Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Sundown 12" Neo Driver 4th Order Bandpass
  1. #16
    Rawr-DQ's Avatar
    Rawr-DQ is offline !!!!Vote Third Party!!!!
    Dec 2004
    Fort Myers, FL Posts:____________31,337,666,999
    25
    2,882
    Re: Sundown 12" Neo Driver 4th Order Bandpass
    Yeah I know right?
    That's what I get for using my struck (stratus+truck) to move sod; plants; mulch; 8-10' lumber; ****.
    Quote Originally Posted by kickerassman View Post
    i was thinking some thing like this..... get a reall fine but strong sharp cable like them tension cables tie it around your neck and tie it to something..... then get some supper supper supper glue and glue your hands to your head.when the glue dries jump of the building with the cable cutting your head off and you would have your head glued to your hands ...... some one would see that and be like wtf omg that dude ripped his head off ... he mst have been pisssed!!!
    My Current Build Log: (16 8" Sundown subwoofers)
    http://www.caraudio.com/forum/showthread.php?t=367352
  2. #17
    DonWan's Avatar
    DonWan is offline Senior VIP Member
    Jul 2010
    indiana
    394
    gotta make a video of this sub when you put it to work . I was debating on buying it as well when Jacob had it for sale..
  3. #18
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    yeah; but you wont be able to see it unless I get a lexan/plexi cover
  4. #19
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Ok well the sheets got cut today; I had to clean the porch to work to mess it up again.
    However with a skill saw I still manage to get cuts within 1/8th of an inch;
    My method of measuring is meticulous I use the factory cut edges of the boards in order to setup a guide. I lined the corners up flush to the guide; the cut board; and the support directly on the chairs I used as saw horses.
    From there I do the following:
    Measure the saw blade to the rim of the saw to determine the distance of the blade to the guide depending on which side of the board I'm on (I account of the thickness of the blade)
    Basically if I'm cutting from the 4x8 sheet and the guide is on the outside the cut. I need to factor in the thickness of the blade plus the distance to the guide from the rim of the saw. If the guide is sitting on the board and I'm trimming it to size; I factor out the blade and just use the distance of the blade to rim.
    I make two markings on the cut sheet the guide arrows and cut arrows using a tape measure.
    I place the guide down and line the board on the center of the arrows and clamp down.
    Here is the tedious part:
    I use a block to nudge the board into alignment before while and after clamping it in place; Then I cut a test notch; measure my board; adjust if necessary; then rip it in a few seconds maintaining and even level pressure perpendicular to the cut.
    Spend 10-20 minutes measuring; and a few seconds cutting.
    I speed things up as I get going I will assembly with minimal screws tomorrow.
    I've already figured how the box is going in; I will have to take off my passenger door to do it; along with the seats out. I will have some more interesting pics tomorrow.
    The guide is on the outside of the cut here. To keep the saw from binding, the support is at the guide; this will pull the board away from my blade to keep it from pinching; another chair that is slightly smaller is there to keep it from bending too far and from falling.
    Here is a picture of the test cut and measurement; This one was spot on at 34"
    Note the guide was on the inside of the cut here; the blade is on the outside; distance of the blade to the rim was 1 1/8th inch plus 32 and 7/8" (the guide position)
    Thanks for looking
  5. #20
    The_Grimy_One's Avatar
    The_Grimy_One is offline CarAudio.com Veteran
    Apr 2011
    Phoenix, AZ
    3,908
    45 Post(s)
    Looking good! What exactly did you apply on the metal? And how did you apply it?
    Deck: Pioneer 80PRS
    Front Stage: Incriminator Audio I65C / Front Amp: JL Audio 300/2
    Sub: (2) 10" FI Audio SSD / Sub Amp: MMATS 1500.2
    Bought From: ge_off_me, Boomsday, Chemmins, impactas, Sleazebagger, NoPh33rRaCiNg, fasfocus00, 50cents, flastrongman, pborcich, ace_800, GAMEOVERCCA
    Sold To: Jamesmington, Juicee, Bunkrd you, Donnie Darko, ge_off_me, destined2race, todd131, Imjtnotu, mclerico83, aimology, Audiobahn, kpetree
    Traded With: ge_off_me, Imjtnotu
  6. #21
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    I used a roofing silicone
    Paint on; messy; but works. Got the idea based on some thread about sound deadening on some other forum. They were testing and looking into all kinds of stuff.
  7. #22
    Flastrongman's Avatar
    Flastrongman is offline CarAudio.com Elite
    Feb 2010
    Ft Myers FL
    1,799
    17 Post(s)
    I have a way easier way of getting accurate cuts with a skil saw. I'll show you when you come by. I even do large kerfs with mine.
    Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
  8. #23
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Other than a rip fence; what would you use?
    Keep in mind I don't have the luxury of a garage.
  9. #24
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Look ma no screws!
    I love my corner clamps for sure; I also love clean even cuts; very few gaps.
    I line up my clamps; test fit; rub my finger at the seems and adjust the clamps till I don't feel any edges; tighten one side of the corner clamps; raise the board; brush glue; drop; clamp corners; add big clamps near corners and tighten each back and forth; add center clamp and tighten; then finish cranking all three down till the glue completely fills the voids.
  10. #25
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Ok well I'm going to cut the ports and put elbows on them!
    Just wanted to make that clear; However 6" elbows are harder to come by than I thought; so I'm gonna visit a sewer guy I know or order them online.
    Today I'm going to wire the amps and cut the ports; going to leave it sealed.
    I've found out that my engine battery (a kinetik 6800?) went bad; doesn't charge.
    Using a Optima d3100? as a start battery; then disconnect it; engine runs without; tried charging it at 2k rpms for 20 min; but unless it's totally dead; it wont even put the windows down or unlock the doors.
    On to the {PICS!}
  11. #26
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Ok well I got to cut the ports; then it rained and lightninged, so I went inside. I got back out and went ahead and painted it with the same silicone I had before. I figure it will seal better when I put the cover on.
    The ports are 15.5 inches; changed the peak; but I have enough room for some elbows which should give me 6-7" longer port; still a cry from the 30" planned, but we'll see what happens. I'm going to test it sealed first; then bandpass w/ 15.5" ports; then with ~21-22" ports; and so on.
    Legend:
    Red is the 30" port
    Orange is the 22" port
    Yellow is the 15.5" port
    Green is a 6.83 Cubic Ft sealed box
    It was a tight fit!
  12. #27
    Rawr-DQ's Avatar
    Dec 2004
    25
    2,882
    Painted with silicone
