very clean install
color is hideous though lol
very clean install
feedback thread
http://www.caraudio.com/forum/showth...appa5+feedback
lol the moderators here are GODS word to the wise
"don't cross them lol
On almost every honda I've dealt with, you just look in the little door cup (the one that you put your hand into to grab when opening or closing the door.
-There's usually a screw down in there hiding under a piece of plastic (that piece of plastic breaks EVERY ****ING TIME!!! You can't win, so go to the honda dealer and buy a couple lol).
-Then right behind the door-open pull lever, there's another little plastic ring that hides the screw, remove it (will probably break too) and the door is now only held in by those plastic clips.
-Just start at one of the bottom corners of the door and start pulling, it'll all just pop right off.
-The top is held in on the window sill. Once the bottom plastic clips are broken free, the panel lifts up and off of the sill hook.
-Once you get the door off, just wiggle the door-open pull lever through the door panel and you should be able to set it aside.
Hope this helps![]()
Bookmarks
