Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 46 to 60 of 107
Reload Thread: Evo VIII install
  1. #46
    Oct 2007
    Queens, NY
    26
    7,385
    149 Post(s)
    Re: Evo VIII install
    Nice EVO!
    Finally, someone else with a awd turbo that isnt a prick and knows what they are talking about lol.
    throw a fp black in that ***** lol.
    Refs : nismos14, Slammed x3, Team H&K, RetroAudioInc, 2002XLT, tc3k101, Fusion_Freak, IAmMurph, louisiana_crx, fast85_gt, Ridnclean x3,
    woofercooker, lil_italy773 x2, 1mtx1, flipx99, MSW Danny, the_greatest_penn, jco1385, walksup, darkhunter139, TurdFurgeuson2, jmanpc, explorer2,
    Jep772, 86yota, fargof, brtnboarder3241, Pitbull12887, Spooney, Phers1er,
  2. #47
    AWD PSI's Avatar
    AWD PSI is offline Senior VIP Member
    Aug 2010
    SoCal
    177
    Lol Thanks! I'm reading up on the BBK full and E85 at the moment
  3. #48
    Oct 2007
    Queens, NY
    26
    7,385
    149 Post(s)
    Quote Originally Posted by AWD PSI View Post
    0_0.
    What is your current mod list?
  4. #49
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    Quote Originally Posted by silvercookie View Post
    0_0.
    According to the shop and tuner I use, Road///Race Engineering, and the packages they put together I'm running stage 1+. Basically it's fueling mods to max the stock turbo with the plus being optional cams. The audio upgrade is on the first post but everything else I've done to the car is below.
    Suspension and handling;
    Road Race 25mm adjustable rear anti sway bar
    GTSpec carbon rear strut tower bar
    WORKS Crox plate II
    WORKS stainless braided brake lines
    Stoptech slotted front brake rotors
    Stoptech street/track pads all around
    Engine and power;
    K&N air filter drop in replacement, stock airbox
    RMR hard pipe, from airbox to turbo
    WORKS 76mm TBE, ceramic coated downpipe, IP, axle back exhaust
    WORKS diverter valve (JDM OE style blowoff valve, recirculated)
    RRE high flow rally cat
    RRE manual boost controler
    Denso 720cc injectors
    Walbro 255 high pressure fuel pump
    HKS 272 intake/exhaust cams
    Others;
    GTSpec carbon radiator shroud/diverter, promotes airflow through radiator
    Zeitronix wide band o2 meter, EGT, AFR, boost and lambda monitoring
    Sparco harness bar and 4point Sparco harnesses
    window tint
    integrated garage remote to center console
    Laptop and OBDII cable tuning and map changing, 91 & 100 oct maps
    **edit**JVC Sirius and ipod module.
    All upgrades revolve around keeping the car stock looking and daily drivable reliability. To that effect all added wires are wrapped with flexible tubing that looks like the stock wiring loom (see power cable install pics) or vacuum tubing is used under the hood for high temp applications. The eagle eyed out there would spot the MBC(really plain looking though) and EGT probe coming out of the manifold but not much else. Even the stock manifold heat shield was drilled and painted flat black and put back on, at a glance nothing looks out of place. My one concession to bling is the airbox hard pipe, it's polished and the coupler is red but it's almost so dirty you can't tell. The labels on the injectors and the BOV have been removed and these parts look stock. I can't really hide the cam lope but the tuner made it so when I turn on my a/c the idle jumps to 1k and smooths right out and you almost can't tell, people just think I need a tuneup anyway. My instructions for the tune were a nice strong road car that I can beat on all year round and not break (both octane maps), nice flat torque curve is way more important to me than peak dyno numbers. I estimate about 320 to the wheels based on other setups but I've never been dynoed.
  5. #50
    FJF's Avatar
    FJF
    FJF is offline No Team
    Sep 2008
    NYS
    1,038
    What does the car run in the quarter?
    Alpine - US Acoustics - Earthquake
  6. #51
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    I don't know I've never run it and I probably never will. My brother says I sleep at the lights.
    The car lives for the canyons and excels when pushed.
  7. #52
    Oct 2007
    Queens, NY
    26
    7,385
    149 Post(s)
    Man, that is so awesome stuff.
    I live about 45 min from GT/Ravspec haha.
    I can see this running high 11's atleast.
  8. #53
    FJF's Avatar
    FJF
    Sep 2008
    NYS
    1,038
    You said the car had never been dyno'd. Your trap speed would give us an idea as to the power you're making.
    If it's not obvious, I have fairly competitive IX.
  9. #54
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    Quote Originally Posted by FJF View Post
    I see. I'll end up dynoing it one of these days, before the next upgrade at least. It was dyno'd with the catback and air filter, no tune and did 256hp and 263tq on Harmanmotive's awd dyno. I'm not sure that dyno is there anymore though.
    If it's not obvious, I have fairly competitive IX. Look me up on EvoM, like on the suspension forum.
    The one in your sig? I'll have to check it out.
  10. #55
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    Thanks.
    I'm not sure where that is but if you are ever around the San Fernando Valley lmk.
  11. #56
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    Anyone know why I can't edit first page posts? Is it a time lock or can you only edit so many times? I started hosting pics on Picasa and now I can't remove my uploaded pics in my first page of posts to change to the links.
  12. #57
    FJF's Avatar
    FJF
    Sep 2008
    NYS
    1,038
    No, that's not my car. Sorry, I didn't mean to give that impression. Look me up on EvoM sometime.
  13. #58
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    I started looking through your threads. what model Recaro car seats were you using? I use the young sport in my wifes car.
  14. #59
    FJF's Avatar
    FJF
    Sep 2008
    NYS
    1,038
    Most of my threads are about audio and detailing - hobby stuff. I don't ask questions; typically, I'm the one who responds especially on the suspension forum.
    I wish I could remember what they were called. I bought them for ~$125 each, if that helps. My kids loved them. As a side benefit, every cop that pulled along side with the seats in the car never gave me another look. lol
    <sigh> The kids outgrew the Recaros. I sold the seats locally to an STi owner with twins.
  15. #60
    AWD PSI's Avatar
    Aug 2010
    SoCal
    177
    Bazooka sub?
    If Kicker is crap can Bazooka be any better? For the price I'm tempted just to find out. Bazooka ELB110RS
