Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 64
Reload Thread: Ford ranger extended cab semi-wall build
  1. #46
    bunkrd you's Avatar
    bunkrd you is offline Senior VIP Member
    Oct 2010
    papillion, ne
    243
    Re: Ford ranger extended cab semi-wall build
    built a battery rack for my yellow top d31 to sit on top of my deka. I tripple grouded my deka and used the machined posts as a d block for grounds and have two grounds to my seats that are grounded through to the chassis, two to a rear seat belt mount which also goes through to the chassis and two grounds up front to the chassis, and engine block. 4/6 of these grounds are in 2/0 and the rest in 1/0. I just ordered a us md3d and it should get pretty loud in my new box. I had a md1d previously and liked it hence why I bought the md3d.
    Also decided on polk components and a kenwood head unit.
    Polk Audio MM6501 - 6-1/2" Component Speakers System - Sonic Electronix
    Kenwood eXcelon KDC-X794 (kdcx794) CD/MP3 Car Stereo Receiver
    Can I bridge the components which are 2.7 ohms into the alpine mrp220? or would that ohm load be unstable?
    98 civic
    Jvc deck
    5.25 alpine type r comps upfront
    6.5 hifonics comps in the rear
    Speakers amp-Rockford 300-4
    Sub amp-Us md1d
    Sub-18" rd audio v2 motor with psi soft parts
    box-4.5 cubes at 33hz
    150 amp alt
    102ah bat in the back
  2. #47
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Three 3" ports for four 10's?
    What are the dimensions for the box?
    edit: I see that they're 4" aeros...still a little small, but should work alright.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  3. #48
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    lol already almost done with my second box i only had like 36 sq in of port for 7+ cubes. I now have 91 sq in on a slot port design with 6.3 net cubes tuned to 31.6 hz. I also used 2x4's for bracing on my first box and now am using 3 1.25 in dowel rods for less turbulance. Box is turning out a lot better then the first just because I took my time more and lined up all the screws to prevent splitting. Another thing I did was for the sub cutouts I had it so when the grills are on the subs they all fit about 1/32nd of an inch apart so It looks a lot cleaner. Amp will be in this week, and the components, alt, and hu will be in in around a month or so.
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  4. #49
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    one brace is going in the center, the other on the center of the 2nd length of port and the other to the right hand side. I just dont want this box to end up falling apart on me. I will paint this like I did the first box because I tried another brand of "stone" texture on my most recent fail and it didnt look near as nice as my other box aesthetically speaking. I cant wait to have teh dbz in my truck again. But my mids and highs have been SCREAMING since my most recent tuning. I just need a foth speaker amp for my stock speaker locations. Pry just end up doing a 2 channel to my infinitys in the door and leave my rockford 5x7's on hu power seeing as though they are so drowned out in the back with the box/batterys/wiring.
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  5. #50
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    so far so good
    tuned to 32.7hz with 6 net cubes with 91 sq in of port
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  6. #51
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    so after an hour with the cutouts using a hand file and sand paper I find out my dad had a dremel this whole time. Ended up taking me 10 minutes further with 2 subs to go and prefecting the other two. Front is double baffled and I braced it using 3 1.25in dowel rods on the second length of port, and bracing along the front.
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  7. #52
    crownroyal's Avatar
    crownroyal is offline BILLY MAYS HERE FOR COKE!
    Jun 2007
    myrtle beach, sc
    108
    looks much better than the first
    Your word is **** here...Tell us how brain surgery works next, you kid genius you.
    Quote Originally Posted by cotjones View Post
    What kind?
    Well split brain surgery, my favorite, is the process of cutting the corpus callosum to sever the connection between the left and right sides of the brain. Usually this surgery is only performed as treatment of severe incidents of epilepsy. The after effects of the surgery are very interesting...
  8. #53
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    Almost done with the paint just another coat of black and a clear coat. I also used a different brand of paint for my second box, but i liked the final texture of my first box so I went with that and this box is looking sweet. will have pics up tonight,
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  9. #54
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    Done.
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  10. #55
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Lets see some good pics maybe of everything put together as well.
    REFS:
    Sold to- Sky Deaner, Jeeper07, brazilianguy, bjl95mustang, Mr Wiggl3s, Ridinhi (x2), Pootie
    Bought from- kurtdirt1, jmanpc, doingstuffwell
    Traded with- DaGhost, Spooney
  11. #56
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    ill do one better Vids. But i just have a 3.2 megpixel camera on my phone. I just need to get a digital but the terrible pics are just to show that i am making progress. I am building a buddy a free box for 2 12" w6's just to get some references out there. Thinking about tuning around 30-32 hz with 3 net cubes. He is the one i sold my 2006 md1d.
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  12. #57
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    loaded?
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
  13. #58
    Sep 2008
    Virginia
    10,725
    This dude will be running a MD3D soon
  14. #59
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Quote Originally Posted by Johnny Law.Lulz View Post
    It's about time he put some real power to those L7's.
  15. #60
    bunkrd you's Avatar
    Oct 2010
    papillion, ne
    243
    I know lol everything thus far has felt like a teaser. 1000 watts in a weak box and 1000 watts on too small of port area. Now I have the box and amp its game time lol.
    Last question can I run the polk's bridged even though they are 2.7ohms it says it can be ran off hu power so i am assuming bridged at 2.7 wont be too bad. The amp is an alpine mrp220. If not I will run my door coax's off of it and get another 2 channel.
    98 civic
    Jvc deck
    Sub amp-Us md1d
    150 amp alt
