Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 34
Reload Thread: Jeep Grand Cherokee - Single 15" AQ HDC3 Setup - Need advice
  1. #16
    WOT's Avatar
    WOT
    WOT is offline Banned
    Nov 2007
    Toronto,CANADA
    3,667
    Re: Jeep Grand Cherokee - Single 15" AQ HDC3 Setup - Need advice
    Oh people run them @ .5 daily, the amp will take .75 + imp rise to over 1 anyways no problem, no reiability problems whatsoever
    If I had 250ish bucks and I was you, wire to .75, pick up a C&D tech battery that are for sale on the forums here for $125, 40-$80 for a run of 2 or 0 gauge (2 obviously saves money and is fine for your amp, but 0 gauge gives you headroom if you go bigger), $15 for a couple ring terminals for the big 3 (so you obviously do the big 3), and thats puts you at..... $225 ish, Id spend another $30 on a stinger led voltmeter, always nice to watch it, and it looks cool
    Youd be fine with that big batt, and there **** cheap
    Do the big 3 man, it helps ALOOOOOOT
    You can also get your factory alt respun to a higher amperage for ~100 if you have a local alternator shop
  2. #17
    WOT's Avatar
    WOT
    Nov 2007
    Toronto,CANADA
    3,667
    Oh and ps, I dont know if you have a weld supply shop locally, but here in my town we have a welding gas supply place and they sell pure copper cable, just a straight black jacket cable, but they sell 2/0 cable for $2.79 a foot, 1/0 was 1.99 I think, pure copper, just no fancy name or branding or middle man.
    Check your weld supply shops if you wanna save some bucks. weldsupply.com also has VERY cheap ring terminals
  3. #18
    GrnZ28's Avatar
    GrnZ28 is offline Senior VIP Member
    Jun 2006
    Chicago,IL
    410
    WOT, you the man ! I do have a weld supply shop about 10min from my house , i will give them a call in the morning! So should i be running two batteries total , underhood and in the rear? Also whats the wiring config to get .75 ohms ?
    00 Jeep Grand Cherokee
    HU:Alpine CDE-102
    Sub: (2) 12" AQ HD3
    Amp: AQ2200D
    Doors:Polk Audio
    REFS-Chitown impala,Caliese
  4. #19
    WOT's Avatar
    WOT
    Nov 2007
    Toronto,CANADA
    3,667
    2 batteries is better than one yeah, if possible, keep the second battery under hood ( I removed my big *** factory air box and kept mine under ), that way you dont have to run wire back to it aswell, saves you money and you save voltage on resisitance.
    DO you know what coil config your sub is, I dont remember seeing that
    EDIT: MLStrass said the sub MAY be DVC 1.5ohm, anyway you can verify that? Ill get you a diagram right quick, but definetely verify before wiring it like this
  5. #20
    BigJoker's Avatar
    BigJoker is offline Team D.O.A V.P.
    Nov 2006
    Chicago,IL
    33
    2,094
    27 Post(s)
    Quote Originally Posted by GrnZ28 View Post
    speaker wire + + and - -
    and since you are in Chicago, pm my friend Koopa about batts.
    refs---gl0ck,unbonyr,xxxpower,sundownz,C5,psych0ticnemes1 ,RydHy3845,DrumProdigy83,Mlstrass,j3bus2k3,chaarli eee,khail19,tapout,sleepyjr,CRXBMPN,skeptikal,head bussaboi,blove1991,jbizzle,DJ,Jonny101abc,rival904 ,popwarhomie
    neutral---djman37,team h&k,sxpimpin
    do not deal with Belunt or hotcarl.
  6. #21
    WOT's Avatar
    WOT
    Nov 2007
    Toronto,CANADA
    3,667
    Wire like this for .75 load
  7. #22
    GrnZ28's Avatar
    Jun 2006
    Chicago,IL
    410
    Not 100% sure on ohms of subs just from what mlstrass said. I should find my DDM , which setting does it have to be on again ?
    HU:Alpine CDE-102
    Sub: (2) 12" AQ HD3
    Amp: AQ2200D
    Doors:Polk Audio
  8. #23
    WOT's Avatar
    WOT
    Nov 2007
    Toronto,CANADA
    3,667
    Ohms, the little horseshoe symbol
  9. #24
    BigJoker's Avatar
    Nov 2006
    Chicago,IL
    33
    2,094
    27 Post(s)
    they should be dual 1.5
  10. #25
    GrnZ28's Avatar
    Jun 2006
    Chicago,IL
    410
    One coil is reading 00.1 and the other 00.2 , both kinda going back and forth 1-2 . What ohm is my sub !?
    HU:Alpine CDE-102
    Sub: (2) 12" AQ HD3
    Amp: AQ2200D
    Doors:Polk Audio
  11. #26
    WOT's Avatar
    WOT
    Nov 2007
    Toronto,CANADA
    3,667
    You must have it on the wrong setting, should be 1.5 not .15
  12. #27
    J31Rob's Avatar
    J31Rob is offline CarTune Netwerk
    Nov 2006
    Indiana
    11,243
    397 Post(s)
    You has HD3.. not HDC3.
    the FUNK / facebook.com/The.Funk.765
    CarTune Netwerk / facebook.com/cartune.netwerk0
    Alpine / Sundown Audio / Sound Solutions Audio
    Audio Technix / CT Sounds / Execution Audio
  13. #28
    GrnZ28's Avatar
    Jun 2006
    Chicago,IL
    410
    Ok wired it ++ , -- , connected the dmm to the terminals on the sub box and i get a steady 1.5 Is that what i want to wire to .75 ohms ? Dmm was set on DC OHM 200
    Update: Found a full run of Memphis 4awg in the garage from my old blazer , possibly just gonna run 2 runs of 4awg, what do you guys think?
    HU:Alpine CDE-102
    Sub: (2) 12" AQ HD3
    Amp: AQ2200D
    Doors:Polk Audio
  14. #29
    jbizzle's Avatar
    jbizzle is offline CarAudio.com Veteran
    Aug 2007
    Chicago, IL
    5,804
    10 Post(s)
    Touch the leads together and subtract the resistance.
    Make sure you have it on the "OHM" Setting.
    MW Car Audio - www.MWCarAudio.net
    Feedback Thead: http://www.caraudio.com/forums/buyer-seller-feedback/378649-jbizzle-feedback-thread.html
  15. #30
    GrnZ28's Avatar
    Jun 2006
    Chicago,IL
    410
    Did a little diggin and found mlstrass old thread on this sub and box. Very nice ! So sub is deffinitely D1.5 ohms and is getting wired to .75ohm on my AQ 1200D =)
    http://www.caraudio.com/forum/showthread.php?t=234443
    HU:Alpine CDE-102
    Sub: (2) 12" AQ HD3
    Amp: AQ2200D
    Doors:Polk Audio
