Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Reload Thread: 1974 Dodge Charger-Alpine, Infinity, Kicker
  1. #31
    SG1022's Avatar
    SG1022 is offline Junior Member
    Dec 2011
    Salem, Oregon
    20
    3 Post(s)
    Re: 1974 Dodge Charger-Alpine, Infinity, Kicker
    Quote Originally Posted by keep_hope_alive View Post
    Dude, to be 19 and have this car - well done. The system is fine. Glad to see you are doing a decent job.
    Any door speaker pics?
    Great to see you reading my thread! I just read you ENTIRE Honda thread. Good ****! Great work,and I will probably be stealing your tweeter mounting idea.
    I also need to get a wiring/audiosystem map done for my car. I really like how you set up your diagram.
    Yeah, the car's alright.
    Seriously though, this car has been my life for four years.
    Here are some pics of the deadener. Ontop of using it on the interior, I put it inside of the door, on the outside, side, of the window.
    Here's a closer picture of the speakers. For some reason I couldn't photograph my door panel accurately. In person it doesn't look like multicolored ****. It's a nice even satin black. I probably should of dusted it off.
    I just picked the only spot in the door that they would fit(no room inside the factory kick panel dimensions), cut a hole, and mounted them. I don't really know enough, and didn't take into consideration how my sound stage will be.
    I probably should of taken my time picking a better location, and glassing them in, instead of just fitting inside factory lines, but I also wanted them to fit inside those factory lines. Oh well.
    Hopefully I will get to finishing the trunk deadener later this week.
  2. #32
    SG1022's Avatar
    Dec 2011
    Salem, Oregon
    20
    3 Post(s)
    I also got it running today! Finishing my audio system is next in line.
    http://www.facebook.com/v/322111611173633
    Sub enclosure now has all the seams sealed up. All that's left is to cover it, and cover my package tray. Looks like I need to dig out my staple gun.
  3. #33
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Looks fine, suede color is good. It is good to start simple with the doors. Ensure you like the location before you glass something in.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  4. #34
    SG1022's Avatar
    Dec 2011
    Salem, Oregon
    20
    3 Post(s)
    That's the thing, they aren't suede, They are painted with a satin. It looks spotty, and like suede because I couldn't photograph it properly.
  5. #35
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    nice work bro,
  6. #36
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by SG1022 View Post
    Gotcha. Still looks good. I am curious how the enclosure works in.
  7. #37
    SG1022's Avatar
    Dec 2011
    Salem, Oregon
    20
    3 Post(s)
    This is a before(paint) picture of the trunk, just to show you the center hump that is in mine. The enclosure will fit kind of over that. The subs are . . . upward firing? I think that's the right term. directly above the enclosure is my package tray(below the rear window) that will hold my 6x9. They fit into that plywood board that can be seen in the picture above. That rectangle port between my 6x9 holes is where my factory rear defroster went. Well, my car doesn't have a defroster, so I cut the hole anyways, and it will serve as kind of a, "port" for the subs to , "flow" into the cabin. That was my idea, I'm not sure if it makes sense from an audio perspective. I guess we will see.
    ---------- Post added at 11:15 PM ---------- Previous post was at 11:14 PM ----------
    This is a picture of some random 74 charger, but it should give you a better idea of my trunk layout.
  8. #38
    SG1022's Avatar
    Dec 2011
    Salem, Oregon
    20
    3 Post(s)
  9. #39
    focused313's Avatar
    focused313 is offline Learning With Every Post
    Mar 2004
    Michigan
    267
    12 Post(s)
    good job man, love seeing this come along.
    Had JL 12w3's...replaced with Type R's...and couldn't be happier
    God Is Love.
    Don't , I'm Just Here To Learn.
  1. alpine amp+kicker sub = ????
    By MopeDman in forum Amplifiers
    Last Post: 04-29-2003, 10:35 PM
  2. Alpine or Kicker
    By jimmyslide in forum Subwoofers
    Last Post: 11-05-2002, 02:05 PM
