Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Reload Thread: My false floor is almost complete...
  1. #31
    focused313's Avatar
    focused313 is offline Learning With Every Post
    Mar 2004
    Michigan
    267
    12 Post(s)
    Re: My false floor is almost complete...
    Quote Originally Posted by OmegaBunny View Post
    I was going to do the Omega symbol but decided that since their was a large one on the box that I would do the Fj symbol on both sides. I messed up the one piece of Lexan so I might change it when I redo it.
    I used this Lexan....
    Amazon.com: Polycarbonate Sheet, ASTM D 3935, Clear, 1/4" Thick, 12" Width, 24" Length: Industrial & Scientific
    and these LED's...
    Amazon.com: Flexible Lighting Strip 300 SMD LED Ribbon 5 Meter or 16.4 Ft 12 volt BLUE, 2026BU: Home Improvement
    I used my table saw to cut it to 8" x 8" squares then taped it off and drew/traced the design. Then I used a utility knife and straight edge to cut out the design, leaving the design and removing all the excess tape. I used my Dremel multi-max with the sanding attachment to frost it. It went very quickly and I used a straight edge to get up to the tape (even if you hit the tape its okay). Then remove the tape and wipe it down with alcohol. Very easy to do.
    thanks for that info.
    Had JL 12w3's...replaced with Type R's...and couldn't be happier
    God Is Love.
    Don't , I'm Just Here To Learn.
  2. #32
    Goindef154's Avatar
    Goindef154 is offline Nothing
    Feb 2007
    Phoenix, AZ
    32
    5,397
    1 Post(s)
    57 Post(s)
    That looks great, good job man.
    Car: 2006 Toyota Tacoma
    Deck: Kenwood Double Din
    Subs: 4 Sundown SA-6.5's
    Mids: Undetermined
    Amps: Undetermined
    Feedback: http://www.caraudio.com/forums/buyer-seller-feedback/250172-goindef154.html
  3. #33
    OmegaBunny's Avatar
    OmegaBunny is offline Moderator
    Oct 2007
    Keyser, West Virginia, United States
    2,722
    464 Post(s)
    Thanks. I have my sub, amp, and second installed and wired. I have my wire ran for the front stage and some Audio Technix on the way so this weekend I will get my front stage installed and hopefully a video or two.
    2007 Black Diamond FJ Cruiser with Box built by Pro-Rabbit
    H/U Kenwood DNX6960
    Sub: 1-18" Zv3 with NS coils and cone Sub Amp: Mmats 2100.2
    Front Stage: Hybrid Audio L6 mids, SEAS Neo Tweets, SAX 100.4, RF 3sixty.2
    Bought From: Rio, davidtemple, Bassin Buick, Pro-Rabbit, Kangaroux, KyleBechtold Traded With: WhiteDragon551 Sold To: jdmeklove, Kpozr2, 97accordalpine
