Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 88 of 88
Reload Thread: Extended cab s-10 Audioque build
  1. #76
    jake760's Avatar
    jake760 is offline CarAudio.com Elite
    Feb 2007
    OR
    27
    523
    Re: Extended cab s-10 Audioque build
    Personally, I would upgrade electrical and run it at 0.5. You could always buy another AQ amp and run one on each coil @ 1 ohm.
  2. #77
    Basshead21's Avatar
    Basshead21 is offline Member
    Sep 2010
    Wichita, KS
    30
    Anyone ever wired a single Audioque HDC3 15 to a AQ1200 using 1/2 ohm? Any opinions or personal experiences? I would really like to keep this sub if its possible.
  3. #78
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    Quote Originally Posted by jake760 View Post
    I am getting a performance alternator very soon, what amperage should I get to run this system? Also I did the big 3 already. My battery is about 4 months old, it is not a performance battery but I think it will do the job.
    Thanks for the input brah.
  4. #79
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    go with the largest amperage you can afford, which outputs full power at the lowest rpm possible.
    you will still need batteries
  5. #80
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    Okay, I am going to get a performance alternator, upgrade to 0g wire, and get a performance battery. Should I get a D2 sub? Or should I just run this D1 @ 0.5 ohms? From what I have looked at stinger batteries, and alternators are the way to go. I really don't have any room for a second battery so I am trying to get one single ballin *** battery. I am confused on what kind of alternator to get. How many amps? I know get the best one I can, but I am running one HDC3 15 2000 watts off of a AQ1200 amp. Would like a 160 amp work? And I was thinking or an optima yellow top battery? I am a super noob at this, this will be my first alternator/battery upgrade ever so any advice on what to do is appreciated.
  6. #81
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    Bump for someone trying to help out a noob.
  7. #82
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    What's the size of your stock alt? Can't be too low in a truck. Honestly, I don't think running the 1200D at 1/2ohm is going to cause you any issues so long as you have an extra batt close to the amp. Now if you plan on upgrading to substantially more power, then a HO alt or dual stock alts would be the way to go.
    2,500+ designs since March 2011
  8. #83
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    I have a stock 100 amp alt, with a Autocraft gold 75-3 battery. There really is not room for a 2nd batt, but I understand if I have to I'll find room somehow. Here are the specs on my current battery.
    Group Size: 75
    Voltage: 12
    Cold Cranking Amps (CCA) @ 0F: 700
    Cranking Amps @ 32F: 875
    Reserve Capacity (minutes): 100
    Terminal Type: Side Terminal
    The previous owner of my truck also had a sound system so when I bought it, soon after my old alt and battery went out. These were just replaced like 4 months ago. If anything I should grab a 150 amp alt? Thanks again for all your help, I hope to see this system up and bumping soon.
    Luke
  9. #84
    Towncar's Avatar
    Towncar is offline CarAudio.com Veteran
    Dec 2005
    who knows
    4,359
    18 Post(s)
    I wouldnt go with a low tune with the aqs. They do better with higher tuning, but still have no issues with the lows. 35 would be the lowest I would go, but closer to 40 would be better. 37-38ish seems to be a great daily choice for them.
    Quote Originally Posted by Terranova View Post
    The gain is set around 750 right now. I need to get together with my buddy and plug his stethoscope in to set it to 1000.
    Quote Originally Posted by infamous_e46 View Post
    Start fcking one of the guys in the *** to make her jealous
  10. #85
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    Quote Originally Posted by Towncar View Post
    The box is already built at a 34hz tune brahh.
  11. #86
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    Hmmm I decided to run it at 0.5 ohms. What connectors do you guys use to go from your wires to the terminal cup? I am going to solder, and use wire wraps, but what connectors should I use? Spades rings, or knives?
  12. #87
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Don't wire to 0.5 without upgrading your electrical first
  13. #88
    manny1337's Avatar
    manny1337 is offline CarAudio.com Elite
    Sep 2009
    Mass
    1,136
    Quote Originally Posted by allcrispedup View Post
    this!
    i would get something big upfront and matching for the back (batts) before doing .5 on an aq amp. 2 runs of 1/0 (pos/neg)
    Refs: BLD 25 - bsean63 - Loud3 - blackv62009 - spltuscon
    BUY MY STUFF
    http://www.caraudio.com/forums/car-audio-classifieds/499741-alpine-ida-x100-fi-q-12-infinity-475a.html
