Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: How are you using 0 Gauge?
  1. #16
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,400
    138 Post(s)
    Re: How are you using 0 Gauge?
    Quote Originally Posted by Popwarhomie View Post
    I dont see wasting your money on 0 gauge if your amp requires 4 gauge
    If you ever upgrade then id be looking into 0 gauge.
    Since I sold my 3500D and pulled my HDC3s out Im running a temp setup with a Kicker 400.1 amp with my 0 gauge. It actually fit fine in the terminals
    If you have multiple amps that require 4 gauge, your going to need a 0 gauge. Unless you want to run multiple runs of 4 gauge, which would probably wind up being more expensive.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - AT - ASE (local) - Batcap - DC - eD - Excessive Amperage - Powermaster - Rainbow
    In Nashville? Me too! Pm me and come hangout!
  2. #17
    alex50's Avatar
    alex50 is offline Member
    Feb 2010
    Tulsa, OK
    34
    Thanks guys. I have 2 JL Slash amps. I also have bought a streetwires distribution block that has fuses. When i was shopping around for them there seemed to be 2 different types though. I think they were power distribution and ground distribution. Believe the gold plated ones were the power dist like i bought.
    I believe you guys, it just doesn't make sense to me how you can put 0 gauge input and 4 output and have that same power transfer through. Seems like just splicing some 4 gauge into 8. I really just bought it for a backup to be safe of any fuses going out.
    I will just stick with the 4 since that's what it says. Appreciate the help though
    Thanks
  3. #18
    tylork92's Avatar
    tylork92 is offline CarAudio.com Veteran
    Nov 2008
    North Carolina
    2,305
    1 Post(s)
    yep distro blocks
    [/SIGPIC][/SIGPIC]
    93 Ford Ranger
    full fiberglass panels and a-pillars
    XS d6500/ Mechman 260A
    2 SA15s
    Sundown 1500dv1
    Toolmaker plexi, dual inputs, distro blocks.
