Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Reload Thread: TaylorFade's run at USACi World Finals.
  1. #31
    budahbuddy803's Avatar
    budahbuddy803 is offline CarAudio.com Veteran
    Feb 2006
    Brunswick, GA
    4,860
    14
    32 Post(s)
    Re: TaylorFade's run at USACi World Finals.
    Quote Originally Posted by cablguy184 View Post
    Rating of your amp(s) at a 4 ohm load ...
    I stood by your truck when it was int the lanes at finals ... suprised alot of people ... great work bro !!!
    is that total power to the subwoofer I guess, rated at 4ohms? If i had 10 amplifiers all with a power rating of 6 watts @ 4ohm I would be in the same class? Power to highs and mids do not count right?
    Vehicle: 2009 Pontiac G5
    Head Unit: Pioneer AVH-X3700BHS
    Highs: Image Dynamics XS28
    Mids: 6-1/2" Poly Cone Midbass Woofer 4 Ohm
    Subwoofer: Image Dynamics IDQ12d4v4
    Amplifier: Kenwood XR 900-5
    Battery: Kinetik HC800BLU
  2. #32
    cablguy184's Avatar
    cablguy184 is offline SQ "White Lightning"
    Oct 2010
    Rankin Co. Mississippi
    46
    498
    49 Post(s)
    Quote Originally Posted by budahbuddy803 View Post
    Wow ... This comming from a caraudio.com veteran with over 4000 post ...
    ok bro ... here it goes ....
    USACI super stock 0 - 600 rules ...
    1 amp with a 4 ohm rating at 600 watts and under, sub enclosure behind the b pillar and below the glass. 2 batteries max and nothing over 14.7 volts.
    Most competitors in this class has no mids and highs .... spl run, no music, using test tones.
    Randal Johnson ... Comcast Xfinity ... 1997 Chevy Silverado 1500 Extended Cab ... 1949 Ford Custom Tudor Sedan
    Linear Power (TIPS) / Blues Car Audio ... Audio Technix ... Hyper Automotive LEDs and HIDs ... Mississippi Street Rod Association
  3. #33
    snfsh79077's Avatar
    snfsh79077 is offline Ladie's like my pole
    Sep 2003
    bay st. louis/baton rouge
    28
    2,297
    That would actually be stock not super stock
    HU: Kenwood KDC-X993
    Front stage: (2x) Shok CB 6.5
    Comp amp: Crescendo 1000c4
    Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
    sub amp: Crescendo 3kw
    Electrical: Mike Singer 250a alt w/ext regulator, D3100, NSB100, D680, 50ft of shok cca
    149.5 @ 39hz and climbing...
    Plenty of refs between here and caco....
  4. #34
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Thanks, man. I was pretty sure I was gonna get killed so I was really pleased with a 2nd and only 1 tenth off of the world record!
    You can have highs amps and stuff but the only amp that counts is the one used on the sub stage. CableGuy is right about the rules. 1 amp. 2 batts. 14.7v max. Box below window line and behind b-pillar. They use the published manufacturer 4 ohm rating of the amp you are using. i.e.- AQ2200 = 500w @ 4 ohms.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  5. #35
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    So to answer your question... no, you can't have 10 amps rated @ 60w. I got hung up on the Cactus pf600 for a while because it was [email protected] ohms and my D5 is only [email protected] Lol. I was like, "it has to make more power!" Lmao.
    It really wouldn't help you to have more than one amp in that class anyway because there are no 200-300 watt amps that can compete with the Cactus or D5's. Maybe if you got like 12 of the old school Orion 225's. Lol. That would be awesome. Roll up with (12) "50w" amps in stock 0-600w. That would dessimate all. Of course, you would need 12 D1 or even D.5 subs to make that work. 2 12v batts might not be able to keep up with 12 class AB amps though. Lol.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  6. #36
    cablguy184's Avatar
    Oct 2010
    46
    498
    49 Post(s)
    Quote Originally Posted by snfsh79077 View Post
    correct ... I reading / typing / working and got distracted and did not catch it ... thanks
  7. #37
    cablguy184's Avatar
    Oct 2010
    46
    498
    49 Post(s)
    Quote Originally Posted by TaylorFade View Post
    We had to pull our mids/highs amp because of the total number of amps in that class. ( in our SPL vehicle)
  8. #38
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Super stock = ~ another $2k. Lol. 18v and like 4 more batts. Yikes. The super stock 0-600 guys were 3 db+ louder than I.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  9. #39
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    That's f'n lame. I've never heard that. I run my daily in stock 0-6 all the time and it has a highs amp. Was it forward of the b pillar?
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  10. #40
    cablguy184's Avatar
    Oct 2010
    46
    498
    49 Post(s)
    3 batteries ... not much difference ??
  11. #41
    cablguy184's Avatar
    Oct 2010
    46
    498
    49 Post(s)
    I'm glad I run SQ ... less stuff ... just alot of detail !!!
  12. #42
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Is it only 3? Hmm, I thought they could have 4 or 6. I dunno, but 3db is a big *** jump from 12v to 18v. I think the guy who won SS 0-6 did a 61 and change.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  13. #43
    cablguy184's Avatar
    Oct 2010
    46
    498
    49 Post(s)
    United States Autosound Competition International (USACi) - USACi Competition Rules
  14. #44
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Wow. Getting crushed by only one more batt and 6 more volts. That's depressing. Lol.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  15. #45
    schrummy's Avatar
    schrummy is offline CarAudio.com Elite
    Jun 2008
    Ames, Iowa
    1,381
    8 Post(s)
    0-600 ss was a 160.5 second was a 160.4.... the guy who beat both you Fade and my Friend Danny was that white CRX... the sad thing is, the crx has more in it...
    Team TREO
    Team Midwest
    Team Gorilla
    USACI- trunk 0-1000 156.4 and climbing
    153 sealed on the dash
    yes its a trunk car and yes its only (2) 12s...
    refs=sold to......R/T Pimp, mustangowner, zyklonb, Miles0803
    Bought from…..2002XLT, R/T Pimp, 92c1v1c, Miles0803, camshoc, dbeez, goindef154
