making the back template
making the bottom piece
mounting some supports
This is an idea, the first templates will be a stealth look, 2nd set will have a window(s) and some design on the back template
Very nice. I would've mounted the amps on the other side of the box though so it's all hidden. But still nice.![]()
Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
Ya the first templates actually going in will be full stealth. So that bottom template will have no windows and be carpeted. Then when i open the trunk itll just look compact. Id like to make some nice display pieces for some car shows this summer. Then use these "stealth" panels when im taking trips or just cause! I will get more pics up tomorrow, i have the back template carpeted. Going to make the new bottom one tomorrow and get it carpeted. And thx bro!
Heres some more stuff. Shes done for now until i make the nicer templates that ill swap in and out with the stealth set.
Gettin the Kenwood Double din in, hooking up the steering wheel control interface with it.
doin the rear 6x9 templates to fit the VR 6" comp set, mounting the crossovers on the right side of the box in last pic
And finishing off the bottom piece. Installed a 3" pc cooling fan to assist in case it gets too hot and a relay for all the remote leads.
meh
Refs: mrmakinmoves[SCAMMER] AKA ICHASEPAPER2010, skydeaner, fukinmovin, mossberg385t, grimreper912003, LBC99, Dbeez, Michaellane, thegreatestpenn, truckstoy, ge_off_me, btr, cupid6969, johnprdeye, jh8909, tylerj, UMWDawg92, nu2spl, zerosktr111, SPLAUDIO, $LICK CALIFA$, jfroghobo
Team AudioTechnix
Western Rep.
99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
-Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
-Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
-Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
-Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
-Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
dang you did some work
Jay elle is the best YO
Bookmarks
