Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Reload Thread: El Camino SS build
  1. #31
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    Re: El Camino SS build
    I think I am going to steal his amp fans and use them for a weed eater LOL. they are like 4" aluminum fined high rpm fans
    Sony Mobile ES C-90 Audison Bit-One
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  2. #32
    glhman222's Avatar
    glhman222 is offline Junior Member
    Dec 2009
    New Jersey
    Hey i have a 1987 el camino, and want to put in a RE SE 12 inch in the smugglers box. Is there any way possible i could get the dimensions of your build? I only want to take up half of the space because i want a spare tire, so i would cut your dimensions in half basically. Thanks
  3. #33
    splferrell's Avatar
    splferrell is offline Member
    Aug 2008
    Toledo, Ohio, United States
    90
  4. #34
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    Quote Originally Posted by glhman222 View Post
    In this El Camino the spare tire ate up most of the area, as it was a full size spare (although not the same as the wider tires that are on it) The box we built was a tad bit on the large side but sounds pretty smooth on the lows. Only issue I could see in building a small box for that area is finding a way that looked good where you could move it easily to get to the spare without having to worry about the box falling down when you stopped.
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  5. #35
    glhman222's Avatar
    Dec 2009
    New Jersey
    Im not all that interested in the appearance, i just want to be able to have a decent sized box with some good bass from a single RE SE 12"
    If i have a problem with the box moving around, il make a bracket that will hold it in place.
    That's basically what I need the specs of, if you happen to have them, if not no big deal, thanks.
  6. #36
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    Only measurements I remember is the part that goes inside the spare tire well is 7.5" tall (6" after you subtract for the wood) and the rings we used are .5" and .75" glued together then we made stands to bring the depth 4.25" so the frame didn't go into the box. Thing is we had to bolt this box in so it wouldnt slide.
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  7. #37
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    http://img442.imageshack.us/img442/2127/imag0108.mp4
    The new engine puts out about 450-500hp.
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
