http://forum.stevemeadedesigns.org/index.php jew shell put it here also
comming along nicely great job so far
2001 Honda Civic EX
power acoustik 8" over sized touch screen
doors Stock
1- Atmos Audio 18
1- Audiopipe 1000d mini @2 ohms
Electrical stock for now
http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
http://www.myspace.com/sykodjthereal"]If you Need Beats click this
http://www.carstereoforum.net"]http://www.carstereoforum.net
More pics chuck![]()
TEAM LETHAL BEATZ
2000 Ford Focus LX
HU: Pioneer Prem 880
COMPS: CDT Audio CL-61i 6.5" Component Set
COMP AMP: CDT Audio SQA-4100
WIRING: Kolossus Flex 0 Gauge (for sub amp)
Kolossus Fleks 4 Gauge (for 4ch amp)ALL KnuKonceptz RCA's and Speaker Wire
SUBS: 2 12" AQ HDC3's
SUB BOX: 4.2 @ 36hz WALL COMING SOON
SUB AMP: Sundown 3500
BATTERIES: (Front)Optima Yellow Top
(Back) Deka Intimidator 9A31(X2)
ELECTRICAL: Big 3 in KnuKonceptz KLM 1/0
Mechman 250 amp alt w/ ext reg
2 Runs of Kolossus Flex 0 Gauge
is there a reason y the godhatescivics jerk is running around flinging poo on your build log? seems like a total duche to me.
or you could be a grown up and explain why you continue to thread bash this guy. Your quick to disrespect him but wont answer a simple question. That is dumb not asking why you are acting like a PRE-TEEN
Nice 4th order, I'm thinking about doing a 6th order for my 2-18's and might need a hand in the design, I think I have it figured out but not 100%.
Drew
Setup in the works-
2-18's ? 6th order?
1-HK4000D@1 ohm
4-Bravox 3-way comp sets
1400 rms on mids and highs
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman, xtcxyooj, chaunb3400, oldschoolboomer (x2), SPLluminator, DBBOOM, Kevinn, JEXTEL, 169db , bernser1er ,wgsj_fortvalley, Gobulls09, BushJ311(x2) , cyoung88 , vickman08, uglydimple12, fatpat1080, SlabRider210 , Smaxor5, iamamp3pimp(x2), snoopysnooper
More work done today. Box should be done tomorrow. Decided Im going to add .4 cubes to the sealed chamber so I can fit the magnets in there. Just need to keep fiberglassing the outside of the box tomorrow, mount the baffle, mount the top, and Ill have a finished box. Then trim work begins. Doing a whole lot more fiberglass on the top and bottom.
Cutting tripple layer baffles with a jigsaw *****. Burned one up. Gotta use another tomorrow to finish the second hole.
Where the box stands with the new port.
Box bottom. Single layered now, doing more tomorrow.
Wet it out.
One of the sides.
Side just about dry.
Bookmarks
