Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Reload Thread: My modest, average joe, install (56K good luck).
    Alter Ego Trip's Avatar
    Alter Ego Trip is offline Witty Statement Here
    Jun 2009
    MT
    34
    243
    To preface; I'm a huge HT buff, and have spent tens of thousands of dollars on equipment and room treatments. I've always been one to do things myself rather than pay someone else. You just gain a greater sense of satisfaction when it's done. Well due to all my funds being dumped into my HT, my truck's have always been neglected. Well lately I've been getting the itch to do more than the basic install so I decided to tackle the project. This is a daily driver, and not designed to ever be near a sound comp. I also want the install to retain all the stock aesthetics.
    Equipment:
    Amps-
    sub: MTX TE1501D
    mains: MTX TE1004
    front stage: JBL 660gti
    subs: two 12" RE SE's
    deck: Alpine W404 multi media and Alpine 12 disc changer
    EQ: Imprint
    wiring: Knu Koncepts 1/0 gauge, 4 gauge, etc.
    sound deadening: Raammat and ensolite
    Interior Gutted, nice and shiny.
    Doors are gutted as well. I chose to remove the window regulator's to make getting deadening inside the door a whole lot easier. Chevy really makes it nice for taking things apart. Half the truck was assembled with a 10mm socket.
    Don't forget to tape up the window before removing the reg though. Bad things will happen if you don't.
    Even though it's a purty yellow, avoid messing with the box under the driver's side seat. This controls the airbag....nuff said.
    First layer of mat is down. I used a combination of wiffle ball and golf ball to roll it around the curves. This took a lot longer than I originally figured.
    Second layer finished. Flat exhausted at this point. The only part that didn't get a full two layers we're directly above the front seats. I ran out and had to make do with what I had.
    Back wall finished. This will only see a single layer as well.
    Stopped for a few minutes to snap a few pic's of a T storm rolling through.
    Jun 2009
    MT
    34
    243
    Re: My modest, average joe, install
    OK, enough screwing around, back to work. Stuffed a bunch of ensolite in the back quarters.
    I doubt it will do much, but seeing as I had a bunch left over I decided to lay some on the floor pan.
    Dropped 2 layers on the outside inner panel, and also covered any piece of exposed metal (intrusion bar, etc). Definitely made a difference knocking on the door. There was also a surprising improvement between the first and second layer. Here's part way through.
    I also added some ensolite behind the speaker position to help with standing waves.
    Seeing as I only had 2 days off work in a row, and this is my daily driver, I had to get cracking and at least get the truck back to driveable. You'd laugh if you saw me trying to remember how it all went back together. Lack of sleep doesn't help any.
    Reg's back in the doors and ready for the outer skin. I'm in the process of building some MDF spacers for the door openings. This should create a little diffusion between the speaker and metal door. In trying to stick with the stock look, the JBL tweeters will be mounted above the woofer with the included waveguides. Thank goodness for Chevy's massive speaker grille's.
    Jun 2009
    MT
    34
    243
    Cut out the MDF for the amp rack. Covered the back of it with ensolite to dampen it from the back wall. Yes I used screws to attach it to the back wall. I know some of you are adamant against this, but in case you haven't noticed, Chevy cut two huge holes for vents on each side of the cab. I doubt a tiny screw hole is going to matter much. Besides, I figure removal of amp rack is easier this way than using liquid nails. Screws are stainless to prevent any corrosion.
    Mounted amps, distribution block, and Imprint. Ran all the speaker wire. I had 14 gauge left over from my theater install so I used that. Maybe a little bit of an overkill but it was free.
    That's all for now, comment welcome.
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    Re: My modest, average joe, install (56K good luck).
    Quote Originally Posted by Alter Ego Trip View Post
    Is that a funnel cloud ?
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
    d-REW's Avatar
    d-REW is offline tuTWENTY
    Jul 2008
    denver COLORADO
    1,121
    nice clean start i like it. more pics when you get em!
    Refs: Rashaddd, SotoGrip, ProjectPechkin, Walled Taurus, Just303, tenbux1970, tmasco, Worstenemy45, blazron22z
    tEh ShOcKeR's Avatar
    tEh ShOcKeR is offline Banned
    Jul 2009
    Gotham City
    989
    Keep em coming.
    Jun 2009
    MT
    34
    243
    Quote Originally Posted by Louisiana_CRX View Post
    You know it sure looked like the start of one. I'm in western MT though, and Tornado's are really rare over here. We've had a couple touch down, but they are few and far between. This has been a killer year for T storms though. We've had more in the last month than I can remember in 10 years.
    Christo19's Avatar
    Christo19 is offline Rockfords are God.
    Jul 2009
    Bozeman, MT
    256
    thats looking really good so far
    1983 BMW 320i turbo
    HU:Kenwood x891
    FS: looking for Focal access comps, anyone have any?
    RS:Focal access 5x7
    Amp: Alpine 5 chan f357
    Mid bass: RF p2 8"
    Sub: Alpine type X
    Sub amp: Looking for something
    REFs: Socailstealth, Jake21, BLD 25, k3n12ock, sq_guru
  9. #9
    Jun 2009
    MT
    34
    243
    Quote Originally Posted by Christo19 View Post
    Thanks. I could use a hand, you up for a road trip?
  10. #10
    Kyle!'s Avatar
    Kyle! is offline Senior VIP Member
    Aug 2008
    Kansas City
    196
    VERY nice looking so far. I love seeing some good truck installs
    Refs: sundownz, hessdawg, nismos14, krisfnbz, 93dakota, woofercooker, iamsonic
    -2006 Ford Ranger Standard Cab- (budget build)
    Head Unit: Alpine IDA-X100
    Front Stage Amp:Infinity DPA275
    Front Stage: CDT CL-61A
    Sub Amp: Alpine MPR-M500
    Subs: Sundown SA-8
    Box: ~.6cf @36hz
    Deadener: ~56ft Damplifier/Pro
    Wiring: Knu KLMX 1/0 gauge, Klear Kable 12 gauge
  11. #11
    Aug 2006
    34,141
    31 Post(s)
    with global warming we will see a lot more bad weather than normal
    install looks good so far
  12. #12
    Loud3's Avatar
    Loud3 is offline Pay me, *****.
    Aug 2005
    Sin City
    28
    4,815
    I enjoy this thread.
    Maxima is SOLD.
    New project COMING SOON!
  13. #13
    blackbonnie's Avatar
    blackbonnie is offline The Revolution
    Jan 2007
    Grand Rapids, MI
    10,149
    your HT work has reallly helpe with this install....silverado?
    HU - Pioneer 800prs
    Mids - Peerless HDS nomex 6.5's
    Highs - Seas Prestige Alumi-domes
    Front Stage Amp - Sundown 100.4D
    Sub - SA-12
    Sub Amp - Saz-1000D
    Wire - Knukonceptz, Kicker Hyperflex
    Blackbonnie References/Feedback
  14. #14
    Jun 2009
    MT
    34
    243
    Quote Originally Posted by blackbonnie View Post
    You got it. My lease was up on my 07 so I purchased an 05 to play with. I'm in the process of building a 6.0 liter swap to replace the 5.3 when I get some time. Here's a couple quick pic's of some of my theater build.
    07 Chevy.
    Custom stage I built. I pulled down some of the covering to get the camera to focus. The whole front wall is treated with 2" thick fiberglass paneling. Speakers and receiver were just positioned to eq before adding more acoustic treatments.
    Changed out speakers for a better sound stage up front. These are powered by a Cinenova grand 300x5 amplifier. The rear surrounds are run off an Onkyo 906.
  15. #15
    Jan 2007
    Grand Rapids, MI
    10,149
    i had an 06 silverado and loved it. wish it was still around but when gas jumped to 4.70 a gallon and drivin 700 miles a week didnt help my bills at all.
    great install so far
    HU - Pioneer 800prs
    Sub - SA-12
    Sub Amp - Saz-1000D
