Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 112
Reload Thread: Porsche 911 SS build
  1. #91
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,113
    31 Post(s)
    Re: Porsche 911 SS build
    Quote Originally Posted by dave_damage View Post
    Soundstorm? why?
    They are just rear fill....I'm sure they will be replaced at some point in time if they don't serve the purpose....I'd really like just a mid/full range and no tweeters back there so I may snip the tweeter wires ........but it was all I could come up with to fit the stock location for now and not look bad.....it is pretty shallow back there also 1 3/4 to be exact....if I measured right....
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  2. #92
    ltr450racer690's Avatar
    ltr450racer690 is offline CarAudio.com Elite
    Jan 2009
    west laffy
    1,515
    looks nice man.
    Bought from:99grandprixGT,chereck04,Shinju, mrmakinmoves,basscort2009,TnT_Sounds, Sicaudio,KHARPS
    trades with:Bologna,Jordon32990,kraudio12
    SOLD TO: j225, taylorfade, dkhage1 , vulocity22
    2009 Subaru legacy se
    headunit: JVC-KR8500
    Front fill: 2 ST350 and 8 6" selenium
    Substage: 4 sa10's in a 4th order
    Sub power: Sundown 3500 at .5
    Electrical: Yt under hood 6 33ah in the trunk, 1/0 shok everywere
  3. #93
    Aug 2006
    34,113
    31 Post(s)
    Quote Originally Posted by ltr450racer690 View Post
    looks nice man.
    thanks....
  4. #94
    Aug 2006
    34,113
    31 Post(s)
    because of the rain I haven't got to work on the system much....the USD horns won't fit due to duct work in the kicks.....no room for the motor off the horns...so i'm going with a set of German made DDA-T28 tweeters in kicks that I had laying around....Here are the tweeter specs.....
    The DDA-T28 is a wide-band tweeter with a 28mm coil diameter. It uses two rear chambers, one behind the voice coil and a second milled aluminum chamber behind the motor. Shorting rings are used in the motor to flatten the impedance curve and wick away heat from the coil windings. The proprietary fabric dome has a range extending 10,000Hz past the hearing capability of the human ear. Countless hours of listening have been done to "tune" this tweeter via each part, glue joint and assembly step. The result is a most listenable tweeter which will show you new details you hadn't known possible.
  5. #95
    Aug 2006
    34,113
    31 Post(s)
    I pulled out the JVC yesterday and decided to install a Blaupunkt deck...and keep the system fairly simple.....
  6. #96
    Aug 2006
    34,113
    31 Post(s)
    Well I updated the Door speakers in the 911.....here are some before.....
  7. #97
    Aug 2006
    34,113
    31 Post(s)
    What was in the hole....
  8. #98
    Aug 2006
    34,113
    31 Post(s)
    What filled the hole a vintage set of MB Quart Q series 5 1/4's ...They have some pretty good midbass.....
  9. #99
    Aug 2006
    34,113
    31 Post(s)
  10. #100
    Aug 2006
    34,113
    31 Post(s)
  11. #101
    Aug 2006
    34,113
    31 Post(s)
  12. #102
    plugitin's Avatar
    plugitin is offline She Bangs plugitin is a Supporting Member of the forum!
    Jul 2009
    Da U.P. eh?
    23
    6,455
    1 Post(s)
    you and all your nice cars
    Team DC Audio
    Refs: absoluteaudio, rab, walnut, seedubs1, dbeez, -leister-, Louisiana_crx, bubbagumper6, DS Autpsports, Mr.Ronin_2U, lil98cabrio, wone, micah_jones, grinder1989
  13. #103
    Aug 2006
    34,113
    31 Post(s)
    Today I ordered some 19's for the car....and I'll probably change decks again tomorrow....
  14. #104
    Jh8909's Avatar
    Jh8909 is offline CarAudio.com Veteran
    Jul 2009
    Pine Hill, NJ
    2,394
    nice job so far. can't wait to see the final product.
    REFS: Ridinhi, --Navi--, gboo559, sojiaraggs9000, usampsman, 9515Rob, GetLikeMe, sojiaraggs9000, ButtaMax, RJesus, Twank06"GTO', speedfreak28
    Bought from, Sold To
    ^there is a lot more i haven't listed by the way
  15. #105
    Aug 2006
    34,113
    31 Post(s)
    Thanks...the Old School Jensen KA3 3ch I hooked up has some really good sound ...I'll decide if I want to keep it or not after some listening test....I'm really considering going vintage Blaupunkt gear except for the deck and sub...a newer Blaupunkt deck and the DD sub of course....
