Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: first box build
  1. #16
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,654
    96 Post(s)
    Re: first box build
    Quote Originally Posted by marcotheclepto View Post
    oh, i didnt know this was seriously first time, looks decent like the flush mount. haha. just make sure to use titebond on the joints and seal all the seems well.
    yeah i fuc.ked up on the first cut out so i desided to make it a flush mount to save the wood
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
  2. #17
    Boomintempo's Avatar
    Boomintempo is offline <---Old tempo setup, lol
    Jul 2009
    Kansas
    36
    542
    24 Post(s)
    Re: first box build
    Not too bad for your first build. Not the best choice of wood, not the cleanest cuts...but at least you had a plan, knew the size of the box, and knew what and how to tune it. Just make sure you seal it up real good and you should be OK with lower wattage.
    Most people first box, that I saw back in the day, were usually made of plywood as well. Really thin plywood. LOL, I remember some friends had a "ported" box where they just drilled different sized diameter holes in the box.
    Not too bad though...and at least you learned some stuff...your next box will be better!
    2010 Golf TDI
    HU: Kenwood DDX319 DVD Receiver
    Front Stage: Infinity Reference 6030cs
    Rear Stage: Pioneer TS-D1720C
    Comp Amp: Rockford Fosgate R400-4D (Birth sheet says it does 543 watts, HA)
    Subs: 2x 15" Lanzar Opti 1535d
    Sub Amp: Hifonics Colossus ltd
    Still waiting to install everything. ---Feed back http://www.caraudio.com/forums/itrader.php?u=72321
