NOTE: THIS IS NOT FOR GLAMOUR, ONLY FUNCTION!
Alright so i decided to change out my sub last weekend. made a few orders on CarAudioClassifieds, eBay, and of course hereand finally got everything installed. Tell me what you think!
Old setup:
Sub: 12" RF Power HX2 D2
Amp: RF T10001bd
Batt: Kinetik HC1400
Box: ~2.5 cu.ft. tuned to 40hz (RF Recommended specs)
4awg from battery to amp
0awg Big 3
New setup:
Sub: 12" RD Heavyweight D2 Daily
Amp: Sundown SAZ-3000D
Batt: Kinetik HC2000 and HC1400
Box: 2.71 cu.ft. before displacement tuned to ~34hz (still don't know Heavyweights displacement? either way its the biggest box i could fit in the opening for my trunk)
0 awg from battery to amp (3 300amp fuses)
0 awg Big 3
Damplifier Pro in Trunk
Now onto the pics!
This is the old ugly setup I had, but it was definitely functional. Just had to keep the trunk closed to hide my embarassment
look at that bootleg bracing haha. a couple 2x4s cut to keep it from sliding around worked like a charm.
Behind the box you can see the battery and amp
They fit perfectly! But not on purpose....
See the box was had to be put in upside down because i couldn't fit it the other way (woops)...the back was supposed to be flush with the back of the seat buut yeah that didn't work out. After a lot of sanding that basically ruined the paint job i did on it, i finally got it in. Luckily it turned out my amp and batt could be hidden out of sight behind it...guess it worked out for the best
Here's the back of the box from another angle
including some more bootleg bracing for my batt. But like I said, function was key, not much else was worried about.
So finally time to say goodbye. Started taking out everything with the help of my pops
Got the box out
amp still attached to the back
all the brown edges you see are where it was sanded down just to get it to fit. and even then it was a bish to put in
This is how it was supposed to sit in the trunk
another angle with the amp removed
trunk empty
Register To Reply
oh yeah only 15's
Bookmarks
