Page 16 of 24 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 226 to 240 of 351
Reload Thread: Buck's Exploder build log
  1. #226
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,496
    149 Post(s)
    Re: Buck's Exploder build log
    Quote Originally Posted by double deez View Post
    you should pickup some raptor 4g just to compare for the lulz
    Audiopipe 4 gauge. The ring terminal is 0 gauge audiopipe, then the 4/0 "lug"
    ---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
    Quote Originally Posted by Mitch86 View Post
    Is that 2/0 welding wire? or bigger?
    i think its 4/0
    What he said.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - CT - ASE (local) - Batcap - C&D Tech - DC - eD - Excessive Amperage - Rainbow
    In Nashville? Me too! Pm me and come hangout!
  2. #227
    May 2006
    Tennessee
    5,463
    37 Post(s)
    Niceeee.. I thought it looked bigger than the 2/0 I have.I need to come to Nashville and check out your build. (and pick up those Dcons Bumpin Goalie has) Wanna help me fiberglass my door panels?
    Refs- DiabolicBass, nismos14,IonSQL,massiveaudiocw,sxpimpin,sundownz,8 7gr, nissan,Louie68,Tips,Trell,integra88,Ellsworthz,bas ebalz13,lil98cabrio,woofercooker,pro-rabbit,Louisiana_CRX,MANTI5,eL_wEEnIe,bubbagumper6 ,jco1385,95saturn,ace_800,micah_jones,assassin1840 ,beat-down69,RAM_Designs,whitedragon551,KTMrida4life
  3. #228
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    I'll help, can't say how good I'll be at it.
  4. #229
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Charleston, SC
    20
    4,013
    24 Post(s)
    How much power can that 4/0 handle?
    Get taken down to funky town on MobileAudioForum.com.
  5. #230
    May 2006
    Tennessee
    5,463
    37 Post(s)
    Quote Originally Posted by Buck View Post
    We're in the same boat then sir. Hell I have plenty to do that I could use some help on. I'm the only one I know around here that is hardcore into audio. I gotta do the big3, run my power wire right, run my rcas right, better ground, finish fiberglassing tweets into the a pillars, figure out what I'm going to do about mids, and I'm sure there is more. Always so much to do and little time to do it though.
    One of these days I'm going to get out towards Nashville, I'll hit you up!
  6. #231
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    Quote Originally Posted by The Artist View Post
    In the runs that I have, probably 500+ amps.
    I pm'd you.
  7. #232
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    Did the big 2- alt pos to bat pos and alt case to bat neg.
    These were a bitch to crimp:
    Pics of install:
    Hmmm, I have a few terminals on this post, no?
  8. #233
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,409
    6 Post(s)
    so how come you didnt fuse the alt to bat? just wondering cause i kept getting mixed sayings from everyone. so to be safe i fused it for my big 3.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
  9. #234
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    Just no need in my mind, but it all depends. Those are not coming off. I could pull a vehicle with that 4/0.
  10. #235
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    Charging voltage is quite a bit higher, around .3-.4v. I haven't play my system much because the rear hatch panel was off, but from what I can tell that voltage has really made my sub stage sound quite a bit better.
  11. #236
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    The big "2" I did actually made my system louder. Loud enough where I almost want to turn it down. I guess that slightly higher charging voltage helped out quite a bit.
  12. #237
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    Ok did some ghetto work on my box. The 2nd baffle isn't flush because the screw heads didn't go all the way into the first baffle, so I had air leaks. For a temp. fix I duct taped around the whole box. It got louder. Then I turned my amps up a little more, and it got A LOT louder, and then my window started making weird noises so every time I roll it down it pops right before it's all the way down.
  13. #238
    May 2006
    Tennessee
    5,463
    37 Post(s)
    Lol come on man... just take the screws that are sticking up out of the first baffle. If its glued properly it shouldnt be a problem!
  14. #239
    Buck's Avatar
    May 2008
    Nashville
    17,496
    149 Post(s)
    Alright, subs are out, head liner is out. Adding some extra sheet metal to my roof. Pics brahz:
    ---------- Post added at 01:59 PM ---------- Previous post was at 01:59 PM ----------
    Wow my tint is dark, that's in broad daylight.
  15. #240
    JL Audio's Avatar
    JL Audio is offline ThugStep
    Dec 2006
    KY
    12,612
    9 Post(s)
    I noticed you said thanks to dave_damage you have that large wire. did he sell you some or? he's owed me money on a refund for a year now and hasn't attempted to pay back unless I constantly pm him.
