+ Reply to Thread
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 31 to 45 of 117
Reload Thread: Yukon Rebuild. 12 15's, Ipad, extensive fiberglass and motorization
  1. #31
    crnacnac's Avatar
    crnacnac is offline Member
    Apr 2011
    Pasadena,CA
    135
    Re: Yukon Rebuild. 12 15's, Ipad, extensive fiberglass and motorization
    Sick work.
    Ready for more...
    Can't wait for the iPad install
  2. #32
    destined2race's Avatar
    destined2race is offline Already Being Used....
    Jun 2008
    Beatin Down Yo BLock
    913
    1 Post(s)
    ya great craftsmanship, and it seems you got a really good vision on this.
    Headunit - Kenwood DDX 318 4v double din
    Front Stage - JL Audio c2 6.5 comp set
    Rear Stage - Jl Audio VR 6" comp set
    Front stage amp - OS Sony (.005 THD Rated)
    Sub Stage - 2 10" IDs 1cu sealed per
    Sub Stage Amp - Boston Acoustic GT-28
    Big 3, SVR800 Batt, JL Blue Line Rca's, 0 ga JL kit
    Refs - The_Grimy_One, Deusle, zach90z, shineman08, Orion 2500D
  3. #33
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    28
    16,623
    20
    28 Post(s)
    Awesome work as usual.
    Tuned in.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
  4. Thanks basebalz13 thanked for this post
  5. #34
    QuietEclipse29's Avatar
    QuietEclipse29 is offline CarAudio.com Elite
    Jul 2011
    Cali Life
    1,102
    2 Post(s)
    Wow that's gonna be insane. Tuned in on this. Great work
    BASSLESS
  6. #35
    RealSoundz's Avatar
    RealSoundz is offline Junior Member
    Aug 2011
    Chicago IL
    23
    What is the name of the blue molding material your using? and where can it be purchased?
  7. #36
    kylediablo's Avatar
    kylediablo is offline 17 & certified
    Aug 2008
    chatham, il.
    602
    the blue stuff is low temp plastic. im not sure where you can buy it online. try a google search. i get it from select products but you have to be a dealer to get it. mobilesolutionsusa.com... try that
    TEAM DTF
    94' Yukon.
    UNDER CONSTRUCTION.....soon to be 12 15's
    99 Silverado
    Subs: (4) Treo SSX 15s
    Amp: (2) Stetsom 14k2d
    Batts: (10) Treo SSX100b batts
    Alts: (4) Tejcurrent 230
    Highs: 8 sets of various high end Boston
  8. #37
    kylediablo's Avatar
    Aug 2008
    chatham, il.
    602
    well i havent been on here much latley. had alot to do with the show and whatnot then took a lil vacation to nashville with the woman to get away from ****.
    got a lil bit of work done tho. i decided to finish one of the kicks to see what the final look of the interior will look like.
    used the chopper gun on this and it worked great. almost no body filling. just sanded the glass and was almost perfect.
    got in some of the 4 way stretch vinyl im going to use. got bored so i found some purple suede in the back room and half-*** made the grill. its not up to my standard but it looks good enough to get the point. im also using GLOSS white formica under the grill, not matte like in the pic. i wish they made a camera that would pick up purple, it looks blue here, but its far from it in person.
    TEAM DTF
    94' Yukon.
    99 Silverado
  9. #38
    kylediablo's Avatar
    Aug 2008
    chatham, il.
    602
    box in
    the other door done
    console work
    also mocked up some armrests. (this is gonna be some crazy work when its done but you wont see it for awhile)
    TEAM DTF
    94' Yukon.
    99 Silverado
  10. #39
    crnacnac's Avatar
    Apr 2011
    Pasadena,CA
    135
    Quote Originally Posted by RealSoundz View Post
    Here is where I get the low heat plastic:
    .125" x 48" x 96" Dark Blue Sintra Komatex Celtec PVC Foam Sheet
    Great work. I see where the iPad is going
  11. #40
    kylediablo's Avatar
    Aug 2008
    chatham, il.
    602
    no **** thats alot cheaper than SP....but i bet shipping is a *****!. i think i payed 35-40~ for a 36x48...
    yep its goin up top, i hate copying off of ppl but Fishman inspired me on his fishedition. so it will be similar to that....
    TEAM DTF
    94' Yukon.
    99 Silverado
  12. #41
    30Hertz's Avatar
    30Hertz is offline Member
    Jul 2011
    Central Cali
    117
    Quote Originally Posted by kylediablo View Post
    Ya, I checked to see how much it would be,,,,Shipping for the panel to my home in central cali tabbed out to be $148. Granted I didn't have them cut it into smaller sections but dayum!
    Not sure if this is the same...but sounds the same! Smaller sizes
    http://www.foamboardsource.com/sintr...a-pvc-3mm.html
    Great work! Lookin forward to more photos! Subscribed
    Feedback:
    http://www.splbassx.com/forums/index.php?showtopic=9609
    Also available is ebay name upon request
    Purchased from:
    919motoring
  13. #42
    kylediablo's Avatar
    Aug 2008
    chatham, il.
    602
    i really wanted to cry when i had to destroy these, first thing i fiberglassed that acually went in a vehicle. alot of work went into these to make them look good (trial and error lol)
    i drilled holes in the sides of the plastic panel so that the fiberglass would better adhere to it.
    TEAM DTF
    94' Yukon.
    99 Silverado
  14. #43
    kylediablo's Avatar
    Aug 2008
    chatham, il.
    602
    hit it with the choppa
    and a vid of the chopper in action for anyone who wants to see
    Building rear pods with a chopper gun - YouTube
    and another video just so you guys can see what kind of dumb **** goes on when im not working on a vehicle
    The *** CRACKER. How Damon makes $20 when hes desperate - YouTube
    and my other hobby......(why i am currently still broke lol)
    2nd Annual TEAM DTF Fireworks Extravaganza. Intro before the show - YouTube
    TEAM DTF
    94' Yukon.
    99 Silverado
  15. #44
    kylediablo's Avatar
    Aug 2008
    chatham, il.
    602
    some more progress today after the show, 5 hours of sanding and a half a can of rage later...
    PRIMED!
    re- sanded the low/ high spots
    TEAM DTF
    94' Yukon.
    99 Silverado
  16. #45
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    Dude you do some amazing work! I CANNOT wait to see the finished product. Subscribed to thread. Keep the updates comin!
    G
+ Reply to Thread
