Page 8 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 106 to 120 of 187
Reload Thread: martian's 2001 buick build log
  1. #106
    martiandancer31's Avatar
    martiandancer31 is offline Front Towards Enemy
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    Re: martian's 2001 buick build log
    today's haul was much less epic than yesterday:
    wiring cups, lol
    i also cleaned the garage so that i could squeeze my car in there and keep it away from all those filthy meddling communist children roaming the streets tonite
    man, i miss this hopefully i'll have time for it soon!!
  2. #107
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    built some tweeter rings for the front (will be installed later)
    working on mounts for amps:
    screws into t-nuts on the other side
    and....amp is mounted
    only had time to make one ground but there will be i think about 7 in total - two for each spare battery, two for the sub amp, and one for all the other amps
    i hooked up a temporary setup so that i can at least listen to music when i'm driving around. I was actually very dissapointed with how not loud this is, although i seem to have a problem - when i turn it up to a certain point, the CD just starts skipping and i can't really turn it up anymore. So i guess i really have no idea how loud it is, lol. Plus, the way everything is wired is really crappy and i only have one spare battery atm, sooo......
    much more stuff to come, don't worry. Might start slowing down once i get stuff in there on a more permanent basis (and wired better...)
  3. #108
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    Working on putting the cover back over the back deck - oddly enough, 1/8" composite doesn't exactly meet my standards for "acoustically transparent", so some of it had to go:
    ready to go in:
    putting CCF and MLV over the back deck:
    also, I put some grill cloth over the speakers to hopefully help shield them from UV rays.
    I did get the cover back on but no pics, sorry.
    More to come!!
  4. #109
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    huzzah!!
    my second additional battery gets here on wednesday so it's all uphill from there. Wiring wiring and more wiring to come, be prepared for mayhem ya maggots!!
  5. #110
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    impedance sweep of box:
    seems like the 30 Hz tune was sucessful, but i'm a little bit surprised as to how high the general impedance seems to be, because i'm "technically" wired down to 1 ohm.....interesting.
  6. #111
    JeepGuy's Avatar
    JeepGuy is offline Member
    Oct 2011
    Naples, FL
    81
    19 Post(s)
    I have read this thread from start to now and I'm really excited to see how this things sound when it's done.
    - 1995 Jeep Wrangler -
    Under Mass Transformation!!!!!!
  7. #112
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    Quote Originally Posted by JeepGuy View Post
    glad you enjoyed. There should be a vid or two up by thanksgiving!!
  8. #113
    KnightWhoSaysNI's Avatar
    KnightWhoSaysNI is offline Senior VIP Member
    Mar 2007
    Oregon
    324
    23 Post(s)
    Wow! Great build so far! That's a hell of an undertaking. One question, what the hell is all over your Goliath????
  9. #114
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,131
    113 Post(s)
    in 4 vids
  10. #115
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    Quote Originally Posted by KnightWhoSaysNI View Post
    ha, the guy who i bought it from packaged it with some sort of stick foam....and i didn't have time to clean it all off before i mounted it
    Quote Originally Posted by Tony30cl View Post
    in 4 vids
    AWWWW YEAH
  11. #116
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    kind of a teaser update here, more/better pics and vids coming, don't worry!!
    setting up my isolator relays:
    mocking up everything to make sure it fits:
    it's a pretty tight fit over on the left side but it's all good.
    hooking up sub amp before it's mounted (all wiring going to it is 2/0 OFC welding wire):
    thus far, altho not shown in pics, the back deck speakers and subs are hooked up. I still have issues with the CD player skipping at high volumes, but I was able to borrow an ipod and kick this thing and it's pure brutality lol. I do have some very minor dimming when the car is idling and i'm playing it really loud but i guess that's to be expected.
    I still have some minor electrical work to do - for example i currently only have one of the two 1/o runs going from the alt to the main battery hooked up, and i have one more run of 1/0 from the main batts to the secondary batts that needs to get hooked up. Also, some better wire management in the back is needed, etc. I probably won't bother with wire management until Christmas break tho because at this point in the semester i'm pretty slammed.
    But coming up over christmas break is the SQ side of this which will be my personal favorite
  12. #117
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    i gave my sister a little demo today and she was kinda surprised at how loud it is, lol. So was I
  13. #118
    silveradokid's Avatar
    silveradokid is offline The Hope that lies WITHIN
    Mar 2011
    Orange County
    160
    I have one thing to say, dude you're crazy lol. Nice build though, very extensive! I haven't checked on it in a while and you have got quite a bit done, good job, looks like you are almost done!
    "Take Your Flame, and IGNITE the world"
  14. #119
    Nov 2009
    Los Angeles, CA
    1,725
    11 Post(s)
    Quote Originally Posted by silveradokid View Post
    ha thanks man, a lot of stuff is done but eventually I would like to clean things up in the trunk a bit cosmetically which could be difficult, i'm not sure. Still need to do the SQ speakers in the front location and get two more amps wired in for those, still need to do some deadening and soundproofing in the doors, etc. In short I have plenty to keep me busy and poor over Christmas break that's for sure.
  15. #120
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,428
    6 Post(s)
    Looks good bro.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
