Current 2010 Louisiana USACi State Records :
Trunk 0-1000.................. 151.3
StreetBeat 2................... 145.6
Stock 1801-up.................153.8
SuperStock 1801-up..........154.2
Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
holy ish, is the man gonna finish a build?!?!
1996 Mitsu Clipse GSX 450whp
1997 Eagle Talon TSI
refs:
wes007parks, ridinswangaz, madmat, treylittlefield, mendezm9
MHD2000, RetroAudioInc, power-fanatic07, Carnivorous18, Spltuscon
Ridinhi, Wingsfreak9, Pro-Rabbit, 2000LaDe, nom nom
DBBOOM, hrtbrk1, dgaf_, dirtbikkerrob, Nik592, SkylineTT
Looks good so far, you oughta make some 3/4 MDF plates wrapped with carpet to mount the amps on. Cut slots in it under the carpet so you can run wires through and clean the wiring up.
Im better than you.
Old School Blaupunkt SQ deck...this deck has a built in 5 band para EQ and a lot of other neat features.....
Deck hid from view behind factory radio door.....
Jh8909 thanked for this post
refs:
Controlled by custom Blaupunkt steering wheel remote when behind cover...This is the same Blaupunkt setup used in newer Lotus vehicles ......
Nice
1995 Explorer
4 18" AQHDC3s
2 AQ 3500D.1s
1 HC2000 & 4 134ah C&D Batts
1 DC Electric TAD270XP Alt
157.8 @ 41hz
FEEDBACK: http://www.caraudio.com/forums/buyer-seller-feedback/448902-aqhdc3s-feedback-thread.html
man just put some a8 turbine wheels on the TT and call it a day
nice car
First hair trick... more to come -----> http://www.youtube.com/watch?v=tbfADio5CjQ
158.1@44hz usaci
155.5 @44hz Usaci Streatbeat
154.7@44hz MECA
130.4@44hz MECA Driveby
Team XS power
Team SecondSkin
no one liked them in a thread i done earlier so i went another route...i thought they looked sharp...those are 19's....i stayed with 17's on stock size tires...but 33mpg on the hwy and 27 around town.....and about 200hp on tap in such a lite car isn't bad...i also did away with the stock exhaust and went to a stainless steel Borla exhaust...
well if you get better mpgs on the 17 then so be it, but you're a man with many cars, so it shouldnt be an issue aye? Dem turbine wheels broham
Bookmarks
