Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Reload Thread: $1K build 2005 Equinox. First time attempting anything audio related.
  1. #31
    daboyfrumdabx's Avatar
    daboyfrumdabx is offline CarAudio.com Elite
    Dec 2009
    Pleasant Mt., PA
    28
    1,199
    39 Post(s)
    Re: $1K build 2005 Equinox. First time attempting anything audio related.
    That amp will give you [email protected] to work with on that third channel. Dual voice coils exist to create more wiring options. In your case, you'll want a sub that is either single 4 ohm voice coil, or dual 2 ohm voice coil. A dual 2 ohm can be wired in series to create a 4 ohm load like you need or it can be wired in parallel to create a 1 ohm load in case someone had an amp for it that did it's power at 1 ohm.
    *Sundown Z15 *SAX-1200D *CDT HD-61A *SAX-100.4 *Pioneer DEH-80PRS *KnuKonceptz *XS Power D3400 *270A Mechman
    Sold to: blackbonnie, TheOneJordan, resko1, kr15, Zichardruniga, IBmikexxx, plugitin
    Bought from: Gruszka530, theMessenjah44, ltr450racer690, Dpc69ss, 97maxima(Here and ROE), Pillow(CACO), pro-rabbit, woofercooker, Twisted_0912
  2. Thanks Jordan Cole thanked for this post
  3. #32
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
  4. Thanks Jordan Cole thanked for this post
  5. #33
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
  6. #34
    Jordan Cole's Avatar
    Jordan Cole is offline Junior Member
    Jan 2011
    Nottingham, Maryland, United States
    15
    Amazing information in those links. If that 5ch is still there in 10 days it's mine. Along with the sub, and component speakers. Now it's time to copy and paste and start filling my carts.
  7. #35
    Nov 2010
    Brandon , FL
    36
    4,627
    10 Post(s)
    Quote Originally Posted by LaserRed38 View Post
    Yeah? And? That is true, if that's the OP's goal. That has nothing to do with recommending a set of MTX anythings in an MTX box with a Kenwood amp. Just...no.
    Shut yo mouth!! Blue thunder amps and old school Thunder series will smash most any affordable amp in the same power range. Them bishes were BEAST. Great SQ , awesome power. 4500 subs????? NO!!! LOL. Chinese garbage , but the old school MTX amps were beast and the old school subs were decent. Don't use any NEW mtx stuff , it *****.
  8. #36
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
  9. #37
    Bumpin' Goalie's Avatar
    Bumpin' Goalie is offline Magic 8 Ball
    Nov 2009
    TN & Travel
    3,163
    3 Post(s)
    I had a feeling mclerico would find this thread and plug away
    System Layout help available via PM.
    My system:
    Sounds good.
  10. #38
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    Quote Originally Posted by Bumpin' Goalie View Post
    amazing deal that 5 channel with a dcon give it 400rms, put some image dynamics up front
  11. Thanks Jordan Cole thanked for this post
  12. #39
    skdooley's Avatar
    skdooley is offline Member
    Nov 2010
    Roanoke, Virginia, United States
    114
    3 Post(s)
    8 Post(s)
    The voice coils will determine the final ohm load you can wire it up to the amp at. When running off the amp, 1 ohm is going to be the least efficient and 4 ohm will be the most efficient. Of course 2 ohm would be somewhere in the middle. Efficiency means how much current the amp is drawing off your car in order to produce the power its creating. For example, if you have a 500 rms amp and say it's 80% efficient, 500/0.80= 625. So your electrical would be seeing 625 watts, while your amp would be producing 500. This is important so you don't pull more current than your alt and battery can handle. It'll also be important to upgrade your big 3 and be sure to have a solid ground in the rear for your amp. Most amps are rated at 14.4 input voltage and as the voltage drops, so will the output from your amp. Maintaining your voltage as high as possible helps with your overall output from the amp. Different ohm loads as determine dampening over the sub, this is important for sound quality. Some people will say you won't be able to hear the difference from 1 ohm or 4 ohm, but 4 ohm will offer greater dampening than 1 ohm will. Dampening is basically control over the woofer. When the tone the sub is playing stops, how quickly does the woofer respond. A single voice coil will do as stated, a dual voice coil, by itself will go up or down from its stated ohm load. A dual 2 ohm can be wire 4 ohm or 1 ohm and a dual 4 ohm can be wire to 8 ohm or 2 ohm.
  13. Thanks Jordan Cole thanked for this post
  14. #40
    skdooley's Avatar
    Nov 2010
    114
    3 Post(s)
    8 Post(s)
    As people are posting, if you're looking for the most for your money, buying used is a great idea. You an find some great deals. Also keep in mind that not only the equipment you choose to go with is important but the install is just as important. Install can make or break a system.
  15. #41
    Jan 2011
    15
    Thinking about installing a system is what got me started wanting to build my own. Now I'm in the information overload zone. I've read you have to install a Cap before the amp to prevent the lights from dimming. There has to be more of reason than that.
  16. #42
    Nov 2009
    TN & Travel
    3,163
    3 Post(s)
    Quote Originally Posted by Jordan Cole View Post
    99.9% of people here will tell you to avoid capacitors...I am one of them.
    If you need an "electrical buffer/band-aid" without grabbing an expensive alternator, grab a small Shuriken or something similar. Though it may not be necessary with your vehicle and the options you choose.
    I would think it'd NOT be necessary, if I was a betting man.
    My system:
    Sounds good.
  17. Thanks Jordan Cole thanked for this post
  18. #43
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    do not get a cap, waste of money.
    either get a bigger alternator or a small battery but with that cadenc eamp you will be fine with no dimming imo,
    SHURiKEN SK-BT20 High Performance Battery 20AH 850 AMP - eBay (item 170511479587 end time Feb-04-11 15:08:39 PST)
    something like this would be much better then a cap
    Xstatic BatCap Model 300 - eBay (item 160530402639 end time Jan-17-11 08:38:13 PST)
    or this
  19. #44
    Jan 2011
    15
    Quote Originally Posted by mclerico83 View Post
    This is the plan so far. I tried posting what I'm going with so far, I guess a moderator has to check it out before it gets posted.
  20. #45
    LaserRed38's Avatar
    LaserRed38 is offline Premium Member LaserRed38 is a Supporting Member of the forum!
    Nov 2007
    Bay Area, CA
    2,373
    1 Post(s)
    39 Post(s)
    Quote Originally Posted by Bassin Buick View Post
    Okay, you know what I meant. I've been around the block. I meant current MTX stuff.
    2005 Escape XLT Sport
    Alpine CDA-9835 - Audison LRx5.1k - Hertz MLK 2 TM - Hertz ML1600 - Hertz HX300
    Audison Wiring - Optima Red Top - Dynamat Extreme
    Refs
    [Bought from] dcmcki, 90accordman, MikeyB, itzme218, redcalimp5, SVT_RELAMPAGO, Johnny_Drama, RollinGTO, Fast1One, tc3k101, ramk1018, Brian_Smith06, John_Pionke, BigOso, TeamPSI, pickup1, PatFitz9, pro-rabbit, oldschoolboomer
    [Sold to] darqnez, tipnitty, Mugatu0, MrChow, nineball, SocialStealth, macq32, .livin.loud., slappinX, GlassEyez, Jeremy M, Honez
    [Traded with] James Bang, MovnZ28
Tags for this Thread
