Page 5 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 61 to 75 of 187
Reload Thread: martian's 2001 buick build log
  1. #61
    martiandancer31's Avatar
    martiandancer31 is offline Front Towards Enemy
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    Re: martian's 2001 buick build log
    mounted one woofer to test excursion and make sure that it wouldn't hit the back seat
    unfortunately i had to use a CD player to output the test tone because my zune can't drive the behringer amp well.
    i think there's just enough room. Maybe 1/4" of clearance at full excursion. That'll do.
    glory shot. These are some **** woofers
  2. #62
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    prepping for some glassing in the trunk
    wire mis-management
    weather's supposed to be crappy on the entire east coast for the next couple of days, but i'll probably try to do work anyways!!
  3. #63
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    it's alternator time.
    this weekend is sub-box building time. fo sho.
  4. #64
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    don't worry, it doesn't make much sense to me either. The pieces of paper are pieces of wood that will end up on the bottom of my box somewhere.
    this was annoying. Pieces of wood got cut and taped over, and glass got put on stuff. More coats tomorrow and then I pull it out of the car (hopefully) and really go to town.
  5. #65
    silveradokid's Avatar
    silveradokid is offline The Hope that lies WITHIN
    Mar 2011
    Orange County
    160
    2 Post(s)
    Looking good man
    "Take Your Flame, and IGNITE the world"
  6. #66
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    Quote Originally Posted by silveradokid View Post
    Looking good man
    thanks!! been working hard on it!!
  7. #67
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    molds out. I'll be beefing these up big-time with mat once it comes in the mail but until that point i'll work on the sides and the top. plenty to do there anyways.
  8. #68
    05trailblazer's Avatar
    05trailblazer is offline k33p groaning son :)
    Mar 2011
    Dallas,TX
    2,048
    194 Post(s)
    cant wait till u post some vids of the setup bro
    HU:Pioneer 80-PRS
    Fnt&Rear Spkrs: 8 Neo-Pro-v.2 soon
    Mid Amp: Sax-50.4& Sax-200.4
    Subs: 4 Sundown Audio 18s Z v.4 tuned at 15hrtz
    Amp: 2*NS-1s
    batts:,xs2500,xs3000 x20
    wire:0g OFC Audio Technix
    alt: 3 HO alts from??? from mechman or singer?
  9. #69
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    Quote Originally Posted by julio13 View Post
    once I have something to post vids of, I will!!
  10. #70
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    molded the right side of the trunk today:
    this was a giant pain in the ballsack, mainly because of the trunk opening and closing. Essentially, I built a small frame in that area that barely clears the bars in both the open and closed positions, hot glued it into the trunk (for easy removal later), then taped around that. I made a small mistake due to the wire looms attached to the trunk lid but it's an easy fix (or ignore, really. I could just get rid of the stupid looms....). The other side doesn't have the same problem so it'll be a tad easier.
    mold glassed and removed from the car. Later i'll be beefing up all three molds with lots of mat and resin. Probably another 2 gallons worth of resin or so. Also, there's a technique that you can use to add curves (strength) to the mold which I will do as well. All of this nonsense will be braced extensively as well, hoping not to lose any SPL to a weak box.
    i have monday off school so it's possible that lots of stuff will happen over the weekend. Stay tuned.
  11. #71
    lilboom's Avatar
    lilboom is offline Car stereo for fun
    Aug 2009
    ca
    679
    30 Post(s)
    This is awesome cant wait to see it done.
    CAR STEREO INTALLATIONS Enclosures
    Custom car modifications
  12. #72
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    more pics showing what I did, i'm too lazy to explain most of them but you'll figure it out.
    that kinda sort shows how and why my side molds ended up like they did. The idea of all this is to get as much volume from the trunk space i have as well as reduce added weight, since MDF is both heavy and takes up a lot of space.
    Lastly, some pics of why I mounted the tweets/woofs for the back deck in the positions I ended up with - you can see what I was dealing with. It was annoying.
  13. #73
    Subcut's Avatar
    Subcut is offline Junior Member
    Dec 2010
    Kansas
    Man this is a crazy build, specifically all of the fiber glassing. If this turns out right, you might want to consider a ridiculous amount of security measures. Like making it really hard to open the trunk, and also very difficult to move the rear seats. Either way looks like it will be a very fun car to drive when it's done.
    Have you considered where you're going to put two amps large enough to run those subs? When I got my setup I anticipated running my sub at double RMS, but now that it's all together I would suggest more. I would also suggest looking at an AQ amp, as mine has exceeded my expectations, especially considering the small space with no ventilation.
  14. #74
    Pioneer~Saturn's Avatar
    Pioneer~Saturn is offline Dr. Enclosure
    Jul 2006
    Dayton, OH
    29
    5,318
    2 Post(s)
    Looks good, man.
    <First and only dual-alternator 'real' Saturn (pre 2002) on the planet>
    Team Concepts, Team Shok Industries Team XS Power
    Soon: Mystery subs + AQ20k
    12.75 cubes net ~25Hz tuning 200 sq inches of port (lowz?)
    AC position- 250 amp alt
    Stock alt position- 225 amp alt
    (2) XS Power D3100's
    4 power+ 4 ground runs of 1/0-gauge to rear
    152.1 @ 40Hz legal, certified...just getting started.
  15. #75
    Nov 2009
    Los Angeles, CA
    1,727
    298 Post(s)
    Quote Originally Posted by Subcut View Post
    thanks man, appreciate the feedback. I am most definitely taking ludicrous security measures - in addition to all the audio equipment, i'm installing a completely custom alarm system that i'm building from the ground up. I'll be writing the software for it as well. I will NOT be documenting it here tho as that could make my system vulnerable, and people would know how much of a nerd I really am Believe me tho if you try to break into my car you'll be in for a nasty surprise.
    currently, I have a hifonics maxximus, which I figure will give me 3500 rms watts to each sub. However, i want to sell it and run 2x AQ2200 which I believe can be strapped to 1 ohm. I need money to finish all this up, all that fiberglass is pricey!!
    Also, i'm leaving enough room for about 5 amps (the maxximus is HUGE, and yes, it's included in that) towards the trunk opening from the box, as well as for some....other stuff.
    Quote Originally Posted by Pioneer~Saturn View Post
    Looks good, man.
    thanks!!
