2002 suburban
Security System Code alarm
Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit pioneer 880prs
Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
Wiring lots of 1/0 stinger, tsunami
Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
Subs 4-18" nightshade v2's d2
System DetailsDaily driver.
pics posted of the box from when it was in my explorer
2002 suburban
Pretty sick setup, I was expecting higher numbers but its tuned pretty low so thats expected, I bet its still brutal on the lows. Have you clamped the amps and what are they wired to?
Got Refs? http://www.caraudio.com/forum/itrader.php?u=47119
How far are you from the louisville (hikes point) area?
2005 VW Jetta GLI
Kenwood DNX6190HD- Stinger Cables
PPI BK800.4 -PPI PC3.65C
PPI BK1300.1D- Obsidian 12 D2- 1.75@33
http://www.caraudio.com/forum/showthread.php?t=180810 feedback thread
are all the interior corners of box 45 degreed from sheet to sheet ?
is the inside of box glassed ?
tell me about what i can't see in the box bracing ?
i would consider glassing the full inside of box if not alreay, i can get you anything fron the select products line i go direct on that ?
it will be more slippery than cow snot
i would probably get 3 each 36 square foot stinger road kill bulk pack i get direct on that to
i would consider 38 and possibly losing a bit of low end but play a 45-50 tone
i would do what i told you to with your grounds
you should see 155 on music and like **** 160 on a tone or real close man i can see that thing doing 160
you need more bracing in my opinion
i know funds are not there
but bracing- glassing- higher tuning closer to 40 , deadner, different ground route, man i can 160 on tone
i know you want lows but i see higher numbers really not to hard to get you there
Alpine 9886
Digital Design 9515G
Digital Design W6.5 Mid Bass
Digital Design DD-A 5.25 Mid Range
Digital Design T2 Tweeters CDT 560I Crossovers
Crunch Ground Pounder 3000D-Pro
Rockford Fosgate T5002
Stinger Battery w/HO Alt
Stinger RCA
Stinger Wire
2002 suburban
2002 suburban
box is plan jane just the rods in it no 45's or anything tuning is going to 36 in the am tomorrow i will be doing more with deadner as soon as money becomes available. the 151 is at the headrest.
2002 suburban
your doing great
your on your way
the subs are not broken in
no rush you got time
that thing can be so very loud , like real loud
Alpine 9886
Stinger RCA
Stinger Wire
2002 suburban
i know bread is weak now
but time & effort & desire , you know man you just started this set up
you will definetly get there
sick start bro i am real excited for you
tuning won't cost , drilling and grounding won't cost , glassing will really help ,start there little by little
long trips all start with a 1st step, and each little stride puts you closer
beautiful equipment
what is voltage out on the head unit
a few completed projects each week and by years end i really see 160 on tone
Alpine 9886
Stinger RCA
Stinger Wire
yeah just gotta tweak i have a week for finals.still have to test fusing as soon as that stuff arrives.
2002 suburban
vid looks way better than i thought it would have coming from my phone love my droid x
2002 suburban
Bookmarks
