I could imagine, I don't think the Jimmy would make it up with out something going wrong haha. That is why it stays on paved roads..well in OKC they might as well be dirt/gravel roads here ****.
That's a driveway? Shit man... you got a lot of trees around ya haha. But I suppose it's just here that they tear everything down for homes... so we don't see trees like that here.
2009 Hyundai Elantra - Budget Sound in Progress
HU- Kenwood eXcelon KDC-X994
Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
Bought from: Inferno333, select127, treesive, Kangaroux, DonH
Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
Looking good
Would like to see the HU and Volt Meter lit up at night
I'll get a shot of the headunit today and I'll try and remember to do it at night, though I think the volt meter is too bright for it to really show up well haha. My camera doesn't like bright lights
Also how are you running the voltage wires?
I just bought a cheap ebay gauge (wish I had spent more and gotten the 3 wire Stinger) but I was going to hook it up behind the dash like I think you have done but that voltage can differ from the voltage the amp is getting.
So for me I am going to ground the voltmeter behind the dash and run a wire to the rear of the car.
Back there I am running a relay to turn on both of my amps (triggered from the remote wire, feed power from the rear Dist block) and I am going to connect the power wire to the voltmeter to the relay output (the same wire that turns on both of my amps)
That should give a better reading of what voltage the amp is getting.
edit** that sounds harder than it really is.
Quit talking and get busy!!! Need pics of those midbass installed, amongst other things! How'd they turn out, etc, etc.![]()
D.D.Q.F.
Traded with : norrizzle9, BassAddictJ (x2), TWiZTid859, btr, btdickey, mylows10, Sour_Deez, El_Weenie;
Bought from : NeilBarber, kurtbeast, bubbagumper, cd6551,
mistergrubbs, gbo559, ltr450racer690, nismos14, ptcmarty,
I was going to run a wire all the way up front/back to get the voltage but what I did was just tap into the headunit's turn on wire (the red wire). It is activated by a relay when only the car is on and has the same voltage as whatever the alt is charging at, it's not some weak 2v signal.
Need to wait for my paypal to resolve so I can order a wire kit to get my rubicon hooked up. These lanzars have less midbass than I thought they would but granted they are rated for 100w+ and they are getting like 10w right now, plus my door isn't sealed up in the slightest.
D.D.Q.F.
meh at best jesse. hopefully the issue gets resolved so you can hurry up an get done. more pics of the stuff thats been installed too.
TEAM AUDIO TECHNIX
TEAM SSC
TEAM CADENCE
Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
Got the big 3 done today, but before I start here are pics of the headunit installed for those that are interested:
Voltage should be higher but I think my battery is slowly dying. It sits around 12.5 at the moment
Pretty much what my front seat looks like when I'm doing any kind of work on my car
The same thing goes for under the hood, lol
Well, the spot where I had originally wanted to ground is out of the question. As I was securing the wire the screw snapped straight in half. Luckily that brace isn't for anything important
Instead, I just used a ground that was already being used.
Ground attached to the engine block
And the alt positive
Almost there...
Had to strip down the wiring coming from the fuse box. The insulator on the wire isn't even rubber, it's hard plastic. Biggest PITA to cut ever
Because I don't have any hydraulic crimpers or bolt cutters to crimp the terminal, I had to go down in my basement and bring the table vice out. Don't worry, it's OK to do this. I'm from Maine.
Heard a weird noise while I was working only to look over and see that my cat had taken a **** all over my front tire. Cool.
Crimped and secured tightly with several passes of electrical tape. I gave this a good tug and it's not going anywhere.
Got it all hooked up only to find the car didn't start. After some quick testing with a DMM the problem came down to the terminals having been painted. Paint had gotten inside the threading where the bolt goes so I wasn't getting any contact there, so I just sanded off the top where the wires touch it.
Now we're good. I ended up accidentally dropping the nut and bolt for the negative terminal so I'm going to have to find that. Until then this will have to suffice.
Bookmarks
