Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 81
Reload Thread: 6 12's 4th order, 16v, 10k+, single cab s10 :)
    treylittlefield's Avatar
    treylittlefield is offline CarAudio.com Elite
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    well i've got a good bit done so i figured i would start a build log, still have a ways to go but i got a lot of the things in i need.
    build will consist of:
    Single Cab s10
    Alts: 2 Ohio Generator 300amp, 1 Mechman 250 amp
    Headunit: Kenwood KDC-X994
    Amps:US Amps for horns, Modded Zed Leviathan for mids, and 2 Sundown 3500d's for subs.
    Subs:6 SA 12's
    Frontstage: Illusion Audio CH-1 Carbon horns, Sundown neo pro 8's and 10's, Dayton 4 inch mids.
    Wiring: 4/0 welding wire for 16v alts, all KNU flex for 12v side.
    Batts: D3400 up front, 3 d1600s for 16v.
    Im sure im leaving something out so bear with me. ive never done a build log nor a build to this magnitude.
    BIG THANKS to Surreal, Toolmaker, and Jacob for helping me out. i know ive bugged the **** out of them with a million questions.
    old setup:
    New Stuff
    Modded Levithian, does 150x6@8 and 250x6@4
    Toolmaker is going to help me fix this mess
    Box
    I-Trader-http://www.caraudioclassifieds.org/forum/itrader.php?u=1860
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    Re: 6 12's 4th order, 16v, 10k+, single cab s10 :)
    Amp Rack
    keep all the wire organized
    Relay wired In with the needed Diode
    ---------- Post added at 01:29 AM ---------- Previous post was at 01:28 AM ----------
    got a little more done today, next step is to resin the inside and outside.
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    Got a little bit done this evening...******* me resined the tops of the wood so i gotta sand it down so i can glue the sealed section together and it actually hold. tried sanding it by hand, that **** ain't happening lol
    and here is what will be powering the subs
    4 inch mids that will go in the dash
    gotta hug them nuts
    box resined. debating on painting the inside and outside. inside will be white with while leds more than likely. anyone got any suggestions on inside and outside? how many coats of resin will it take jsut to waterproof it? what prep work should i go to to get it ready to paint? noob questions i know, dont want super slick paint but i want it to look good.
    1 of 2 braces added. other will run perpendicular to this one.
    thanks toolmaker!! negative terminal is sideways a little to keep it away from the fender a little.
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    not much of an update, but got the sealed section done. also got the t nuts on the baffle. gotta wait on the gasket for the top. gonna sand the inside down good and paint it this week if i can get a warmer day.
    amp situation will change more than likely. gonna ditch the US amps. jsut isnt practical and i have all the power with the leviathan. plan on building another amp rack since the current one is butchered up with a bunch of holes. it will help with tuning and make things all around better.
    Epic0318's Avatar
    Epic0318 is offline FFFFFUUUUUUUUUUUUUU
    Apr 2011
    Goodyear, Arizona, United States
    22
    918
    25 Post(s)
    this looks like a ****** build. definitely in for this one.
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    glad your interested....gonna be a long haul im afraid. but im making good progress. been working on it for a week now.
    maljr1980's Avatar
    maljr1980 is offline Senior VIP Member
    Apr 2011
    frederick co
    315
    sundown license plate=good way to get your **** jacked
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    That removable section is only going to be one layer thick? That's a big span to leave unbraced.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  9. #9
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    Quote Originally Posted by maljr1980 View Post
    I live in a very small town. Park in a garage and no-one even knows what sundown is. It will be fine lol
    Quote Originally Posted by RAM_Designs View Post
    No it will have a brace in the middle
  10. #10
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Elite
    Dec 2011
    Tulsa, OK
    1,869
    25 Post(s)
    Man that's beautiful! Wish I had the ability to do something like that....
  11. #11
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    1,898
    2 Post(s)
    Good looking build, keep up the good work...I'm curious though, what type of mod did you have done to your Leviathan and who did the work to get those type of power numbers out of it at those impeds????
    Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
    ____________
    refs:
    Type-S Texan ............Xtremebass5
    NE14MX ........Grinder1989
    NJack2AF
    .............Jameseypoo
    Randyrsx ..........Bagdntagd
    M3Transporter......Teggybwoy
    RJ Sclafani...........Zeuslicious
    Saltyreefguy........Qkassidyw
    Qtrhorse..............Nismos14
    Pistonsfan70........4nine
    SlainNothing.........Orangelss
    M3@Apex............Louisiana_CRX
    SW9152..............DukeNut
  12. #12
    mast240's Avatar
    mast240 is offline YOU'RE A HOOKER!
    Mar 2011
    washington, dc
    3,332
    5 Post(s)
    I'm in... looks good so far bro
    NEW TO CAR AUDIO? READ THIS FIRST... http://www.caraudio.com/forums/general-discussion/532425-new-car-audio-read-first.html
    the loudest montero sport around
    head unit: toshiba thrive 10.1" android tablet/ Kenwood KVT-516
    front stage: each door: 1 8' RF p1 (midbass), midrange: 2 cadence cwm6.5's, 1 memphis pr 6.5 coax (kickplate), 1 cadence 4' coax (a-pillars)
    subs: 4 AQ HDC3 18'S, walled in a clamshell
    amps: subs: AB 500.1, looking for a second; midrange and midbass: 2 AP 1000.4
  13. #13
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,435
    6 Post(s)
    Quote Originally Posted by mast240 View Post
    x2
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
  14. #14
    May 2009
    Sand Rock, AL
    1,297
    19 Post(s)
    Quote Originally Posted by sacsking916 View Post
    x2
    thanks
    thanks man
    Quote Originally Posted by DARKHART View Post
    send it to stephen himself. he wont give any information on the mod nor tell anyone how to do it. lol
    Quote Originally Posted by DoesDad View Post
    only my 1st real box....lol have done a few quick boxes. nothing like this though. lol
  15. #15
    DARKHART's Avatar
    Aug 2002
    LITTLE ROCK, AR
    1,898
    2 Post(s)
    Hahaha, sounds like him....I'm looking at getting three, so I might need to give him a call bout some mods...
    ____________
    refs:
    NJack2AF
  1. opinions... 4th order badpass in single cab cut through
    By bgowdy31 in forum General Discussion
    Last Post: 05-30-2011, 06:58 PM
  2. 4th order for a single 8" help
    By cheeto in forum Enclosure Design & Construction Help
    Last Post: 06-14-2008, 04:04 AM
  3. single cab s10
    By derek9087 in forum Enclosure Design & Construction Help
    Last Post: 04-13-2008, 09:53 AM
  4. single cab s10 ported box
    By xluben in forum Enclosure Design & Construction Help
    Last Post: 12-10-2006, 09:50 PM
  5. System for a single cab s10?
    By Shyne151 in forum General Discussion
    Last Post: 03-17-2005, 09:20 AM
