Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 121 to 135 of 142
Reload Thread: My Memphis Car Audio R/T Dakota Build
  1. #121
    1LOUDRT's Avatar
    1LOUDRT is offline Member
    Jun 2010
    Ozark, MO
    116
    Re: My Memphis Car Audio R/T Dakota Build
    Full Feature from Car Audio & Electronics Magazine
    Crazy Custom Dodge Dakota - Show Cars - Car Audio and Electronics
  2. #122
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
    Well, I was lucky enough to pick up a sponsorship through NorthStar battery company. They seen my truck at SEMA with the Telcom batteries in the Bed and wanted to talk with me. They had no Idea I lived in their back yard. So after a few months here we are with Two of their new Blue Top G-31 AGM engine start batteries. Here are the specs for each of these batteries.
    NSB G-31M
    12 volts
    1150 Cold Cranking Amps
    1370 Marine Cranking Amps
    2150 Pulse Cranking Amps
    205 Minute Reserve Capacity
    Electrical characteristics
    BCI Group Number 31m
    SAE Terminal configurations
    Capacity - 20 Hour Rate 100Ah
    Capacity - 10 Hour Rate 92Ah
    Internal Resistance 2.2 m
    Short Circuit Current 5000A
    Measurements
    Height w/Terminal 9.12 in
    Width 6.77 in
    Length w/Rib 12.91 in
    Weight 77.8 lbs
    I started today cutting and welding. The idea behind their AGM design is that the battery can be mounted in almost any way except inverted. So I decided to use that to my advantage. I'll be building a battery rack in place of the stock battery tray and will mount one there as it usually is. I Decided to put the second battery on the passenger side and will be mounted on it's side. So far i only have the passenger side backet fabbed up but the driver side will come later this week.
  3. #123
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
  4. #124
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
    Well I Started on the Driver side- I've been wanting to trash the stock battery tray for years and I now I can. Pulled it out and made the frame for the tray. I'll work on the supports tomorrow.
  5. #125
    Alexlivingloud's Avatar
    Alexlivingloud is offline Junior Member
    Jun 2011
    Sacramento, Ca
    19
    Thats a really nice dakota you got their ...not a big fan of dakotas but this one is nice..
  6. #126
    SPLAudioHz's Avatar
    SPLAudioHz is offline Senior VIP Member
    Sep 2010
    Indiana
    322
    1 Post(s)
    You know what would make that truck really awesome? Some mud Lets go off roading!!!!!!!!!!!!! THEN WE WILL DRINK A LOT AND FIGURE OUT HOW THE HELL WE WILL GET THAT TRUCK CLEAN!!!
  7. #127
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
    Been Busy but today I had some spare time to start the sheet metal around the battery boxes and engine bay. I am building these so they can easily be taken out if need be.
  8. #128
    FLboy4x4's Avatar
    FLboy4x4 is offline CarAudio.com Elite
    Mar 2011
    Lehigh Acres, FL
    772
    1 Post(s)
    Looks good man makes me want to hurry and start my work on my mini truck but I gotta wait for some money to get right and then do it.
  9. #129
    Vossy's Avatar
    Vossy is offline CarAudio.com Elite
    May 2010
    St. Cloud MN
    1,508
    19 Post(s)
    I still think that things crazy
    2 Sundown Z 12s
    2 AQ 2200s strapped @ 1
    Infinity 6030cs on a JBL GTO 75.4
    in a BMW e46
    Youtube: www.youtube.com/diablo2369
  10. #130
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
    Thanks fellas
  11. #131
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
    Put in a couple more hours of fab work today. Slowly comming along. Wish I had a Metal Brake -Would have made doing this alot easier, Instead I'm cutting out my panels using a plasma cutter, getting as close to my line as possible without burning through it and then grinding all my edges straight. This is what takes the most time. I'm also trying to keep both sides some what uniform so it's easier on the eye's.
  12. #132
    BlactimusCrime's Avatar
    BlactimusCrime is offline NUT HUGGERS UNITE!!!
    Jul 2010
    Your mom's port, OH
    22
    3,032
    3 Post(s)
    How did i miss this for almost an entire year....wtf... damm nice truck man
    Quote Originally Posted by loudrc View Post
    fuck you eddie.
    Quote Originally Posted by dbeez View Post
    Judge me not by what i've done but the amount of haters on my balls.
    Quote Originally Posted by CRXBMPN View Post
    you have the best user ID on teh site playa
    Refs: NateBerrier, Thegreatestpenn, mossberg385t, mfenske, plugitin, retroaudioinc, michaellane, Ge_off_me
    Feedback- http://www.caraudio.com/forum/buyer-seller-feedback/489798-bumpinboats-feed-back-thread.html#post7273394
  13. #133
    focused313's Avatar
    focused313 is offline Learning With Every Post
    Mar 2004
    Michigan
    245
    I'm honored to have viewed this thread.
    I hope somebody hits the person that keyed your truck with a car!!!
    Had JL 12w3's...replaced with Type R's...and couldn't be happier
    God Is Love.
    Don't , I'm Just Here To Learn.
  14. #134
    2Dcore's Avatar
    2Dcore is offline F*It
    May 2011
    A craphole town
    475
    15
    4 Post(s)
    Awesome!!!!!! Love everything bout it. The body, i love the color and air brushing. The system is cool as hell. I'd love to hear it. I just got my system in, we started at 3pm got finished at 9:30am Had to build sort of a 6th order blowthrough box for 8 10" subs never thought how hard it was going to be to fit all them in a 1990 Isuzu lowrider pickup. I wish i had the patients to do such a clean install like you. i want it in right away, Hate to wait so it's not the best looking but not to shabby. Cool good job.
  15. #135
    1LOUDRT's Avatar
    Jun 2010
    Ozark, MO
    116
    Thanks Fellas'
    Well I had a show on Sat> so I had to hurry up and knock these out. Worked on them all day Thur and Friday. Still need to make another panel to run accross the back firewall area but so far I'm really happy with the turn out. The front panel I cut out and then took it to a place that does my water jetting and had them cut out the R/T and Dakota into it. And yes My paint booth was rigged out of a E-Z up canopy, plastic drop cloths and 2 filters with the down draft one attached to a box fan. works great.
