Those doors came out awesome.
Newb question,but how do the subs add anything for the listeners,firing into the trunk? All I would hear is the ports coming through the package tray?
i have a ******* question, but i have never fiberglasssesd so, how do you get the finished panel to stay on the door?
Last edited by Falcons; 01-14-2012 at 02:27 PM. Reason: something crazy happened and mixed my sentence together lol
Things to look forward to:
(2) 10" or 12" imperium audio designs subs
set of PHD MF 6.5" comps
Completely seal off and deaden my doors
aquire a 2k amp
aquire a 2 channel amp for front stage
its screwed to the panel through the speaker holes.
Looks phenominal
www.BassHeadsENT.net for all your custom enclosure needs
Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
Robin@BassHeadsENT.net
Check this thread for all the build logs being posted.
http://www.caraudio.com/forums/suppo...ks-thread.html
makes sense. but hell yeah it looks amazing
aquire a 2k amp
you don't hear the ports, you hear the same thing you would that you do if the driver was facing you, it is just the sound wave off the back of the sub. But there is also some of the front wave making its way to the front of the car. I am in hopes of putting it on the meter this week. I expect a decent number considering it is a looker and daily driver, not an all out comp vehicle with a fart box
Mine is bigger than yours!
In this instance they are screwed from the door panel to the pod, that way the panel tightens up to the door better. I did learn on this build that I will glass some pan head bolts into the pod next time and then bolt the pod to the door, making it real tight.
and thanks alot for the props, much appreciated
aquire a 2k amp
the drivers are secured to the pod is secured to the panel and the panel is secured to the door, so there is no part that is unsecured, infact if you are not careful and you warp the glass while laying it up you will have a hell of a time getting the panel on once the pod is secured to the panel because the pod is so rigid from having so many different planes/curves.
I hope that helps
aquire a 2k amp
Is there a divider to separate the airspace between the mids and midbass? Did you vent into the door? What is the airspace the dual midbass drive see? How many layers of glass did you use on the doors?
have you been helped by me? i'd love to know. shoot me a PM.
My 2001 Accord build log:
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
Can I help you? valencebandacoustics@gmail.com
Want to learn about car audio electronics?
http://www.bcae1.com
man this would look good with some HLCD's![]()
need an aeroprt?
http://www.caraudio.com/forums/misce...aeroports.html
Bookmarks
