Head Unit: Eclipse AVN5510 w/ Ipod control (IPC-106)
Component Speakers: Hybrid Audio Clarus
Amplifier: Cadence ZRS-7504 (bridged 2x300w)
Started with this:
Filled gaping hole with this and sealed to door with silicone:
After B-Quiet sound deadener applied:
Custom MDF baffles and rings made in my basement with a jigsaw and coated with 4 coats of paint to avoid water penetration:
Baffles, speaker and crossover installed:
I used non-hardening modelling clay to seal the ring to the baffle and the baffle to the door. Should I be using a gasket between the speaker and the baffle?
Closed cell foam added to door card where I thought it might be necessary:
Double DIN installed. I painted the install kit but its still not right... obviously:
Front stage amp installed under rear deck. Fiberglass subwoofer enclosure should be done soon and will be installed in passenger side trunk corner:
Obviously I'm no professional. Actually this is my first audio install ever.
Register To Reply
Bookmarks
