Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 88
Reload Thread: Extended cab s-10 Audioque build
  1. #31
    reflecting's Avatar
    reflecting is offline CarAudio.com Elite
    May 2009
    midwest
    619
    Re: Extended cab s-10 Audioque build
    Quote Originally Posted by snfsh79077 View Post
    At what frequency? What was the setup? I find that hard to believe. Maybe a 155 burp but not on music with subs and port up.
    OP should do subs forward and port up as it will work great for daily.
    8.5ft3 after displacement(pretty much all available room there was) tuned to 35hz. Had 2 DD 9515 d2 with a HK4KD for daily and two for shows. Never swapped ports or anything..let me see if I can dig up some pics and more specs on it. It has been a long time since I had this build....
    SOLD TO-Kinglowlife, DBBOOM, dave_damage, way2sl0, Johnny Law.Lulz, jmj
    BOUGHT FROM-GavinVoy, aaronrchr, cmiller8006, Chevyaudio, Twisted_0912, bigbirney420, 05_ZX636,
    Traded with- Pro-rabbit(also bought/sold with him), Mr.Ronin_2U
    !!!DO NOT SHIP TO ME USING USPS!!!
  2. #32
    reflecting's Avatar
    May 2009
    midwest
    619
    This is what I could find..sorry but this is all just guess work from a note book I had the design in(I'm sure it is not exact as I tend to change things when I actually build it)....
    Ruffly-54x21x19 ish Going to be just under 10ft3(Before displacement)
    10 x 19 port(not sure on length or exact tuning)
    here are a few pics though
    OP-do sub forward port up if your a tall guy subs up ***** bad...I had no room to move back then.
  3. #33
    snfsh79077's Avatar
    snfsh79077 is offline Ladie's like my pole
    Sep 2003
    bay st. louis/baton rouge
    24
    2,297
    I still don't see 55s on music with that. I can see a 55 burp with both amps but from my experience helping build a world champion s10 and picking the brain of a s-10 guru I know how hard it is to get certain numbers. Do you remember the peak of that setup? The peak freq of s-10's is 70+hz.
    HU: Kenwood KDC-X993
    Front stage: (2x) Shok CB 6.5
    Comp amp: Crescendo 1000c4
    Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
    sub amp: Crescendo 3kw
    Electrical: Mike Singer 250a alt w/ext regulator, D3100, NSB100, D680, 50ft of shok cca
    149.5 @ 39hz and climbing...
    Plenty of refs between here and caco....
  4. #34
    reflecting's Avatar
    May 2009
    midwest
    619
    this setup peaked at 52hz on burp. This was also on a 16 volt setup as well. Let me see if I can dig up some results from back in the day...
    Personally I don't see 155 to be a hard number to get in a S10 with good power and subs. Now anything after that is a *****. I did play around with some burp boxes, but was never happy with them. I never got to run at a show with the burp box do to the wreck though.
  5. #35
    reflecting's Avatar
    May 2009
    midwest
    619
    I couldn't find any results, but after talking with a buddy(who competed that year with me) he said it did a 155.2 burping and 152.? on music... I guess that is what it did then. Sorry for the confusion. It has been several years and many builds since then.
  6. #36
    reflecting's Avatar
    May 2009
    midwest
    619
    I would assume you are talking about rob and his box style s10?
  7. #37
    snfsh79077's Avatar
    Sep 2003
    24
    2,297
    Quote Originally Posted by reflecting View Post
    That sounds more like it. No problem on the confusion
    No jimbo from team big un
  8. #38
    Basshead21's Avatar
    Basshead21 is offline Member
    Sep 2010
    Wichita, KS
    30
    Yeah buddy. Things are coming along, just need a blueprint now.
  9. #39
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    I just installed a new battery and alternator because the old ones went bad. I am a super noob at all this stuff. To get another battery would I need to get a performance alternator?
    I am trying to get a hold of a design for the box, I plan on getting started tomorrow!
  10. #40
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    updates?
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  11. #41
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    I got a design from Ryan (RAM_Designs) and I gave him the wrong dimensions, then he completely redesigned for free. Ryan is very legit, I would recommend him to anyone who needs a design!
    I got all the pieces cut out, and pre drilled all the holes. I am gluing the first part tonight. I do not own a scroll saw, so I am taking the top piece to a different shop to cut the sub hole, and port. I still need to cut one of the corner 45's. The saw I used did not have anti-kickback guards, one piece of wood to the stomach is enough.
    Any major tips for gluing???
    Anyways here are some pictures. (taken on my phone, sorry for the quality)
  12. #42
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Don't use a ton, but make sure there is enough. also make sure to clamp it evenly and make sure the pieces stay at 90 degree angles, the wood tends to tilt when you clamp it.
    REFS:
    Sold to- Sky Deaner, Jeeper07, brazilianguy, bjl95mustang, Mr Wiggl3s, Ridinhi (x2), Pootie
    Bought from- kurtdirt1, jmanpc, doingstuffwell
    Traded with- DaGhost, Spooney
  13. #43
    Basshead21's Avatar
    Sep 2010
    Wichita, KS
    30
    Are clamps completely necessary? I was planning on putting the glue down, then screwing the boards together.
  14. #44
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    22
    6,408
    Quote Originally Posted by Basshead21 View Post
    Clamp, predrill, unclamp, glue, clamp, drill screws, remove clamp, let dry.
  15. #45
    miker's Avatar
    Oct 2007
    Wayzata, MN
    5,326
    Without a few clamps you will have a hard time keeping everything square. I would recommend investing in at least a couple bar clamps and one corner clamp.
    I don't even use screws...
    REFS:
