Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Reload Thread: Something a little different... Boat Build
  1. #16
    agarabaghi's Avatar
    agarabaghi is offline Senior VIP Member
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    Re: Something a little different... Boat Build
    Quick update. Started building the box... got most of the cuts done and the port opening mounted. Just need to fiberglass epoxy resin the inside and test for fit...
  2. #17
    The_Grimy_One's Avatar
    The_Grimy_One is offline CarAudio.com Veteran
    Apr 2011
    Phoenix, AZ
    3,908
    45 Post(s)
    Nice build bro... That amp is super ****, and those Exide batts are very nice. My boy got one for the super low and he loves it, almost more than his BatCaps. I hope I come across one for cheap.
    And I see you decided to go ported, nice stuff. I was just gonna say that I had talked to Jason and he said the SA-10 performs great in about .5 cubes, which is ridiculously small. Great work so far.
    Deck: Pioneer 80PRS
    Front Stage: Incriminator Audio I65C / Front Amp: JL Audio 300/2
    Sub: (2) 10" FI Audio SSD / Sub Amp: MMATS 1500.2
    Bought From: ge_off_me, Boomsday, Chemmins, impactas, Sleazebagger, NoPh33rRaCiNg, fasfocus00, 50cents, flastrongman, pborcich, ace_800, GAMEOVERCCA
    Sold To: Jamesmington, Juicee, Bunkrd you, Donnie Darko, ge_off_me, destined2race, todd131, Imjtnotu, mclerico83, aimology, Audiobahn, kpetree
    Traded With: ge_off_me, Imjtnotu
  3. #18
    agarabaghi's Avatar
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    Yea, i though about sealed, but i really like the sound of ported especially on the water it helps with all the outside noise.. .you can really hear the different between sealed and ported on the water lol... its hard to dapend / deadened a boat...
    Im going to wait for the SA 8 v2 and put one under the dash also =P that will be sealed though...
  4. #19
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    Looks great so far. I want to see what you think of it once it is in the boat.
  5. #20
    agarabaghi's Avatar
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    I will be sure to let everyone know... I still need to figure out the port length. I know it's suppose to be 16, but is that the measurement from flange to flange? The instruction are not very good, but it says something about cutting 5" off from the pipe, so im assuming that is to compensate for the tips.
  6. #21
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    When I get a chance I will go back to the notes and see what the overall length was again.
    If you are using a precision port, then once you subtract 5" from the total actual length and that is your center section.(it should be on that little paper in the box....they call that the instructions )
  7. #22
    agarabaghi's Avatar
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    length was 16.01", so let's say 16" ... so i should cut the middle section to 11"?
    I am using a precision port.
  8. #23
    agarabaghi's Avatar
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    Got the box built this weekend.
    ---------- Post added at 08:14 AM ---------- Previous post was at 08:13 AM ----------
    Ended up doing all resin coating and 1 layer of fiberglass cloth on the bottom. Pretty pleased with how it turned out, and once it's carpeted no one will notice the mess hah...
  9. #24
    agarabaghi's Avatar
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    Did a dry test run, hooked it up and everything... WOW is all I can say. Much better sounding than before. Its not carpeted yet, and im wondering if this wedge box shape will fit under the dash should it would be completely hidden.... We shall see...
  10. #25
    agarabaghi's Avatar
    Apr 2011
    Orlando, FL
    449
    3 Post(s)
    Video of the stereo:
