 Post(s)
    Quote Originally Posted by duanebro View Post
    It's hard to explain, at least for me.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  3. #18
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Maybe @Moble Enclosurs could chime in. But don't expect a short response lol
  4. Likes Buck, sobe3yourself. liked this post
  5. #19
    sobe3yourself.'s Avatar
    sobe3yourself. is offline lordside gangster
    Nov 2009
    Orange, CA
    2,947
    167 Post(s)
    1" wood? looks thick.
  6. #20
    Qexler's Avatar
    Qexler is offline Senior VIP Member
    Oct 2010
    Vine Grove, Kentucky, United States
    158
    16 Post(s)
    Its 3/4" thick MDF, and the baffle is 1" pressed Wood.
  7. #21
    The_Grimy_One's Avatar
    The_Grimy_One is offline CarAudio.com Veteran
    Apr 2011
    Phoenix, AZ
    4,236
    1 Post(s)
    565 Post(s)
    Yummy. Wish I could hear this. Bet its ridiculous.
    Deck: Pioneer 6900UB
    Highs: Pioneer TS-D1730C, Focal OEM Mids (Clarion NX-3410)
    Sub Stage: None (Sony ES XM-6001GXD)
    Bought From: ge_off_me, Boomsday, Chemmins, impactas, Sleazebagger, NoPh33rRaCiNg, fasfocus00, 50cents, flastrongman, pborcich, ace_800, GAMEOVERCCA, Ciaonzo
    Sold To: Jamesmington, Juicee, Bunkrd you, Donnie Darko, ge_off_me, destined2race, todd131, Imjtnotu, mclerico83, aimology, Audiobahn, kpetree, Souldrop
    Traded With: ge_off_me, Imtjnotu, 04lariat
  8. #22
    Moble Enclosurs's Avatar
    Moble Enclosurs is offline Box Designer/Builder
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    If you look at a typical quasi 6th order, you will notice that it is not much different than a typical bass reflex firing into another area at which, based on even more physical constraints, the resonances within that area also conform to the response. If you look at the word quasi, you will see that in definition it says something about resemblance and looking like something but not all the way. Well, in this particular design, it resembles a BR in a vehicle with a measurement taken just outside the window of the vehicle, 3 ft away. But it also can have an acoustic,al resemblance to a tapped enclosure in which the phase of the rear signal has to be in phase with the output of the second chamber in order to increase efficiency and in turn increase output at a power constant. This is why they can be very efficient, much like a tapped design, but the big difference between the two is that the tapped design utilized back wave propagation for extended low frequency response. The quasi 6th does not. It utilizes resonances and small room acoustics for increased gain even before the vehicle is taken into consideration.
    So, basically what happens is, you figure for the response calculation of the rear chamber resonances and response, and figure what it will do in the accompanied space of the second chamber with its response, and figure for a combined response with a specific phase correlation between that and itself, and that within another complex environment in which more resonances and modes are excited creating more gain and loss based on volume and distance, and then conform them together to get a final response and phase at a specific listening position or even an average of the entire room. (take a breath). So, in essence, a quasi 6th order can become very efficient, but uses one chamber to limit its response to a specific tuning factor and then uses that response combined with direct driver radiation into another chamber that again limits that response into a different tuning factor which is combined with vehicle gain at the end.
    It is not known that the quasi design acts like a bandpass in a sense that the front or rear chamber is sealed, but in a sense that the direct driver radiation has already contribut3ed to the response before final tuning, where as we know, it only exits one port. And at the end, the terminal velocity and intensity at that port determines the bandwidth, which is like calculation for a single port without combining direct driver radiation as the box volume itself is always considered a filter of some sort. Direct radiation is more broadband, hence the smoother output in be and sealed designs than bps. But I wouldn't call a quasi 6th an typical bp. I consider it quasi and that's it.
    Contact me for more info:[/COLOR][/I][/B]
    Mobile Enclosures:http://mobileenclosures.com
    Facebook:http://www.facebook.com/pages/Mobile-Enclosures/134158593281463
    YouTube Channel http://www.youtube.com/user/TheMobileenclosures
  9. Likes 05trailblazer, sobe3yourself. liked this post
  10. #23
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    Its much like designing a bass reflex in a room with no losses. And getting the response from the outside of the only window instead of in the room. you treat the second chamber like a room and figuree for its gain in the response curve and add that mathematically to the response from the first chamber and the driver. But not that simple to do correctly.
    This is why you see a lot of tapped boxes, because sometimes the physics involved are very similar.
  11. #24
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    why do you think trucks can get so loud at comps? The less airspace coupling between the box and the cabin, the more the truck sounds like your in a box.....because after a certain ratio, you kind of are. And why in house response can have more losses because it's larger. Etc etc its all physics really
  12. #25
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    And I actually shouldn't say "no losses", I should say, minimal absorption losses.
  13. #26
    brandinooooo's Avatar
    brandinooooo is offline Woot Woot
    Dec 2010
    Stantonville, TN , Anchorage, AK
    27
    733
    1 Post(s)
    53 Post(s)
    Quote Originally Posted by Moble Enclosurs View Post
    I was thinking about that the other day. Having a walled truck is just like a 6th order with the windows as a adjustable port.
    HU - Kenwood KDC-HD545u
    Front Stage - Stock
    Amp -
    Rear Stage - Stock
    Amp -
    Sub - HDC318 6cuft tuned to 35
    Amp - Audiopipe 1500d
    MY BUILD LOG - http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/526429-02-tahoe-aq-build.html
  14. #27
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    Quote Originally Posted by brandinooooo View Post
    precisely. But only as a 6th if the wall is ported. If it's a sealed wall, it acts as a common 4th. Unfortunately for those who do not accurately figure for cabin gain, this is not an accurate way to model it simply by adding the vehicle volume into the design, due to resonances of oblique shapes and reverb as well as absorption loss.
  15. #28
    Dec 2010
    27
    733
    1 Post(s)
    53 Post(s)
    Yeah I meant a ported one. If I were ever going to start entering comps I would wall a truck. I would account for every little thing so I could use it as a 6th order.
    Front Stage - Stock
    Amp -
    Rear Stage - Stock
    Amp -
  16. #29
    Qexler's Avatar
    Oct 2010
    158
    16 Post(s)
    Fine Tuning still being done, Got another photo! But the Vid will have to come another time sadly =/ Still gotta work out some small kinks.
  17. Likes Moble Enclosurs liked this post
  18. #30
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    You're right, that is a close fit nice work guys!
+ Reply to Thread
  1. box for 2 18" AQ HDC3's
    By lowrnu in forum Enclosure Design & Construction Help
    Last Post: 09-02-2009, 10:19 PM
  2. need 2 boxed designed 4th order and aero port
    By jonny101abc in forum Enclosure Design & Construction Help
    Last Post: 07-03-2009, 01:39 PM
  3. Need a box design for 2 15" hdc3's....7.25 cubes @ 36 hz
    By da box king in forum Enclosure Design & Construction Help
    Last Post: 03-01-2009, 01:21 PM
  4. I need a box design for 2 15" HDC3 asap
    Last Post: 06-20-2008, 12:43 PM
