Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Reload Thread: My modest, average joe, install (56K good luck).
  1. #31
    Alter Ego Trip's Avatar
    Alter Ego Trip is offline Witty Statement Here
    Jun 2009
    MT
    39
    243
    Re: My modest, average joe, install (56K good luck).
    Not a whole lot to go over but I thought I'd update a little bit. I've been pretty busy with other projects, I got a whim to install Caddy lights in my truck so I've been preoccupied with this as well.
    Here's a pic of the 660GTi's installed behind the factory Bose grilles. Those wave guides were a tight fit. Tough to see but that's how I wanted it.
    Alpine W404 is installed. To the right is where I mounted the bass control knob for the Sundown. Yup. the MTX's are gone.
    I left the factory mic installed and just mounted the new Parrot BT one right above it. Works great there with no issues.
    Here's a couple shots of test fitting the box. A lot of angles here to maximize as much airspace as possible. I decided against running both RE sub's and have opted for just one instead. Seat will be raised 2" to clear. Sub box is right at 1.0cf. I am also building a custom amp rack to house the JBL crossover and Arc amp under the seat.
    Speaking of Arc.
    I decided to rewire some things behind the seat. I wanted to get the audio portion as far away from the power supply as possible. I also placed the mat back behind the mounting board instead of a direct mount to the back wall.
    BEFORE
    AFTER
  2. #32
    bigaudiofanati2's Avatar
    bigaudiofanati2 is offline CarAudio.com Veteran
    Jan 2009
    Bridgeton, NJ
    29
    2,272
    I love that head unit how do you like it?
    Your install looks good man, good job.
    My build thread.
    http://www.caraudio.com/forum/showthread.php?t=406175
    If anyone needs help just let me know
  3. #33
    Jun 2009
    MT
    39
    243
    Quote Originally Posted by bigaudiofanati2 View Post
    Thanks. It has it's pro's and con's. I'm hoping for an update as the UI isn't that friendly and it suffers from being a little sluggish from time to time. It's a little redundant as far as the touch screen go's as well. Everything you can do with the touch screen can be done directly below the screen via a hard button. The Parrot BT is a huge step up though in quality and performance. I actually don't mind talking on the phone now when I'm driving.
  4. #34
    Jun 2009
    MT
    39
    243
    Starting to see some light at the end of the tunnel. Spent all day today building a box, and mounting the amp's. All that's left is to finish wiring, tune the Imprint, and reinstall the seat with the new brackets.
  5. #35
    jadon087's Avatar
    jadon087 is offline The Snowman
    Jan 2007
    Columbia,Sc
    30
    2,472
    how does the sundown compare to the mtx amp? You have some very nice gear my man looking good.
    refs:Ca.com:pboulos(x2),jeepintn(x2),flipx99,altima98,h eyduude888,lmllopez, brchd, 22mountaineer(x2),NhustlaR(x2), Buck, crownvicon4's,quakercountry,cloak(x2),Twank06"GTO, fasfocus, WilsSebring
    sounddomain:banbury,GmcTruckman
    roe:jdiddy, Team_Havoc_Spl, grandprixgtx
    l
  6. #36
    Jun 2009
    MT
    39
    243
    I have no idea, lol. I haven't had a chance to test it yet. I figure as soon as I got it hooked up I wouldn't be as motivated to get it finished.
  7. #37
    carguy83's Avatar
    carguy83 is offline DLS Iridiums
    Sep 2004
    Houston, TX
    34
    674
    4 Post(s)
    very nice build man. this isn't your "average joe" install...
    [Head Unit] Eclipse CD-5100
    [Amps] Arc Audio 1500-XXK, Arc Audio 4150-XXK
    [EQ] Arc Audio XEQ
    [Rear Fill] Boston Acoustics SL65
    [Front Stage] DLS Iridium 8.3i
    [Subwoofer] DLS Nobelium 12
    [Dampeners] Hushmat, Cascade Audio Deflex
    [Wiring] Kicker Hyperflex, Audison Interconnects
    Refs: Slickrick, Moe Lester, 3.5Max6spd, 6Spdcoupe, Kpr10is, Vincent9515, NisAznMonk, etc etc
